Проблемы с привязкой геотиффов к геосерверу.
special K
Сообщение special K » 28 апр 2011, 21:45
Вот тифф http://narod.ru/disk/11405782001/100k-- ... c.tif.html
{0:27}[ruby-1.9.2]special-k:~➜ listgeo 100k--n40-029_merc.tif
Geotiff_Information:
   Version: 1
   Key_Revision: 1.0
   Tagged_Information:
      ModelTiepointTag (2,3):
         0                0                0
         6231740.42       7429094.9        0
      ModelPixelScaleTag (1,3):
         21.1389329       21.1389329       0
      End_Of_Tags.
   Keyed_Information:
      GTModelTypeGeoKey (Short,1): ModelTypeProjected
      GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
      GTCitationGeoKey (Ascii,28): "Google Maps Global Mercator"
      GeographicTypeGeoKey (Short,1): GCS_WGS_84
      GeogCitationGeoKey (Ascii,7): "WGS 84"
      GeogAngularUnitsGeoKey (Short,1): Angular_Degree
      GeogSemiMajorAxisGeoKey (Double,1): 6378137
      GeogInvFlatteningGeoKey (Double,1): 298.257224
      ProjectedCSTypeGeoKey (Short,1): User-Defined
      ProjectionGeoKey (Short,1): User-Defined
      ProjCoordTransGeoKey (Short,1): CT_Mercator
      ProjLinearUnitsGeoKey (Short,1): Linear_Meter
      ProjNatOriginLongGeoKey (Double,1): 0
      ProjNatOriginLatGeoKey (Double,1): 0
      ProjFalseEastingGeoKey (Double,1): 0
      ProjFalseNorthingGeoKey (Double,1): 0
      ProjScaleAtNatOriginGeoKey (Double,1): 1
      End_Of_Keys.
   End_Of_Geotiff.
Projection Method: CT_Mercator
   ProjNatOriginLatGeoKey: 0.000000 (  0d 0' 0.00"N)
   ProjNatOriginLongGeoKey: 0.000000 (  0d 0' 0.00"E)
   ProjScaleAtNatOriginGeoKey: 1.000000
   ProjFalseEastingGeoKey: 0.000000 m
   ProjFalseNorthingGeoKey: 0.000000 m
GCS: 4326/WGS 84
Datum: 6326/World Geodetic System 1984
Ellipsoid: 7030/WGS 84 (6378137.00,6356752.31)
Prime Meridian: 8901/Greenwich (0.000000/  0d 0' 0.00"E)
Projection Linear Units: 9001/metre (1.000000m)
Corner Coordinates:
Upper Left    ( 6231740.416, 7429094.899)  ( 55d58'50.44"E, 55d31'28.45"N)
Lower Left    ( 6231740.416, 7359991.727)  ( 55d58'50.44"E, 55d10'15.02"N)
Upper Right   ( 6291711.569, 7429094.899)  ( 56d31' 9.86"E, 55d31'28.45"N)
Lower Right   ( 6291711.569, 7359991.727)  ( 56d31' 9.86"E, 55d10'15.02"N)
Center        ( 6261725.992, 7394543.313)  ( 56d15' 0.15"E, 55d20'53.16"N)
Если добавить в геосервер и выставить epsg:900913, а затем просто посмотреть слой, то координаты левого верхнего угла при наведении курсора мыши будут 6231833.26575, 7464144.16819, т.е слой смещен по вертикали. Почему это происходит?
special K
Re: Проблемы с привязкой геотиффов к геосерверу.
Сообщение special K » 28 апр 2011, 23:45
вроде вот про это http://osgeo-org.1803224.n2.nabble.com/ ... 07575.html
не знаю правильно ли я понял: я создал epsg:3785 в cubewerx_extra.wkt и проецировал в нее, но что-то это ничего не изменило..
special K
Сообщение special K » 29 апр 2011, 00:50
перепрецировал в world mercator, импортировал, перепроецировал. Вобщем не импортируются нормально в геосервер тиффы в проекции 900913/3857, так что надо использовать другую, например, epsg:3395, а с wms запрашиваем ту проекцию, которая нужна.
Vladimir_R
Сообщение Vladimir_R » 29 апр 2011, 06:05
Тоже встретился с этой проблемой. Оставил растр в EPSG:4326, а перепроецирование в EPSG:900913 задал на Geoserver при публикации слоя.
Вернуться в «Веб-картография»
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 44 гостя
