Обсудить в форуме Комментариев 1Редактировать в вики
Tool background and description.
This tool can be used for applying a single legend file (qml) for multiple raster or vector layers in QGIS.
| Made by | Opensource GIS development and projects |
Plugin is available via QGIS official repository.
MultiQML is under development and tested with QGIS 2.0 and higher.
You can obtain sources with this command:
git pull git@github.com:nextgis/MultiQML.git
After plugin installation and startup by clicking
main window will appear:
At left there is a layers list which shows layers depending of the active selector «Raster» or «Vector». To apply style to layers:
To restore original styles: select layers and press "Restore initial style".
In this demo, the tool is used to apply a single legend to series of uniformly indexed raster, that have comparable color tables. During demo it is also used to use single min-max legends for series of USGS dems.
<object width="943" height="576">
<param name="movie" value="/images/qgis-multiqml-01.swf"> <embed src="https://wiki.gis-lab.info/images/qgis-multiqml-01.swf" width="943" height="576"> </embed>
</object>
If you want report a bug or want make suggestion — use bugtracker. Also if you have a question about the script or plugin usage, you can contact us directly.
Последнее обновление: 2014-05-14 23:14
Дата создания: 10.01.2009
Автор(ы): Максим Дубинин
