Википедия гислаба и логин
gimran
Сообщение gimran » 02 сен 2014, 05:50
Пытался создать статью. В итоге выходит при попытке логина:
Unexpected non-MediaWiki exception encountered, of type "Exception"
exception 'Exception' with message 'There was a problem when connecting to the phpBB database.<br />Check your Host, Username, and Password settings.<br /><br />MySQL Error Number: 0<br />MySQL Error Message: <br /><br />' in /usr/local/www/gis-lab/data/wiki/extensions/Auth_phpBB.php:699
Stack trace:
#0 /usr/local/www/gis-lab/data/wiki/extensions/Auth_phpBB.php(428): Auth_phpBB->mySQLError('There was a pro...')
#1 /usr/local/www/gis-lab/data/wiki/extensions/Auth_phpBB.php(491): Auth_phpBB->connect()
#2 /usr/local/www/gis-lab/data/wiki/includes/User.php(664): Auth_phpBB->getCanonicalName('Gimran')
#3 /usr/local/www/gis-lab/data/wiki/includes/User.php(343): User::getCanonicalName('gimran', 'valid')
#4 /usr/local/www/gis-lab/data/wiki/includes/specials/SpecialUserlogin.php(411): User::newFromName('gimran')
#5 /usr/local/www/gis-lab/data/wiki/includes/specials/SpecialUserlogin.php(520): LoginForm->authenticateUserData()
#6 /usr/local/www/gis-lab/data/wiki/includes/specials/SpecialUserlogin.php(103): LoginForm->processLogin()
#7 /usr/local/www/gis-lab/data/wiki/includes/specials/SpecialUserlogin.php(17): LoginForm->execute()
#8 [internal function]: wfSpecialUserlogin(NULL, Object(SpecialPage))
#9 /usr/local/www/gis-lab/data/wiki/includes/SpecialPage.php(749): call_user_func('wfSpecialUserlo...', NULL, Object(SpecialPage))
#10 /usr/local/www/gis-lab/data/wiki/includes/SpecialPage.php(539): SpecialPage->execute(NULL)
#11 /usr/local/www/gis-lab/data/wiki/includes/Wiki.php(226): SpecialPage::executePath(Object(Title))
#12 /usr/local/www/gis-lab/data/wiki/includes/Wiki.php(59): MediaWiki->initializeSpecialCases(Object(Title), Object(OutputPage), Object(WebRequest))
#13 /usr/local/www/gis-lab/data/wiki/index.php(114): MediaWiki->initialize(Object(Title), NULL, Object(OutputPage), Object(User), Object(WebRequest))
#14 {main}
Natalia Novoselova
Ваше звание: Лиса
Re: Википедия гислаба и логин
Сообщение Natalia Novoselova » 08 сен 2014, 20:21
gimran писал(а):Пытался создать статью. В итоге выходит при попытке логина:
Может, сделали что-то не так и нашли случайную ошибку?
1.Входите - Представиться системе (прав-верх угол), логинитесь.
2. Ниже (прав-верх угол) слева от копки "Перейти" вбиваете название вашей новой статьи, жмете "Перейти"
3. Программа выдает:
Соответствий запросу не найдено.
Создать страницу «Test ARTICLE» в этом вики-проекте!
4. Жмете на название вашей статьи и она создается отдельной страницей.
