Импорт геометрии (Google maps)
Winsent
Сообщение Winsent » 23 окт 2008, 08:49
Добрый день, возникла следующая проблемма:
Есть набор координат объектов выглядит приблизительно так:
[size=75][color=#400080]50.59476 36.575519
50.594692 36.576026
50.594673 36.576057
50.59465 36.576068
50.594619 36.576061
50.594562 36.575752
50.594528 36.575737
50.594516 36.575801
50.594463 36.575778
50.594432 36.57574
50.594417 36.575683
50.594413 36.575626
50.594417 36.575576
50.594459 36.575588
50.594467 36.575531
50.594341 36.575489
50.594345 36.575462
50.594253 36.575431
50.594078 36.576629
50.594047 36.576618
50.594013 36.576869
50.594242 36.576946
50.594348 36.576229
50.594512 36.576286
50.594528 36.576164
50.594501 36.576156
50.594562 36.575752
50.594619 36.576061
50.594581 36.576313
50.594642 36.576335
50.594474 36.577457
50.5942 36.577362
50.594184 36.577419
50.594154 36.577446
50.594116 36.577453
50.594081 36.577438
50.594055 36.577404
50.594039 36.577362
50.594036 36.577293
50.593875 36.57724
50.593853 36.577308
50.593833 36.577388
50.59383 36.57748
50.593837 36.577575
50.593856 36.57769
50.593795 36.577648
50.593639 36.577568
50.593517 36.577518
50.593521 36.577449
50.593433 36.577423
50.593505 36.576915
50.593483 36.576885
50.593502 36.576732
50.593753 36.57682
50.593746 36.5769
50.593799 36.576919
50.593814 36.576824
50.59386 36.576839
50.593891 36.576602
50.593277 36.576393
50.593288 36.576309
50.593154 36.576267
50.593177 36.576087
50.593097 36.576061
50.593238 36.575058
50.593334 36.575088
50.593357 36.574905
50.593364 36.574909
50.593471 36.574943
50.593479 36.574886
50.59415 36.575122
50.594142 36.575202
50.594097 36.575382
50.593681 36.575225
50.593536 36.576225
50.593952 36.57637
50.594097 36.575382
50.594142 36.575202
50.594356 36.575275
50.594368 36.575229
50.594398 36.575222
50.594455 36.575222
50.594692 36.575305
50.594684 36.575382
50.594711 36.575401
50.594726 36.575435
50.594669 36.575481
50.59465 36.575462
50.594619 36.575447
50.594593 36.575458
50.594562 36.575485
50.594551 36.575534
50.594551 36.575584
50.594566 36.575622
50.594589 36.575649
50.594615 36.575649
50.594642 36.575637
50.594669 36.575603
50.59468 36.575561
50.59468 36.575515
50.594669 36.575481
50.594726 36.575435
50.594734 36.575481
50.594734 36.575511
50.59476 36.575519[/color]
center 50.5939007874263 36.5762163683517[/size]
Проблема состоит в том, чтобы загрузить это каким либо образом в GIS без изменений/искажений. Дело в том, что я не знаю проекцию этого объекта, но подозреваю, что отрисованно по гуглю (900913 (EPSG: 3785)Меркатор на сфере/WGS84).
Где (50.593900, 36.576216) - это координаты в градусах и долях градуса.
При загрузке в MapInfo получаю следующее
а должно быть
Подскажите пожалуйста каким образом перерасчитать координаты или какую проекцию выбрать в MapInfo. Спасибо всем откликнувшимся.
Анна
Re: Импорт геометрии (Google maps)
Сообщение Анна » 23 окт 2008, 13:55
подозреваю, что дело не в проекции.
когда вы загружали точки, вы вероятнее всего сочли, что первый столбец (где 50.ххх) - это долгота, а на самом деле - это широта. И наоброт - там где 36.ххх - это на самом деле долгота, а не широта.
Таким образом, ваши значения при загрузке в гис должны соответствовать следующему порядку:
Latitude (Y!) Longitude (X!)
50.59476 36.575519
50.594692 36.576026
50.594673 36.576057
50.59465 36.576068
и т.д.
Сообщение Максим Дубинин » 24 окт 2008, 01:30
сформулируйте ваш вопрос, пересчитать куда в ту СК в которой у вас объект на второй картинке? Вы знаете какая именно это СК?
