ПОМОГИТЕ узнать проекцию
agrohim_19
Сообщение agrohim_19 » 29 ноя 2019, 09:53
Здравствуйте! Помогите распознать проекцию для векторного слоя. Два файла mif и midi.
В мапинфо, в qgis, в аргисе пишет проекция неизвестна
mIF:
VERSION 550
CharSet "WindowsCyrillic"
  Delimiter ","
CoordSys NonEarth Units "m" Bounds (-10000000, -10000000) (10000000, 10000000)
Columns 10
   ID Integer
   OBJ_ID Integer
   OUTER_OBJ_ID Integer
   CAD_NUM Char (100)
   DATE_CREATE Date
   DATE_INS Date
   DATE_CHANGE Date
   CS_ID Decimal(10,0)
   COD_SDO_SUBTYPE Char (20)
   OBJ_LABEL Char (100)
DATA
REGION 1
5
199007.64 409052.6
199002.63 409045.49
199009.73 409040.45
199014.73 409047.57
199007.64 409052.6
REGION 1
5
200218.47 409539.33
200223.73 409529.14
200233.92 409534.42
200228.66 409544.62
200218.47 409539.33
REGION 1
5
И.Д
MIDI:
136422,1425403,,"19:01:000000:8(1)",20120210,20120222,20121126,1,"10100000200101",":8(1)"
136423,1425397,,"19:01:000000:8(2)",20120210,20120222,20121126,1,"10100000200101",":8(2)"
136424,1425402,,"19:01:000000:8(3)",20120210,20120222,20121126,1,"10100000200101",":8(3)"
136425,1425398,,"19:01:000000:8(4)",20120210,20120222,20121126,1,"10100000200101",":8(4)"
136426,1425399,,"19:01:000000:8(5)",20120210,20120222,20121126,1,"10100000200101",":8(5)"
136427,1425400,,"19:01:000000:8(6)",20120210,20120222,20121126,1,"10100000200101",":8(6)"
136428,1425395,,"19:01:000000:8(7)",20120210,20120222,20121126,1,"10100000200101",":8(7)"
136429,1425401,,"19:01:000000:8(8)",20120210,20120222,20121126,1,"10100000200101",":8(8)"
136430,1425394,,"19:01:000000:8(9)",20120210,20120222,20121126,1,"10100000200101",":8(9)"
42471,726481,,"19:01:010101:9",20110507,20110509,20121126,1,"10100000200101",":9"
48666,726482,,"19:01:010102:1",20110507,20110509,20121126,1,"10100000200101",":1"
50931,726736,,"19:01:010102:3",20110507,20110509,20121126,1,"10100000200101",":3"
54509,726741,,"19:01:010102:4",20110507,20110509,20121126,1,"10100000200101",":4"
56944,726742,,"19:01:010102:5",20110507,20110509,20121126,1,"10100000200101",":5"
39762,726749,,"19:01:010102:6",20110507,20110509,20150409,1,"10100000200101",":6"
И Т.Д.
Последний раз редактировалось agrohim_19 02 дек 2019, 11:01, всего редактировалось 2 раза.
Денис Афанасьев
Re: ПОМОГИТЕ узнать проекцию
Сообщение Денис Афанасьев » 29 ноя 2019, 09:59
Было бы неплохо указать географическое место, а также откуда получен файл. Ну и сами файлы выложить. Это план-схема, а без привязки к конкретному месту с координатами не разобраться.
Сообщение gamm » 29 ноя 2019, 10:57
agrohim_19 писал(а):
29 ноя 2019, 09:53
NonEarth
нету у вас проекции, написано жеж :mrgreen: ... если это метры, то какие-то квадратики, скорее всего кадастраторы делали. Значит либо Гаусс-Крюгер имени 42 года, либо Гаусс-Крюгер имени 63 года. Для всего остального (параметры уточнить) нужны те же точки в долготе/широте, на Гислабе много есть на эту тему ...
Сообщение trir » 29 ноя 2019, 11:11
