открыты данные НАСА по осадкам и другим погодным явлениям
Ваше звание: хрюкало
Сообщение nadiopt » 01 окт 2014, 19:54
выложены в свободный доступ данные об осадках.
The most accurate and comprehensive collection of rain, snowfall and other types of precipitation data ever assembled now is available to the public. This new resource for climate studies, weather forecasting, and other applications is based on observations by the Global Precipitation Measurement (GPM) Core Observatory, a joint mission of NASA and the Japan Aerospace Exploration Agency (JAXA), with contributions from a constellation of international partner satellites.
The GPM Core Observatory, launched from Japan on Feb. 27, carries two advanced instruments to measure rainfall, snowfall, ice and other precipitation. The advanced and precise data from the GPM Core Observatory are used to unify and standardize precipitation observations from other constellation satellites to produce the GPM mission data. These data are freely available through NASA's Precipitation Processing System at Goddard Space Flight Center in Greenbelt, Maryland.
общая страница скачки здесь: http://pmm.nasa.gov/data-access. я пока не разобралась тут
Вернуться в «Данные»
