GLOBAL_MAPPER_SCRIPT VERSION="1.00" FILENAME="L-37-006-B-c.gmw"
DEFINE_PROJ PROJ_NAME="PRJ"
Projection TRANSVERSE
Datum PULKOVO
Zunits NO
Units METERS
Xshift 0.000000
Yshift 0.000000
Parameters
1 /* scale factor at central meridian
39 /* central meridian
0 /* latitude of the origin
7500000 /* false easting (meters)
0 /* false northing (meters)
END_DEFINE_PROJ
IMPORT FILENAME="..\..\..\..\maps\25000\L-37\L-37-006-B-c.png" TYPE="PNG" \
PROJ_NAME="PRJ" RECTIFY="Automatic" SAMPLING_METHOD="BILINEAR" \
GCP="POINT1,18.071541846,23.4855709252,7481313.33069,5309285.52921" \
GCP="POINT2,4091.0,33.377728232,7490656.66312,5309262.83651" \
GCP="POINT3,4084.4642557,4072.51442908,7490641.67006,5299997.02267" \
GCP="POINT4,5.0,4062.61942177,7481283.34447,5300019.7219" \
CLIP_COLLAR="LAT_LON" CLIP_COLLAR_BOUNDS="38.75,47.8333333333,38.875,47.9166666667"Код: Выделить всё
Global Mapper v17.1.2 (b040816) [64-bit] [+OTF] [+Lidar]
The following errors were generated loading the workspace file:
WARNING: Unknown parameter <Projection> ignored.
WARNING: Unknown parameter <TRANSVERSE
Datum> ignored.
WARNING: Unknown parameter <PULKOVO
Zunits> ignored.
WARNING: Unknown parameter <NO
Units> ignored.
WARNING: Unknown parameter <METERS
Xshift> ignored.
WARNING: Unknown parameter <0.000000
Yshift> ignored.
Parameters
1> ignored.
WARNING: Unknown parameter </*> ignored.
WARNING: Unknown parameter <factor> ignored.
WARNING: Unknown parameter <at> ignored.
WARNING: Unknown parameter <central> ignored.
WARNING: Unknown parameter <meridian
39> ignored.
0> ignored.
WARNING: Unknown parameter <latitude> ignored.
WARNING: Unknown parameter <of> ignored.
WARNING: Unknown parameter <the> ignored.
WARNING: Unknown parameter <origin
7500000> ignored.
WARNING: Unknown parameter <false> ignored.
WARNING: Unknown parameter <easting> ignored.
WARNING: Unknown parameter <(meters)
0> ignored.
WARNING: Unknown parameter <northing> ignored.
ERROR: The PROJ_NAME PRJ did not have an END_DEFINE_PROJ line.
ОК
