GeoServer problems with russian
mihkelo
Сообщение mihkelo » 08 мар 2013, 16:58
Hi,
hopefully You don't mind I write in (bad) english. I'm from Estonia, learned russian over 12 years and unfortunately not speak it at all. Well, let it be...
I hope, that someone have run into weird problems related with russian letters and GeoServer. I tried to set up WMS services with GeoServer on top of database (PostGIS) where all field names and values are in cyrillic. Everything seems to work, but when I try to create CQL filters from OpenLayers in russian, then it do not work.
For example
CQL_FILTER=myfield='тому'
works well, but
CQL_FITLER=тому='myvalue'
don't.
WMS gives following error:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
  <!DOCTYPE ServiceExceptionReport SYSTEM ...>
    <ServiceExceptionReport version="1.1.1" >
      <ServiceException>Could not parse CQL filter list. Lexical error at line 1, column 1.  Encountered: "\u0442" (1090), after : "" Parsing : ????=1.
      </ServiceException>
    </ServiceExceptionReport>
Also, WFS do not work with filters:
<ows:ExceptionReport xmlns:ows=...>
  <ows:Exception exceptionCode="NoApplicableCode">
    <ows:ExceptionText>java.lang.RuntimeException: Failed to get property:{http://www.opengis.net/wfs/2.0}boundedBy Failed to get property: {http://www.opengis.net/wfs/2.0}boundedBy java.io.IOException null ERROR: column "    " does not exist Position: 80
    </ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
Weird is that with combination GeoServer 2.2.2 in Windows, WFS do not work at all with cyrillic fieldnames, but with version 2.1.3 in Debian, WFS works (without filters). Also, If filters are OGC filters (posted xml), it works.
Is anybody run into this behavior? Any help or quidelines are more than appreciated.
Mihkel
GIS developer from Estonia.
Re: GeoServer problems with russian
Сообщение Максим Дубинин » 08 мар 2013, 20:39
how about not using fieldnames in cyrillic, this is universally a bad idea
mihkelo
Сообщение mihkelo » 11 мар 2013, 12:53
Well, I am agree, but it's not up to me. Spatial data comes from client and it is entirely in russian. Also one requirement is filtering from UI, and there would be nice to have field names and values both in cyrillic. Of cource, if there is no other reasonable solution, I need to rename all field names in database. But this will be my last solution.
