Обсудить в форуме Комментариев 8
For those who are using or planning to use Landsat data in their everyday work it is important to know, what imagery exists for the territory of their interest. When the territory is quite small and doesn't exceed 2-3 images then it is convenient to use browsing software like USGS GloVis. However, for huge territories, listing through hundreds of images can be very ineffective.
For facilitating of image selection and ordering it is convenient to use actual Landsat map, which shows all the Landsats from GloVis (read USGS) archives. Using attributive data, like cloudiness, acquisition time or image quality, it is easy to make preliminary assumptions on availability of the data. These maps are available as GIS data, so it is really easy to integrate them with any other spatial data using Arcview or ArcGIS.
Index maps for data from following data is available:
Data source - GloVis catalog, with represents USGS Landsat archives, largest in the world. Note, that large portion of data from Landsat 4,5 satellites (TM sensor), was not received and stored in USGS thus is missing from GloVis and our coverages, this data should searched through IGS (International Ground Stations ), in the presented maps there is no data about IGS scenes.
Last update of the catalog in January 2009, it is important to know, that after this time, new data will appear in USGS archives, especially TM and ETM+-SLCOFF, which still on the orbit.
Get data
Following data is available in Arcview shape-file format.
Sensor |
Global (file size, number of scenes) |
former USSR (file size, number of scenes) |
ETM+ |
| ETM+-SLCOFF | ||
TM |
180 meridian
Scenes which are crossing International date line are cut in 2 parts with the same attributes.
Relation of image frame to a real Landsat scene
Polygon which represents the scene in the catalog fits it quite well (red line - image frame), while not perfect, real Landsat image is usually several percents bigger. Following image illustrates this fact.
Attributes
Attributive information is slightly different for different sensors. All information found in GloVis metadata is ingested in the coverage attribute table.
Возможны следующие причины ошибки: Вы можете: Вы также можете: Воспользоваться поиском Сообщить нам о недоступой странице по e-mail или воспользовавшись формой быстрой отправки комментария. © GIS-Lab и авторы, 2002-2021. При использовании материалов сайта, ссылка на GIS-Lab и авторов обязательна. Содержание материалов - ответственность авторов. (подробнее).
СТРАНИЦА НЕ НАЙДЕНА!
Последнее обновление: September 09 2021
Creating multi-level tiles from QGIS project with QTiles
Rendering vector data with Mapnik without direct access to the storage
Geoprocessing with SEXTANTE for QGIS
Remote sensing Corona data - description and access
© GIS-Lab and authors, 2002-2013. Attribution to GIS-Lab and authors is required. The responsibility for the content of this article rests with the author (more).
