Проблема с установкой GeoServer
drebedan
Сообщение drebedan » 12 янв 2011, 07:52
Привет.
Скачал GeoServer 2.0.2, установил (windows 7, jre-6u23), запускаю батник, в окне пишется процесс запуска, но останавливается вот на этом моменте:
12  эт 07:42:25 WARN [grid.GridSetFactory] - GridSet EPSG:26713_sf:roads was def
ined without metersPerUnit. Assuming 1m per SRS unit for WMTS scale output.
12  эт 07:42:25 WARN [grid.GridSetFactory] - GridSet EPSG:26713_sf:streams was d
efined without metersPerUnit. Assuming 1m per SRS unit for WMTS scale output.
12  эт 07:42:25 WARN [grid.GridSetFactory] - GridSet EPSG:26713_sf:sfdem was def
12  эт 07:42:25 WARN [grid.GridSetFactory] - GridSet EPSG:26713_spearfish was de
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding layers from GeoServer
Catalog Listener
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: nurc:Arc_Sample
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: nurc:Pk50095
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: nurc:mosaic
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: nurc:Img_Sample
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: sf:archsites
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: sf:bugsites
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: sf:restricted
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: sf:roads
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: sf:streams
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: sf:sfdem
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: tiger:giant_polygon
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: tiger:poi
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: tiger:poly_landmarks
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: tiger:tiger_roads
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: topp:states
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: topp:tasmania_cities
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: topp:tasmania_roads
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: topp:tasmania_state_b
oundaries
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: topp:tasmania_water_b
odies
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: spearfish
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: tasmania
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding: tiger-ny
12  эт 07:42:25 ERROR [config.XMLConfiguration] - Configuration file cannot be r
ead or does not exist!
12  эт 07:42:25 INFO [config.XMLConfiguration] - Found configuration file in C:\
Program Files\GeoServer 2.0.2\webapps\geoserver\..\resources
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - Adding layers from C:\Program
12  эт 07:42:25 ERROR [layer.TileLayerDispatcher] - Configuration C:\Program Fil
es\GeoServer 2.0.2\webapps\geoserver\..\resources contained no layers.
12  эт 07:42:25 ERROR [layer.TileLayerDispatcher] - Error reading service inform
ation from C:\Program Files\GeoServer 2.0.2\webapps\geoserver\..\resources: Erro
r parsing file C:\Program Files\GeoServer 2.0.2\webapps\geoserver\..\resources\g
eowebcache.xml
12  эт 07:42:25 INFO [layer.TileLayerDispatcher] - ConfigurationLoader completed
http://localhost:8080/ после этого не открывается.
Пробовал переустанавливать GeoServer в другую папку - ничего не меняется.
Помогите, пожалуйста. Что я делаю не так?
drebedan
Re: Проблема с установкой GeoServer
Сообщение drebedan » 12 янв 2011, 08:59
Перепробовал несколько версий GeoServer'a - все ведут себя одинаково :(.
Печально начинать знакомство с продуктом с такого.
drebedan
Сообщение drebedan » 12 янв 2011, 09:45
Проблема решена, фух. Это фаервол блокировал джаву.
Сейчас этот форум просматривают: Ahrefs [Bot] и 0 гостей
