источник новости http://landsat.usgs.gov/mission_headlines2014.php
January 29, 2014 – Landsat 8 Reprocessing to Begin February 3, 2014
On February 3, 2014, the entire Landsat 8 archive will be cleared from the online cache and reprocessed to take advantage of calibration improvements identified during its first year of operation. All Landsat 8 scenes will be removed from the online cache at this time and these data will be reprocessed starting with the most recent acquisitions and proceeding back to the beginning of the mission. Data will then become available for download. Scenes waiting to be reprocessed will also be available for on-demand product orders. Reprocessing is expected to take approximately 50 days.
A summary of the changes being made to the Landsat 8 Operational Land Imager (OLI) and Thermal Infrared Sensor (TIRS) data include:
All OLI bands (excluding cirrus Band 9) will have reflectance changes of up to 0.8 percent. (This can be compared to about a two (2) data value maximum change of Landsat 5-7 8-bit data). Visible striping may currently exist due to the improved sensitivity of OLI in dark uniform areas, such as water. This striping is reduced with this update. Changes to the cirrus Band 9 are more substantial, at about 7 percent.
The TIRS temperature offset noted on November 14, 2013 Calibration Notice on http://landsat.usgs.gov/calibration_notices.php is a primary driver for this reprocessing effort. These offsets remove about 2.1 K from Band 10 and about 4.4 K from Band 11, relative to products processed prior to February 3, 2014. Users should work with TIRS Band 10 data as a single spectral band (like Landsat 7 Enhanced Thematic Mapper Plus (ETM+) and should not use Band 11 by itself or attempt a split-window correction using both TIRS Bands 10 and 11.)
More details about the changes being made to these data are available in the January 29, 2014 Calibration Notice on http://landsat.usgs.gov/calibration_notices.php.
Most users will not need to reorder data currently in their local archive; however, users are encouraged to review all Landsat 8 calibration notices (website above) and evaluate the improvements as they relate to specific applications.
Pilot
- rhot
- Ваше звание: доктор
Re: Данные Landsat
Ну вот, теперь надо успеть качнуть ландсат 8 за 3 дня или ждать 2 месяца.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 32 гостя
