WMS публичной кадастровой карты в GeoExt
Филиппов Владислав
Ваше звание: Геннадич
Сообщение Филиппов Владислав » 20 май 2013, 10:44
Не получается добавить WMS публичной кадастровой карты в GeoExt
вот валидный URL - http://maps.rosreestr.ru/ArcGIS/service ... /WMSServer, где и версия сервиса есть и Name и Title слоёв и ещё куча всего
 * Add all your dependencies here.
 * @require widgets/Viewer.js
 * @require plugins/LayerTree.js
 * @require plugins/OLSource.js
 * @require plugins/OSMSource.js
 * @require plugins/WMSCSource.js
 * @require plugins/WMSSource.js
 * @require plugins/BingSource.js
 * @require plugins/GoogleSource.js
 * @require plugins/ZoomToExtent.js
 * @require plugins/NavigationHistory.js
 * @require plugins/Zoom.js
 * @require plugins/AddLayers.js
 * @require plugins/RemoveLayer.js
 * @require RowExpander.js
 * @require plugins/WMSGetFeatureInfo.js
 * @require plugins/FeatureManager.js
 * @require plugins/FeatureEditor.js
 * @require plugins/FeatureGrid.js
 * @require plugins/DrawBox.js
 * @require plugins/BoxInfo.js
var app = new gxp.Viewer({
    portalConfig: {
        layout: "border",
        region: "center",
        // by configuring items here, we don't need to configure portalItems
        // and save a wrapping container
        items: [{
            xtype: "panel",
            layout: "fit",
            region: "center",
            border: false,
            items: ["mymap"]
            xtype: "container",
            layout: "fit",
            region: "west",
            width: 200
			xtype: "container",
			layout: "fit",
			region: "south",
			border: false,
			height: 200
            xtype: "container",
            layout: "fit",
            region: "south",
            height: 100
        bbar: {id: "mybbar"}
    // configuration of all tool plugins for this application
    tools: [{
        ptype: "gxp_layertree",
        outputConfig: {
            border: true,
            tbar: [] // we will add buttons to "tree.bbar" later
        outputTarget: "westpanel"
        ptype: "gxp_addlayers",
        actionTarget: "tree.tbar"
        ptype: "gxp_removelayer",
        actionTarget: ["tree.tbar", "tree.contextMenu"]
        ptype: "gxp_zoomtoextent",
        actionTarget: "map.tbar"
        ptype: "gxp_zoom",
        ptype: "gxp_navigationhistory",
		ptype: "gxp_wmsgetfeatureinfo",
		featureManager: "states_manager",
		outputConfig: {
			width: 700
		actionTarget: {
			target: "map.tbar",
			index: 1
		ptype: "gxp_featuremanager",
		paging: false,
		autoLoadFeatures: true,
		layer: {
			source: "local",
		ptype: "gxp_featureeditor",
		autoLoadFeature: true
		ptype: "gxp_featuregrid",
		outputConfig: {
			loadMask: true
		outputTarget: "south"
        ptype: "myapp_drawbox",
        ptype: "myapp_boxinfo",
		boxTool: "drawbox",
        outputTarget: "southpanel"
    // layer sources
    sources: {
        local: {
            ptype: "gxp_wmscsource",
            url: "/geoserver/wms",
            version: "1.1.1"
        osm: {
            ptype: "gxp_osmsource"
		rosreestr: {
            ptype: "gxp_wmssource",
            url: "http://maps.rosreestr.ru/arcgis/services/CadastreNew/CadastreWMS/MapServer/WMSServer?service=WMS"
			//version: "1.3.0"
			//,srs: "EPSG:3857"
		"bing": {
			ptype: "gxp_bingsource"
		"google": {
			ptype: "gxp_googlesource"
    // map and layers
    map: {
        id: "mymap", // id needed to reference map in portalConfig above
        title: "Map",
        projection: "EPSG:3857",
        center: [4187314.9432233, 7447312.6747233],
        zoom: 17,
        layers: [{
            source: "osm",
            group: "background"
            source: "bing",
			title: "Bing Map",
            group: "background"
            source: "google",
            group: "background"
			source: "rosreestr",
            group: "background"
            source: "local",
            selected: true,
			visibility: true
            source: "local",
			visibility: true
            source: "local",
			visibility: true
            source: "local",
			visibility: false
            source: "local",
			visibility: false
            source: "local",
			visibility: false
            source: "local",
			visibility: true
        items: [{
            xtype: "gx_zoomslider",
            vertical: true,
            height: 100
но в FireBug я вижу вот что:
Non-existing source 'rosreestr' referenced in layer config.
Такой же результат на домашней машине (Ubuntu). Используется последняя версия OpenGeo Suite 3.0.2
что я не то делаю?
Филиппов Владислав
Re: WMS публичной кадастровой карты в GeoExt
Сообщение Филиппов Владислав » 09 июн 2013, 15:56
решено.
нужно такие ресурсы подключать через OLSource.js, а не WMSSource.js
