Please help me transfer data from Microstation to MapInfo?
hoangdiep
Сообщение hoangdiep » 01 сен 2011, 04:34
When I moved the map from Microstation to MapInfo by several different methods, but will only move the object space, while the property is lost, anyone can help fill line not to be complete?
I thank you!
Mavka
Re: Please help me transfer data from Microstation to MapInf
Сообщение Mavka » 01 сен 2011, 12:50
Is MapInfo Universal Translator not support all DGN features? As I can see - all is good.
I haven't tested Microstation formats but you can try:
  1. trial version of FME Desktop
  2. console program ogr2ogr (from OSGeo4W):
    ogr2ogr -f "MapInfo File" new_file.tab old_file.dgn
    List of supported attributes
  3. open DGN file in Qunatum GIS and save from menu Layer|Save as... (same as #2 result)
Последний раз редактировалось Mavka 01 сен 2011, 13:32, всего редактировалось 1 раз.
Сообщение Boris » 01 сен 2011, 13:22
The best way to move simple data (no spline or surface or 3D ) from MS to MapInfo is to convert data to DXF and use right projection when transforming data.
It may be an other problem if you use inches in MS but really they are meters.
Дмитрий Барышников
Сообщение Дмитрий Барышников » 01 сен 2011, 13:25
Unfortunately OGR does not support the transfer of attributes. Thus, options 2 and 3 are not suitable. See http://gdal.org/ogr/drv_dgn.html for details.
