NextGis QGIS
Alex555
NextGis QGIS
Сообщение Alex555 » 19 дек 2014, 07:01
Добрый день.
Подскажите как загрузить выгрузку из openstreetmap.org с расширением xml в программе
выгрузка:
<?xml version="1.0" encoding="UTF-8"?>
<osm version="0.6" generator="CGImap 0.3.3 (14771 thorn-02.openstreetmap.org)" copyright="OpenStreetMap and contributors" attribution="http://www.openstreetmap.org/copyright" license="http://opendatacommons.org/licenses/odbl/1-0/">
 <relation id="79379" visible="true" version="96" changeset="26675017" timestamp="2014-11-09T21:18:20Z" user="Sadless74" uid="85553">
  <member type="way" ref="120024097" role="outer"/>
  <member type="way" ref="61032001" role="outer"/>
  <member type="way" ref="102708498" role="outer"/>
  <member type="way" ref="121304219" role="outer"/>
  <member type="way" ref="64545042" role="outer"/>
  <member type="way" ref="297569170" role="outer"/>
  <member type="way" ref="121304227" role="outer"/>
  <member type="way" ref="60220910" role="outer"/>
  <member type="way" ref="66757873" role="outer"/>
  <member type="way" ref="102708505" role="outer"/>
  <member type="way" ref="66758254" role="outer"/>
  <member type="way" ref="70953167" role="outer"/>
  <member type="way" ref="101202139" role="outer"/>
  <member type="way" ref="261722557" role="outer"/>
  <member type="way" ref="261722559" role="outer"/>
  <member type="way" ref="94899184" role="outer"/>
  <member type="way" ref="101202143" role="outer"/>
  <member type="way" ref="259709141" role="outer"/>
  <member type="way" ref="60220914" role="outer"/>
  <member type="way" ref="55509344" role="outer"/>
  <member type="way" ref="245524586" role="outer"/>
  <member type="way" ref="245524585" role="outer"/>
  <member type="way" ref="245540486" role="outer"/>
  <member type="way" ref="245540489" role="outer"/>
  <member type="way" ref="245468566" role="outer"/>
  <member type="way" ref="245468586" role="outer"/>
  <member type="way" ref="245494059" role="outer"/>
  <member type="way" ref="245524590" role="outer"/>
  <member type="way" ref="245524579" role="outer"/>
  <member type="way" ref="245468549" role="outer"/>
  <member type="way" ref="245468547" role="outer"/>
  <member type="way" ref="61498141" role="outer"/>
  <member type="way" ref="69655717" role="outer"/>
  <member type="way" ref="61588481" role="outer"/>
  <member type="way" ref="68134313" role="outer"/>
  <member type="way" ref="70954276" role="outer"/>
  <member type="way" ref="71880767" role="outer"/>
  <member type="way" ref="89964766" role="outer"/>
  <member type="way" ref="89964776" role="outer"/>
  <member type="way" ref="71881014" role="outer"/>
  <member type="way" ref="68110744" role="outer"/>
  <member type="way" ref="68110767" role="outer"/>
  <member type="way" ref="68134195" role="outer"/>
  <member type="way" ref="70971765" role="outer"/>
  <member type="way" ref="81606478" role="outer"/>
  <member type="way" ref="68134322" role="outer"/>
  <member type="way" ref="68286474" role="outer"/>
  <member type="way" ref="95977562" role="outer"/>
  <member type="way" ref="142675482" role="outer"/>
  <member type="way" ref="142675473" role="outer"/>
  <member type="way" ref="68325031" role="outer"/>
  <member type="way" ref="72312072" role="outer"/>
  <member type="way" ref="89589910" role="outer"/>
  <member type="way" ref="70980805" role="outer"/>
  <member type="way" ref="89589908" role="outer"/>
  <member type="way" ref="68435449" role="outer"/>
  <member type="way" ref="98995971" role="outer"/>
  <member type="way" ref="98995935" role="outer"/>
  <member type="way" ref="98995942" role="outer"/>
  <member type="way" ref="61498142" role="outer"/>
  <member type="way" ref="65968980" role="outer"/>
  <member type="way" ref="150369432" role="outer"/>
  <member type="way" ref="65968990" role="outer"/>
  <member type="way" ref="65968972" role="outer"/>
  <member type="way" ref="72311199" role="outer"/>
  <member type="way" ref="226867948" role="outer"/>
  <member type="way" ref="226867950" role="outer"/>
  <member type="way" ref="65968968" role="outer"/>
  <member type="way" ref="64622168" role="outer"/>
  <member type="way" ref="72310912" role="outer"/>
  <member type="way" ref="103433676" role="outer"/>
