Направление (стрелку) движения на линии трека в MapServer.
onfor
Сообщение onfor » 20 фев 2017, 16:14
Здравствуйте.
С огромной помощью сообщества форума у меня есть отлично работающий map-файл, содержимое которого привожу ниже:
MAP
 CONFIG "CPL_DEBUG" "ON"
 CONFIG "PROJ_DEBUG" "ON"
 DEBUG 5
  SIZE		256 256
  IMAGETYPE	PNG
  IMAGECOLOR	235 235 235
  TRANSPARENT	true
  UNITS		METERS
  SYMBOL
    NAME 'circlef'
    TYPE ellipse
    FILLED true
    POINTS
        3 3
    END #POINTS
  END #SYMBOL
SYMBOL
  NAME "arrow"
  TYPE vector
  FILLED true
 POINTS
   0 0
    8 3
    0 6
  0 0
 END
 ANCHORPOINT  0.5 0.5
END
LAYER
        STATUS          DEFAULT
        CONNECTIONTYPE  postgis
        NAME            segments
        VALIDATION
            # 'DATA'   '^[0-9a-zA-Z\-\.\,\'\"\(\)\:\=\>\<\!\_\ ]+$'
            # 'car'   '^[a-zA-Z]+$'
          "car" "^[0-9]+$"
          "speed" "^[0-9]+$"
          "fromd" "^20[0-9]{2}-[0-9]{1,2}-[0-9]{1,2}$"
          "fromt" "^[0-9]{1,2}:[0-9]{1,2}:[0-9]{1,2}$"
          "tod" "^20[0-9]{2}-[0-9]{1,2}-[0-9]{1,2}$"
          "tot" "^[0-9]{1,2}:[0-9]{1,2}:[0-9]{1,2}$"
        END
        CONNECTION "user=________ dbname=__________ host=___________"
# Ваш запрос на рисование полилинии
        DATA "geom from (
          select
            st_makeline(p1, p2) as geom, gid, num, speed
          from
              select
                gid, row_number() over w as num, date_p as ts1, speed, location as p1, lead(location) over w as p2, lead(date_p) over w as ts2
              from
                gps_points
              where
                id_car=%car%
		and date_p>='%fromd% %fromt%'::date
		and date_p<='%tod% %tot%'::date
		window w as (partition by id_car order by date_p)
           ) as query where p2 is not NULL
        ) as foo using unique gid using srid=900913"
        TYPE           LINE
  STATUS ON
  TYPE LINE
CLASS
            EXPRESSION ([speed] < %speed%)
            STYLE
                COLOR 28 130 0
                WIDTH 3
            END
        END
        CLASS
            EXPRESSION ([speed] > %speed%)
            STYLE
                COLOR 219 52 49
                WIDTH 3
            END
        END
      METADATA
       wms_title "world"
       wms_abstract "world test"
       wms_srs "epsg:900913"
       wms_include_items "all"
       "wms_enable_request" "*"
      END #METADATA
    END
LAYER
    VALIDATION
      "car" "^[0-9]+$"
    END
  NAME "path"
  PROCESSING "CLOSE_CONNECTION=DEFER"
  DATA "geom from (select ST_MakeLine(location) as geom, 0 as gid from (select location, gid from gps_points where active = true and id_car=%car% and date_p>='%fromd% %fromt%'::date and date_p<='%tod% %tot%'::date order by date_p asc) as track_data) as foo using unique gid using srid=900913"
  #FILTER "foo.id_car = '%car%'"
  STATUS ON
  TYPE LINE
  CLASS
   STYLE
      #GEOMTRANSFORM "end"
      ANTIALIAS TRUE
      COLOR 55 12 253
      SYMBOL "arrow"
      SIZE 5
      ANGLE AUTO # угол
      #GAP 10	# Расстояние между стрелками
	END # STYLE
  END #CLASS
  METADATA
   wms_title "Track"
   wms_abstract "Map file for track format"
  END #METADATA
 END #LAYER
LAYER
    VALIDATION
      "car" "^[0-9]+$"
    END  NAME "points"
  CONNECTION "user=postgres dbname=mapserver host=localhost"
  DATA "the_geom from (select location as the_geom, speed, gid from gps_points where active = true and id_car=%car% and date_p>='%fromd% %fromt%'::date and date_p<='%tod% %tot%'::date ) as geom using unique gid using srid=900913"
  STATUS ON
  TYPE POINT
  CLASS
   EXPRESSION ([speed] <= 60)
   STYLE
     ANTIALIAS TRUE
     SYMBOL "circlef"
     COLOR 28 93 162
     SIZE 6
     GAP 1
   END #STYLE
  END #CLASS
  CLASS
   EXPRESSION ([speed] > 60)
    STYLE
      ANTIALIAS TRUE
      SYMBOL "circlef"
      COLOR 180 50 50
      SIZE 6
      GAP 1
    END #STYLE
  END #CLASS
  METADATA
   wms_title "world"
  END #METADATA
  CLUSTER
    MAXDISTANCE 10
    REGION "ellipse"
  END
#CLUSTER
#  LABELITEM "Cluster_FeatureCount"
 END #LAYER
  PROJECTION
    "init=epsg:900913"
#    "proj=latlong"
#    "ellps=WGS84"
#    "datum=WGS84"
#    "init=epsg:3857"
  END #PROJECTION
END
Не претендую на 100% правильность файла, но свои задачи он выполняет. Вопрос в том, КАК можно вместе с точками и самим треком нанести стрелки с указанием направления движения.
Были попытки вывести при помощи SYMBOL, но к сожалению, по разным причинам (иногда не совсем понятным для меня) вывод не удавался.
Спасибо заранее!
