Атрибутивная информация векторного слоя
GeoNik
Сообщение GeoNik » 01 мар 2015, 19:12
Здраствуйте. Я нашел пример в котором используют OpenLayer для отображения слоев с Geoserver. И при клике на нем отображается атрибутивная информация об объекте.
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0">
    <meta name="apple-mobile-web-app-capable" content="yes">
    <title>OpenLayers WMS Feature Info Example (GeoServer)</title>
    <script src="http://localhost:8080/geoserver/www/OpenLayers.js"></script>
    <link rel="stylesheet" href="http://localhost:8080/geoserver/www/style1.css" type="text/css">
    <link rel="stylesheet" href="http://localhost:8080/geoserver/www/style.css" type="text/css">
    <script  type="text/javascript">
    function load() {
        var map = new OpenLayers.Map('map');
            var political = new OpenLayers.Layer.WMS("State Boundaries",
            "http://localhost:8080/geoserver/wms",
            {'layers': 'topp:tasmania_state_boundaries', transparent: true, format: 'image/gif'},
            {isBaseLayer: true}
        var roads = new OpenLayers.Layer.WMS("Roads",
            {'layers': 'topp:tasmania_roads', transparent: true, format: 'image/gif'},
            {isBaseLayer: false}
        var water = new OpenLayers.Layer.WMS("Bodies of Water",
            {'layers': 'topp:tasmania_water_bodies', transparent: true, format: 'image/gif'},
	var layer4 = new OpenLayers.Layer.Vector('ДЦ1', {
						strategies: [new OpenLayers.Strategy.Fixed()],
						protocol: new OpenLayers.Protocol.WFS({
							version: '1.1.0',
							url: 'http://localhost:8080/geoserver/IGDG_data/wfs',
							featureType: 'churchu',
							featureNS: 'file:data/',
							extractAttributes: true
		map.addLayers([political, roads, water,layer4]);
        var info1=new OpenLayers.Control.WMSGetFeatureInfo({
                url: 'http://localhost:8080/geoserver/wms',
                //title: 'Identify features by clicking',
                layers: [layer4,political]
                //queryVisible: true
        var infoControls = {
            click:info1
		for (var i in infoControls) {
            infoControls[i].events.register("getfeatureinfo", this, showInfo);
            map.addControl(infoControls[i]);
        infoControls.click.activate();
        map.zoomToMaxExtent();
    function showInfo(evt) {
        document.getElementById('responseText').innerHTML = evt.text;
	</script>
  </head>
  <body onload="load()">
     <div id="responseText">  </div>
     <div id="map" class="smallmap"></div>
  </body>
</html>
У меня есть несколько вопросов:
1.Этот пример работает для WMS слоев. А мне нужно чтобы так же работало для WFS (в коде это layer4). Пересмотрел кучу литературы и ничего не нашел такого чтобы я понял (я только начинаю программировать в JavaScript). Подскажите что изменить чтобы код заработал для layer4?
2.Не полностью понимаю, что делается в следующих строках. Если бы кто-то мог напишите несколько комментов.
            click:info1
А также что делают эти теги
3. Для основной работы я использую фреймворк ExtJs и GeoExt. Там есть Ext.grid.GridPanel. Как мне поместить полученную атрибутику туда?
Заранее спасибо!
