проблемы установки geowebcache
s_r_b
Сообщение s_r_b » 20 мар 2012, 10:59
Привет. Не могу настроить geowebcache. Установил tomcat на порт 8090. Работает. Залил через Tomcat Manager geowebcache(файл - .war). Далее перехожу на страницу с geowebcache - http://localhost:8090/geowebcache/home выкидывает ошибку:
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: Servlet.init() for servlet geowebcache threw exception
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:602)
org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
java.lang.Thread.run(Unknown Source)
root cause
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcTLDispatcher' defined in ServletContext resource [/WEB-INF/geowebcache-core-context.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geowebcache.layer.TileLayerDispatcher]: Constructor threw exception; nested exception is com.thoughtworks.xstream.converters.ConversionException: Cannot construct org.geowebcache.grid.SRS as it does not have a no-args constructor : Cannot construct org.geowebcache.grid.SRS as it does not have a no-args constructor
---- Debugging information ----
message : Cannot construct org.geowebcache.grid.SRS as it does not have a no-args constructor
cause-exception : com.thoughtworks.xstream.converters.reflection.ObjectAccessException
cause-message : Cannot construct org.geowebcache.grid.SRS as it does not have a no-args constructor
class : org.geowebcache.config.GeoWebCacheConfiguration
required-type : org.geowebcache.grid.SRS
org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:254)
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
java.security.AccessController.doPrivileged(Native Method)....................
Смотрел лог
мар 20, 2012 12:21:27 AM org.apache.coyote.http11.Http11Protocol pause
INFO: Pausing Coyote HTTP/1.1 on http-8090
мар 20, 2012 12:21:28 AM org.apache.catalina.core.StandardService stop
INFO: Stopping service Catalina
мар 20, 2012 12:21:35 AM org.apache.coyote.http11.Http11Protocol destroy
INFO: Stopping Coyote HTTP/1.1 on http-8090
мар 20, 2012 9:04:40 AM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Apache Software Foundation\Tomcat 6.0\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:\Program Files\PC Connectivity Solution\;C:\Program Files\Embarcadero\RAD Studio\7.0\bin;C:\Users\Public\Documents\RAD Studio\7.0\Bpl;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\ATI Technologies\ATI.ACE\Core-Static;X:\home\uchastok26.rf\yii\framework;D:\COD\DENWER\usr\local\php5;C:\Program Files\PostgreSQL\9.1\bin;;.
мар 20, 2012 9:04:44 AM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8090
мар 20, 2012 9:04:44 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 5737 ms
мар 20, 2012 9:04:44 AM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
мар 20, 2012 9:04:44 AM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.35
мар 20, 2012 9:04:44 AM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor manager.xml
мар 20, 2012 9:04:46 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive geowebcache.war
мар 20, 2012 9:05:04 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory docs
INFO: Deploying web application directory ROOT
мар 20, 2012 9:05:04 AM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8090
мар 20, 2012 9:05:05 AM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
мар 20, 2012 9:05:05 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/422 config=null
мар 20, 2012 9:05:05 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 21247 ms
мар 20, 2012 9:17:30 AM org.apache.coyote.http11.Http11Protocol pause
мар 20, 2012 9:17:31 AM org.apache.catalina.core.StandardService stop
мар 20, 2012 9:17:32 AM org.apache.coyote.http11.Http11Protocol destroy
мар 20, 2012 11:44:34 AM org.apache.catalina.core.AprLifecycleListener init
мар 20, 2012 11:44:42 AM org.apache.coyote.http11.Http11Protocol init
мар 20, 2012 11:44:42 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 15058 ms
мар 20, 2012 11:44:42 AM org.apache.catalina.core.StandardService start
мар 20, 2012 11:44:42 AM org.apache.catalina.core.StandardEngine start
мар 20, 2012 11:44:42 AM org.apache.catalina.startup.HostConfig deployDescriptor
мар 20, 2012 11:44:44 AM org.apache.catalina.startup.HostConfig deployWAR
мар 20, 2012 11:45:12 AM org.apache.catalina.startup.HostConfig deployDirectory
мар 20, 2012 11:45:13 AM org.apache.coyote.http11.Http11Protocol start
мар 20, 2012 11:45:13 AM org.apache.jk.common.ChannelSocket init
мар 20, 2012 11:45:13 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/219 config=null
мар 20, 2012 11:45:13 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 31185 ms
Сам не могу разобраться. Жду советов