  <member type="way" ref="86661835" role="outer"/>
  <member type="way" ref="70278208" role="outer"/>
  <member type="way" ref="311991368" role="outer"/>
  <member type="way" ref="231528544" role="outer"/>
  <member type="way" ref="231528548" role="outer"/>
  <member type="way" ref="64622180" role="outer"/>
  <member type="way" ref="137159410" role="outer"/>
  <member type="way" ref="70967535" role="outer"/>
  <member type="way" ref="133397985" role="outer"/>
  <member type="way" ref="64622176" role="outer"/>
  <member type="way" ref="133397982" role="outer"/>
  <member type="way" ref="311979185" role="outer"/>
  <member type="way" ref="311979180" role="outer"/>
  <member type="way" ref="66723745" role="outer"/>
  <member type="way" ref="311979183" role="outer"/>
  <member type="way" ref="64622164" role="outer"/>
  <member type="way" ref="176225428" role="outer"/>
  <member type="way" ref="176225403" role="outer"/>
  <member type="way" ref="64619685" role="outer"/>
  <member type="way" ref="176225415" role="outer"/>
  <member type="way" ref="176225388" role="outer"/>
  <member type="way" ref="64619693" role="outer"/>
  <member type="way" ref="64619697" role="outer"/>
  <member type="way" ref="137031809" role="outer"/>
  <member type="way" ref="103438463" role="outer"/>
  <member type="way" ref="64619676" role="outer"/>
  <member type="way" ref="176000670" role="outer"/>
  <member type="way" ref="176000645" role="outer"/>
  <member type="way" ref="176000653" role="outer"/>
  <member type="way" ref="64619702" role="outer"/>
  <member type="way" ref="176000623" role="outer"/>
  <member type="way" ref="137032013" role="outer"/>
  <member type="way" ref="64619683" role="outer"/>
  <member type="way" ref="176993512" role="outer"/>
  <member type="way" ref="176993479" role="outer"/>
  <member type="way" ref="176993431" role="outer"/>
  <member type="way" ref="64619687" role="outer"/>
  <member type="way" ref="177020293" role="outer"/>
  <member type="way" ref="64619692" role="outer"/>
  <member type="way" ref="177020299" role="outer"/>
  <member type="way" ref="177020274" role="outer"/>
  <member type="way" ref="64619703" role="outer"/>
  <member type="relation" ref="1289032" role="subarea"/>
  <member type="relation" ref="1240375" role="subarea"/>
  <member type="relation" ref="1297899" role="subarea"/>
  <member type="relation" ref="1240372" role="subarea"/>
  <member type="relation" ref="1297900" role="subarea"/>
  <member type="relation" ref="1288919" role="subarea"/>
  <member type="relation" ref="3360366" role="subarea"/>
  <member type="relation" ref="1111949" role="subarea"/>
  <member type="relation" ref="1110131" role="subarea"/>
  <member type="relation" ref="1110855" role="subarea"/>
  <member type="relation" ref="1288920" role="subarea"/>
  <member type="relation" ref="1110851" role="subarea"/>
  <member type="relation" ref="1110126" role="subarea"/>
  <member type="relation" ref="1074591" role="subarea"/>
  <member type="relation" ref="1067582" role="subarea"/>
  <member type="relation" ref="1468147" role="subarea"/>
  <member type="relation" ref="1016575" role="subarea"/>
  <member type="relation" ref="1298865" role="subarea"/>
  <member type="relation" ref="1298867" role="subarea"/>
  <member type="relation" ref="1298866" role="subarea"/>
  <member type="relation" ref="1374176" role="subarea"/>
  <member type="relation" ref="1317756" role="subarea"/>
  <member type="relation" ref="1305627" role="subarea"/>
  <member type="relation" ref="1291582" role="subarea"/>
  <member type="relation" ref="1305626" role="subarea"/>
  <member type="relation" ref="1305625" role="subarea"/>
  <member type="relation" ref="1046967" role="subarea"/>
  <member type="relation" ref="1059796" role="subarea"/>
  <member type="relation" ref="1305624" role="subarea"/>
  <member type="relation" ref="1291581" role="subarea"/>
  <member type="relation" ref="1104258" role="subarea"/>
  <member type="relation" ref="930932" role="subarea"/>
  <member type="relation" ref="1124099" role="subarea"/>
  <member type="relation" ref="1297876" role="subarea"/>
  <member type="relation" ref="1297877" role="subarea"/>
  <member type="relation" ref="1112110" role="subarea"/>
