Argos-tools: can't import DIA file(s)
Ciconia
Сообщение Ciconia » 26 июн 2008, 16:54
I've just started working with Argos tools and huge amounts of data supplied by email from ARGOS. They come with a *.txt extension and in the following format:
15258 Date : 01.12.06 12:26:54 LC : Z IQ : 00
Lat1 : ??????? Lon1 : ???????? Lat2 : ??????? Lon2 : ????????
Nb mes : 001 Nb mes>-120dB : 000 Best level : -132 dB
Pass duration :???s NOPC : ?
Calcul freq : 401 650000.0 Hz Altitude : 0 m
00 01 54 55
15258 Date : 02.12.06 10:13:50 LC : Z IQ : 00
Nb mes : 001 Nb mes>-120dB : 000 Best level : -133 dB
03 00 02 21
I want to directly import them. I have tried renaming the files as *.dia This downloads the headings but not the actual data. Can somebody help?
Ciconia
Сообщение Максим Дубинин » 26 июн 2008, 17:46
please attach one of the files or send it by email
Ciconia
Argos tools
Сообщение Ciconia » 27 июн 2008, 11:38
Many thanks for having a look at this. I have attached a file. I receive them as email attachements. They have recently changed the export to *.cvs
STRUYF_ADS_4102_20080417040051_769.CSV
(11.67 КБ) 1213 скачиваний
Сообщение Максим Дубинин » 27 июн 2008, 23:04
I renamed your csv to dia and it worked fine for me. Here is the log file:
d:\programming\avenue\argos\errors\struyf_ads_4102_20080417040051_769.dia
PTT 15258
10 valid point(s)
6 invalid point(s) skipped
PTT 27235
5 valid point(s)
1 invalid point(s) skipped
PTT 27254
5 valid point(s)
8 invalid point(s) skipped
Please show me whats in yours.
Ciconia
Argos-Tools
Сообщение Ciconia » 30 июн 2008, 11:01
Hi
I'm very happy. I moved my data from the server to C drive and now the files import very well.
However, I am forced to run in demo mode (of which there are only 3 days remaining) and a product key is requested. Do I need to purchase the product key?
Also how did you generate the log file - this of course would be very handy. Many thanks for your help :D
Ciconia
Сообщение Максим Дубинин » 30 июн 2008, 19:09
I'm using Argos-tools for Arcview GIS it is way more advance and it is completely free.
To continue using Argos-tools for ArcGIS enter
username: Sim
password: yuuUIBtG6x
Ciconia
Argos -tools
Сообщение Ciconia » 01 июл 2008, 11:04
I have upgraded my version from 0.26 to 0.35 - now everything appears to be working perfectly. I'm still running Arcview 3.1, we are waiting to upgrade to ARCGIS 9 at the end of the year. When this happens is it better at this stage to continue with this work in ArcView 3.1 or shift across to the next platform ?
Ciconia
Сообщение Максим Дубинин » 01 июл 2008, 18:09
I'd recommend to stay in AV3, at least for running this extension. ArcGIS version of it is lagging far behind.
Ciconia
Argos-tools
Сообщение Ciconia » 02 июл 2008, 09:40
thanks for all your help :D
Ciconia
Вернуться в «Материалы сайта»
