MapServer First Demo
Xaver
Сообщение Xaver » 01 сен 2011, 07:35
Решил установить MapServer
по этому мануалу. Демо проект скачал отсюда. Положил в свой католог (/home/zaa/workshop-5.4). При запуске демки (нажатие кнопки Initalize) получаю loadWeb(): Unknown identifier. Parsing error near (/home/zaa/workshop-5.4/tmp/):(line 1).
Содержимое файла /etc/apache2/sites-available/default:
<VirtualHost *:80>
	ServerAdmin webmaster@localhost
	ServerName mapserverdemo
	DocumentRoot /home/zaa/workshop-5.4
	<Directory />
		Options FollowSymLinks
		AllowOverride None
	</Directory>
	<Directory /var/www/>
		Options Indexes FollowSymLinks MultiViews
		AllowOverride None
		Order allow,deny
		allow from all
	</Directory>
	ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
	<Directory "/usr/lib/cgi-bin">
		AllowOverride None
		Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
		Order allow,deny
		Allow from all
	</Directory>
	ErrorLog ${APACHE_LOG_DIR}/error.log
	# Possible values include: debug, info, notice, warn, error, crit,
	# alert, emerg.
	LogLevel warn
	CustomLog ${APACHE_LOG_DIR}/access.log combined
	ServerSignature On
    Alias /doc/ "/usr/share/doc/"
    <Directory "/usr/share/doc/">
        Options Indexes MultiViews FollowSymLinks
        AllowOverride None
        Order deny,allow
        Deny from all
        Allow from 127.0.0.0/255.0.0.0 ::1/128
    </Directory>
</VirtualHost>
Содержимое файла index.html в директории /home/zaa/workshop-5.4/
<html>
  <head>
    <title>MapServer Itasca Application</title>
    <script language="javascript">
      function configure() {
			  var template = document.demo.template.options[document.demo.template.selectedIndex].value;
        var snippet = " TEMPLATE " + template;
        document.demo.map_web.value = snippet;
        if(template.indexOf("frame") != -1) document.demo.action = "frames.html";
        if(template.indexOf("dhtml") != -1) document.demo.action = "frames_dhtml.html";
    </script>
  </head>
  <body bgcolor="#FFFFFF">
    <center><h2>MapServer Itasca Application (ms v5.4)</h2></center>
    <p><hr><p>
    This demonstration application will take you through various levels of complexity. Starting with a basic application that
    allows a user to pan/zoom and change layers we add:
    <ul>
      <li> dynamically configured scalebars
      <li> javascript-based panning
      <li> query results to a frame
      <li> and finally, a DHTML rubber-band zoom/query capabilty
    </ul>
    The base data is the old-reliable Itasca dataset that we know and love...
    <form name="demo" method="GET" action="/cgi-bin/mapserv" onSubmit="submit_form()">
      <input type="hidden" name="layer" value="lakespy2">
      <input type="hidden" name="layer" value="dlgstln2">
      <input type="hidden" name="zoomsize" value=2>
      <input type="hidden" name="map_web" value="">
      <input type="hidden" name="map" value="/home/zaa/workshop-5.4/itasca.map">
      <input type="hidden" name="program" value="/cgi-bin/mapserv">
      <input type="hidden" name="root" value="/">
      <input type="hidden" name="map_web_imagepath" value="/home/zaa/workshop-5.4/tmp/">
      <input type="hidden" name="map_web_imageurl" value="/tmp/"
      <select name="template" size="1">
        <option value="itasca_basic.html"> Basic Application
        <option value="itasca_adds_scalebar.html"> &nbsp;&nbsp;-- Adds second scalebar
        <option value="itasca_adds_pan.html"> &nbsp;&nbsp;-- Adds pan controls
        <option value="itasca_adds_frames.html"> &nbsp;&nbsp;-- Adds frames
        <option value="itasca_adds_dhtml.html"> &nbsp;&nbsp;-- Adds dhtml rubber-band box
      </select>
      <input type="submit" value="Initialize"></center>
    </form>
    <p><hr>
    <table width="100%"><tr><td align="right">This site running MapServer v. 5.4</td></tr></table>
  </body>
</html>