  <member type="relation" ref="1074090" role="subarea"/>
  <member type="relation" ref="1289095" role="subarea"/>
  <member type="relation" ref="1124064" role="subarea"/>
  <member type="relation" ref="1014789" role="subarea"/>
  <member type="relation" ref="1014788" role="subarea"/>
  <member type="relation" ref="1047000" role="subarea"/>
  <member type="relation" ref="1125463" role="subarea"/>
  <member type="relation" ref="1014778" role="subarea"/>
  <member type="relation" ref="1019865" role="subarea"/>
  <member type="relation" ref="1120630" role="subarea"/>
  <member type="relation" ref="1014759" role="subarea"/>
  <member type="relation" ref="933808" role="subarea"/>
  <member type="relation" ref="1291599" role="subarea"/>
  <member type="relation" ref="1643659" role="subarea"/>
  <member type="relation" ref="1328971" role="subarea"/>
  <member type="relation" ref="1328973" role="subarea"/>
  <member type="relation" ref="1328972" role="subarea"/>
  <member type="relation" ref="1288760" role="subarea"/>
  <member type="relation" ref="1359256" role="subarea"/>
  <member type="relation" ref="1328974" role="subarea"/>
  <member type="relation" ref="1074051" role="subarea"/>
  <member type="relation" ref="1047028" role="subarea"/>
  <member type="relation" ref="1375635" role="subarea"/>
  <member type="relation" ref="1375632" role="subarea"/>
  <member type="relation" ref="1359253" role="subarea"/>
  <member type="relation" ref="1113021" role="subarea"/>
  <member type="relation" ref="1120596" role="subarea"/>
  <member type="relation" ref="1067601" role="subarea"/>
  <member type="relation" ref="1375628" role="subarea"/>
  <member type="relation" ref="1288740" role="subarea"/>
  <member type="relation" ref="1374013" role="subarea"/>
  <member type="relation" ref="1120607" role="subarea"/>
  <member type="relation" ref="1059715" role="subarea"/>
  <member type="relation" ref="1112083" role="subarea"/>
  <member type="relation" ref="1067529" role="subarea"/>
  <member type="relation" ref="1643660" role="subarea"/>
  <member type="relation" ref="1289033" role="subarea"/>
  <member type="node" ref="27503892" role="admin_centre"/>
  <member type="node" ref="535182674" role="label"/>
  <tag k="addr:country" v="RU"/>
  <tag k="admin_level" v="4"/>
  <tag k="border_type" v="region"/>
  <tag k="boundary" v="administrative"/>
  <tag k="cladr:code" v="6600000000000"/>
  <tag k="int_ref" v="RU-SVE"/>
  <tag k="iso3166-2" v="RU-SVE"/>
  <tag k="name" v="Свердловская область"/>
  <tag k="name:de" v="Oblast Swerdlowsk"/>
  <tag k="name:en" v="Sverdlovsk Oblast"/>
  <tag k="name:fr" v="Oblast de Sverdlovsk"/>
  <tag k="name:ru" v="Свердловская область"/>
  <tag k="ref" v="66"/>
  <tag k="timezone" v="Asia/Yekaterinburg"/>
  <tag k="type" v="boundary"/>
  <tag k="wikipedia" v="ru:Свердловская_область"/>
 </relation>
</osm>
Версия последняя 2.6, что для этого нужно.
Порядок действий.
Спасибо всем кто откликнулся.
HasT
Re: NextGis QGIS
Сообщение HasT » 19 дек 2014, 11:38
Если нужно загрузить данные OSM в QGIS, установи плагин Quick OSM. В закладке Quick query выбери Key=name, Value=Свердловская область.
Alex555
Re: NextGis QGIS
Сообщение Alex555 » 19 дек 2014, 12:46
При установки их репозитария, падает с ошибкой. Не может установится.
gimran
Re: NextGis QGIS
Сообщение gimran » 19 дек 2014, 19:02
А какая ошибка?
Alex555
Re: NextGis QGIS
Сообщение Alex555 » 20 дек 2014, 06:53
Установился но появляется ошибка:
The OSM's driver is not installed. You must have GDAL/OGR >= 1.10.
Скрин запросов
NextGIS QGIS.png (163.44 КБ) 7869 просмотров
Дмитрий Барышников
Re: NextGis QGIS
Сообщение Дмитрий Барышников » 20 дек 2014, 17:22
Поставьте develop или future версию. там GDAL более новых версий.
alisovenko
Re: NextGis QGIS
Сообщение alisovenko » 23 дек 2014, 15:08
На сайте nextgis.ru обновился дистрибутив NextGIS QGIS NextGIS QGIS Installer Version 2.6.1.18 (32 bit).
В предыдущей версии использовался пакет gdal-python версии 1.9, поэтому плагин Quick OSM ругался на старый GDAL.
В дистрибутиве NextGIS QGIS версии 2.6.1.18 пакет gdal-python обновлен и плагин Quick OSM работает.
Попробуйте еще раз с новой версией NextGIS QGIS.
Сейчас этот форум просматривают: Semrush [Bot] и 8 гостей
