Description and latests news about development of enhanced Georeferencer plugin.
502 Bad Gateway
Important: this page is outdated and left for historical purposes. Georeferencing module is included in QGIS core and does not require separate installation anymore. The process of georeferencing is described in details in "Geographic referencing of the data with QGIS" (article available only in Russian).
Contents
Georeferencing of raster data in QGIS is accomplished using Georeferencer plugin (more in Russian). However this module allows transforming rasters using so called Helmert transformation, which is shifting and translating rasters. Obviously, this is not enough to georeference distorted materials, like scanned ones.
It is possible to use other software, such as GDAL (more in Russian), which allows to use more appropriate polynomial transformations (more in Russian). As QGIS includes GDAL functions, it is possible to use them to enhance Georeferencer functionality using them.
Enhanced Georeferencer can perform 1st, 2nd, 3rd order polynomial and thin plate splines transformation.
Source code for the enhanced Georeferencer module can be obtained from SVN.
svn checkout http://svn.gis-lab.info/qgis-gdal-georef/trunk/ georeferencer
Or get separate binary dll for Windows (latest trunk).
To install on Windows, copy dll to C:\OSGeo4W\apps\qgis-dev\plugins\
To install this plugin from source code, it is necessary to first install from source codes QGIS itself (more in Russian), after the plugin is installed like that:
cd build rm -rfv src/plugins/georeferencer cd ../src/plugins/ rm -rvf georeferencer svn co http://svn.gis-lab.info/qgis-gdal-georef/trunk georeferencer cd - make georefplugin make install
Installed plugin replaces current Georeferencer. Plugin is tested in OSGeo4W QGIS-1.5 and under Mandriva Linux.
502 Bad Gateway
