OpenLayers WMS+разные подложки
Malig
Сообщение Malig » 04 сен 2012, 11:40
Создал WMS на MS4W 3.0.6 на локальной машине.
MAP
        NAME           "WMS"
        STATUS         ON
        IMAGETYPE      PNG
        EXTENT         37.6825 44.3103 40.6413 55.5705
        SIZE 800 2048
        UNITS DD
        IMAGECOLOR     255 255 255
    FONTSET "./fonts/fonts.list"
        WEB
            TEMPLATE  './templates/template.html'
            IMAGEPATH '/ms4w/tmp/ms_tmp/'
            IMAGEURL  '/ms_tmp/'
            METADATA
                    wms_enable_request "*"
                    wms_title                  "GIS-LAB Demo"
                    wms_abstract               "This is the WMS demo from GIS-Lab"
                    wms_onlineresource         "http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/example/wms - mezhuzl.map&"
                    wms_srs                    "EPSG:4326"
                    wms_getfeatureinfo         "http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/example/wms - mezhuzl.map&"
                    wms_featureinfoformat      "text/plain"
            END
        END
        PROJECTION
        "proj=latlong"
        "ellps=WGS84"
        "datum=WGS84"
        END
        LAYER
                NAME         veget
                CONNECTIONTYPE postgis
                CONNECTION "user=postgres password=123 dbname=postgis host=localhost"
                DATA "the_geom from roadmezhuzl"
                STATUS       ON
                TYPE         LINE
                PROJECTION
                    "proj=latlong"
                    "ellps=WGS84"
                    "datum=WGS84"
                END
                CLASS
                    NAME       "Ось дороги"
                    STYLE
                        COLOR        5 115 253
                        OUTLINECOLOR 32 32 32
                    END
                END
                METADATA
                    wms_title         "Countries 1"
                    wms_abstract      "Countries 1 test"
                    wms_srs           "EPSG:4326"
                    wms_include_items "all"
                END
        END # Конец определения слоя
END # Конец определения карты
В браузере по ссылке http://localhost/cgi-bin/mapserv.exe?ma ... t&mode=map работает. В Quantum GIS подключаю слой WMS - работает.
Подключаю через OpenLayers
var map, select;
var lat=60;
var lon=80;
var zoom = 5;
function init(){
    var OSM_map = new OpenLayers.Layer.OSM("OpenStreetMap");
    var gmap = new OpenLayers.Layer.Google("Google Streets", {visibility: false});
    var Y_map = new OpenLayers.Layer.Yandex("Yndex",{sphericalMercator: true, visibility: false});
    var wms = new OpenLayers.Layer.WMS("Layer", "http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/example/wms - mezhuzl.map&",
            {transparent: 'true', layers: 'veget', format: 'png'},
            {isBaseLayer:false});
    var mapoptions = {
        projection: "EPSG:900913",
        units: "m",
        numZoomLevels:18,
        maxResolution: 156543.0339,
        maxExtent: new OpenLayers.Bounds(-128 * 156543.0339, -128 * 156543.0339, 128 * 156543.0339, 128 * 156543.0339)
    map = new OpenLayers.Map("map", mapoptions);
    map.addLayers([OSM_map, gmap, Y_map, wms]);
    var lonLat = new OpenLayers.LonLat(lon, lat).transform(new OpenLayers.Projection("EPSG:4326"), new OpenLayers.Projection("EPSG:900913"));
    map.setCenter (lonLat, zoom);
    map.addControl(new OpenLayers.Control.LayerSwitcher());
Подложки отображаются. А WMS заливает красным. Предполагаю что дело Bounds и проекциях, но совершенно не понимаю какие задавать.
Re: OpenLayers WMS+разные подложки
Сообщение Denis Rykov » 04 сен 2012, 14:04
Тут всё понятно. Ваш WMS настроен таким образом, что может отдавать данные только в EPSG:4326, а судя по клиентскому коду OL, запрос уходит на сервер с указанием проекции EPSG:900913. Добавьте поддержку нужной проекции на сервере и всё должно заработать. Чтобы в следующий раз не гадать в чём причина ошибки - посмотрите в фаербаге URL запроса, уходящего к WMS, вставьте его в адресную строку браузера и перейдите, если на сервере произойдёт ошибка - он вернёт вам XML-документ, который нужно сохранить и затем открыть в текстовом редакторе и прочитать сообщение об ошибке.
Malig
Сообщение Malig » 05 сен 2012, 05:50
Добавил в map-файл
wms_srs                    "EPSG:4326 epsg:900913"
Результат тотже, но ошибка изменилась:
msProcessProjection(): Projection library error. no options found in 'init' file
Malig
Сообщение Malig » 05 сен 2012, 07:32
Проблему решил
Нужно в 'C:\ms4w\proj\nad'. В файлах - epsg, esri, esri.extra прописать первой строкой:
    #  google mercator
     <900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext  +no_defs <>
Я так пытался делать, но для скачивания предлагался файл с расширением exe, это меня почему то смущало, и уж никак я не мог догадаться, что это xml и открыть его в редакторе:)
Спасибо Denis Rykov , вопрос решен!
