Не устанавливается RGdal
SBoris
Сообщение SBoris » 16 сен 2012, 12:05
Здравствуйте.
Возникла проблема, после установки GRASS и R пробую установить RGdal и через меню и как описано в http://gis-lab.info/qa/rgdal.html с коммандной строки - результат одинаковый:
R version 2.15.1 (2012-06-22) -- "Roasted Marshmallows"
Copyright (C) 2012 The R Foundation for Statistical Computing
ISBN 3-900051-07-0
Platform: x86_64-pc-linux-gnu (64-bit)
R is free software and comes with ABSOLUTELY NO WARRANTY.
You are welcome to redistribute it under certain conditions.
Type 'license()' or 'licence()' for distribution details.
  Natural language support but running in an English locale
R is a collaborative project with many contributors.
Type 'contributors()' for more information and
'citation()' on how to cite R or R packages in publications.
Type 'demo()' for some demos, 'help()' for on-line help, or
'help.start()' for an HTML browser interface to help.
Type 'q()' to quit R.
[Workspace loaded from ~/.RData]
> install.packages("rgdal")
Installing package(s) into ‘/home/boris/R/x86_64-pc-linux-gnu-library/2.15’
(as ‘lib’ is unspecified)
trying URL 'http://ftp5.gwdg.de/pub/misc/cran/src/contrib/rgdal_0.7-18.tar.gz'
Content type 'application/x-gzip' length 1433864 bytes (1.4 Mb)
opened URL
downloaded 1.4 Mb
* installing *source* package ‘rgdal’ ...
** package ‘rgdal’ successfully unpacked and MD5 sums checked
configure: gdal-config: gdal-config
checking gdal-config usability...
./configure: line 2058: gdal-config: command not found
no
Error: gdal-config not found
The gdal-config script distributed with GDAL could not be found.
If you have not installed the GDAL libraries, you can
download the source from  http://www.gdal.org/
If you have installed the GDAL libraries, then make sure that
gdal-config is in your path. Try typing gdal-config at a
shell prompt and see if it runs. If not, use:
 --configure-args='--with-gdal-config=/usr/local/bin/gdal-config'
with appropriate values for your installation.
ERROR: configuration failed for package ‘rgdal’
* removing ‘/home/boris/R/x86_64-pc-linux-gnu-library/2.15/rgdal’
Warning in install.packages :
  installation of package ‘rgdal’ had non-zero exit status
The downloaded source packages are in
        ‘/tmp/RtmpF2b0EU/downloaded_packages’
и для коммандной строки:
utils:::menuInstallPkgs()
Error in get(name, envir = asNamespace(pkg), inherits = FALSE) :
  object 'menuInstallPkgs' not found
В чём может быть проблема?
В линуксе недавно. Debian wheezy. Gnome.
rhot
Ваше звание: доктор
Re: Не устанавливается RGdal
Сообщение rhot » 16 сен 2012, 12:16
Вот же ответ:
Сообщение Александр Мурый » 16 сен 2012, 12:22
SBoris писал(а):В чём может быть проблема?
В том, что вы невнимательно читаете сообщения об ошибках :)
Установите пакеты gdal-bin и libgdal-dev.
SBoris
Сообщение SBoris » 16 сен 2012, 13:12
Спасибо за ответ! :) rhot & amury
rhot писал(а):Вот же ответ:
Ну, это я читал. Дело в том, что Synaptic показывал что у меня gdal-bin 1.9.0-3+b1 имеется.- "GDAL is a translator library for raster geospatial data formats". Или это не то же самое?
Вот с коммандной
wiki.americaview.org/display/miview/Introduction+to+GDAL
sudo apt-get install gdal-bin
sudo apt-get install python-gdal
Попробовал...
shell prompt and see if it runs...
boris@Castle:~/FWTools-2.0.6$ gdal-config
Usage: gdal-config [OPTIONS]
Options:
	[--prefix[=DIR]]
	[--libs]
	[--dep-libs]
	[--cflags]
	[--datadir]
	[--version]
	[--ogr-enabled]
	[--formats]
То есть он стоит. А как заставить его работать? :?:
После доустановки библиотеки lib... появилось:
configure: error: proj_api.h not found in standard or given locations.
После открытия темы, я пошерстил нэт и нашел, что можна установить FWTools on Linux fwtools.maptools.org/linux-main.html
Теоретически GDAL должен был встать, после такой установки. Но, увы, тоже самое.
SBoris
Сообщение SBoris » 16 сен 2012, 13:27
Нашел, что надо доставить libproj-dev. Ставлю.
Спасибо! Есть контакт.
* DONE (rgdal)
Вернуться в «R»
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 30 гостей
