Как определить полигон, которому принадлежит точка x,y
Tereha
Сообщение Tereha » 14 июн 2012, 10:43
Уважаемые Гуру!
Если не сложно, где можно посмотреть - как определить какому полигону принадлежит точка с координатами x,y?
(arcgis engine 2010, c#+ vs 2010)
Tereha
Re: Как определить полигон, которому принадлежит точка x,y
Сообщение Tereha » 14 июн 2012, 11:54
Спасибо, огромное!
///<summary>Finds all the features in a GeoFeature layer by supplying a point. The point could come from a mouse click on the map.</summary>
///<param name="searchTolerance">A System.Double that is the number of map units to search. Example: 25</param>
///<param name="point">An IPoint interface in map units where the user clicked on the map</param>
///<param name="geoFeatureLayer">An ILayer interface to search upon</param>
///<param name="activeView">An IActiveView interface</param>
///<returns>An IFeatureCursor interface is returned containing all the selected features found in the GeoFeatureLayer.</returns>
///<remarks></remarks>
public ESRI.ArcGIS.Geodatabase.IFeatureCursor GetAllFeaturesFromPointSearchInGeoFeatureLayer(System.Double searchTolerance, ESRI.ArcGIS.Geometry.IPoint point, ESRI.ArcGIS.Carto.IGeoFeatureLayer geoFeatureLayer, ESRI.ArcGIS.Carto.IActiveView activeView)
  if (searchTolerance < 0 || point == null || geoFeatureLayer == null || activeView == null)
    return null;
  ESRI.ArcGIS.Carto.IMap map = activeView.FocusMap;
  // Expand the points envelope to give better search results
  ESRI.ArcGIS.Geometry.IEnvelope envelope = point.Envelope;
  envelope.Expand(searchTolerance, searchTolerance, false);
  ESRI.ArcGIS.Geodatabase.IFeatureClass featureClass = geoFeatureLayer.FeatureClass;
  System.String shapeFieldName = featureClass.ShapeFieldName;
  // Create a new spatial filter and use the new envelope as the geometry
  ESRI.ArcGIS.Geodatabase.ISpatialFilter spatialFilter = new ESRI.ArcGIS.Geodatabase.SpatialFilterClass();
  spatialFilter.Geometry = envelope;
  spatialFilter.SpatialRel = ESRI.ArcGIS.Geodatabase.esriSpatialRelEnum.esriSpatialRelEnvelopeIntersects;
  spatialFilter.set_OutputSpatialReference(shapeFieldName, map.SpatialReference);
  spatialFilter.GeometryField = shapeFieldName;
  // Do the search
  ESRI.ArcGIS.Geodatabase.IFeatureCursor featureCursor = featureClass.Search(spatialFilter, false);
  return featureCursor;
