Rumato
Сообщение
Rumato » 06 ноя 2013, 09:40
Добрый день! Подскажите, пожалуйста, с таким вопросом. Я пытаюсь конвертировать HDF в Geotiff, при использовании графического интерфейчас все нормально происходит, но мне нужен интерфейс командной строки, который и при этом возникают ошибки, ниже приведен вывод консоли:
Incorrect OUTPUT_TYPE field (bad value GEO).
Invalid field OUTPUT_TYPE
Error: : Reading Input Parameter File
: Failed reading parameter values.
Fatal Error, Terminating...
diver@dipprogram:~/geoserver/workers/mod07$ /home/diver/heg/bin/swtif -p /home/diver/geoserver/fileparams/mod07.prm
(swtif)
Start Time: Wed Nov 6 13:26:47 2013
Listing Command Line Options:
Translating input file 1...
Failed in assigning logical IDs
Shortname for input product = NONE-ECS
=== Parameter file input variables ====
...INPUT_FILENAME: /home/diver/geolocal/datahdf/MOD07_L2.A2013036.0535.005.2013079062316.hdf
...OBJECT_NAME: mod07
...FIELD_NAME: Total_Ozone
...upper left(lat): 56.675838
...upper left(lon): 65.675201
...lower right(lat): 35.211338
...lower right(lon): 101.789185
...OUTPUT_PROJECTION_TYPE: GEO
...OUTPUT_PROJECTION_PARAMETERS: (
0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 )
...OUTPUT_PIXEL_SIZE_X: 0.065516
...OUTPUT_PIXEL_SIZE_Y: 0.045191
...OUTPUT_FILENAME: /home/diver/geoserver/data/geotiff/24.10/MOD07.tif
...OUTPUT_TYPE: GEO
Warning: No map relation in swath mod07. Assuming default values for offset and increament.
Please wait. Reading/interpolating lats/lons .....
Warning: lat/lon of subset corners are about the same as the lat/lon for the converted swath.
Unneccessary subsetting will not be performed.
Swath temp files for lats/lons will require about 876 KB of disk space (in the disk containing heg's bin directory).
Error: interpolate_latlon : General Processing
: Latitude has value less than -90 or greater than 90. Exiting.
diver@dipprogram:~/geoserver/workers/mod07$ /home/diver/heg/bin/HEG -p /home/diver/geoserver/fileparams/mod07.prm
Fontconfig warning: "/etc/fonts/conf.d/50-user.conf", line 9: reading configurations from ~/.fonts.conf is deprecated.
Я использую следующий файл параметров:
NUM_RUNS = 1
BEGIN
INPUT_FILENAME = /home/diver/geolocal/datahdf/MOD07_L2.A2013036.0535.005.2013079062316.hdf
OBJECT_NAME = mod07
FIELD_NAME = Total_Ozone|
BAND_NUMBER = 1
OUTPUT_PIXEL_SIZE_X = 0.065516
OUTPUT_PIXEL_SIZE_Y = 0.045191
SPATIAL_SUBSET_UL_CORNER = ( 56.675838 65.675201 )
SPATIAL_SUBSET_LR_CORNER = ( 35.211338 101.789185 )
RESAMPLING_TYPE = NN
OUTPUT_PROJECTION_TYPE = GEO
ELLIPSOID_CODE = WGS84
OUTPUT_PROJECTION_PARAMETERS = ( 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 )
OUTPUT_FILENAME = /home/diver/geoserver/data/geotiff/24.10/MOD07.tif
OUTPUT_TYPE = GEO
END
Запускаю вот так /home/diver/heg/bin/swtif -p /home/diver/geoserver/fileparams/mod07.prm
Заранее большое спасибо!
Сообщение
Александр Мурый » 06 ноя 2013, 11:06
Проблемы здесь:
Странно, т.к. в файле параметров ошибок не заметил. Всё, как в мануале.
Приведите свойства файла MOD07_L2.A2013036.0535.005.2013079062316.hdf
Rumato
Сообщение
Rumato » 09 ноя 2013, 07:44
Извиняюсь, что не сразу отвечаю, на учёбе был полный завал. Вот вывод gdalinfo:
Files: MOD07_L2.A2013036.0535.005.2013079062316.hdf
Size is 512, 512
Coordinate System is `'
Metadata:
ALGORITHMPACKAGEACCEPTANCEDATE=June 1997
ALGORITHMPACKAGEMATURITYCODE=at-launch
ALGORITHMPACKAGENAME=ATBD-MOD-07
ALGORITHMPACKAGEVERSION=2
ASSOCIATEDINSTRUMENTSHORTNAME=MODIS
ASSOCIATEDPLATFORMSHORTNAME=Terra
ASSOCIATEDSENSORSHORTNAME=MODIS
AUTOMATICQUALITYFLAG=Passed
AUTOMATICQUALITYFLAGEXPLANATION=Passed: >10% usable; Failed: <10% usable
DAYNIGHTFLAG=Day
DayProcessedPct= 99.51
DESCRREVISION=5.0
EASTBOUNDINGCOORDINATE=102.17755581025
EQUATORCROSSINGDATE=2013-02-05
EQUATORCROSSINGLONGITUDE=69.892629225641
EQUATORCROSSINGTIME=05:50:24.423577
EXCLUSIONGRINGFLAG=N
GRINGPOINTLATITUDE=56.7210860633523, 51.6165145933327, 34.9683818735014, 38.5101395174693
GRINGPOINTLONGITUDE=66.5030267908967, 102.178743202231, 91.8206182548688, 65.5496471984142
GRINGPOINTSEQUENCENO=1, 2, 3, 4
HDFEOSVersion=HDFEOS_V2.16
history=$Id: MOD07.V2.CDL,v 1.1.2.4 2002/03/04 15:47:57 gumley Exp $
INPUTPOINTER=MOD021KM.A2013036.0535.005.2013079061917.hdf, MOD03.A2013036.0535.005.2013079061913.hdf, MOD35_L2.A2013036.0535.005.2013079062135.hdf, gdas1.PGrbF00.130205.06z, MODIS_REGCOEF_col5.2.terra, MODIS_senzen.bin, terra_bias.dat.v2, terra_det.dat.v2, destripe_config_terra.dat.v1
INSTRUMENTNAME=Moderate Resolution Imaging Spectroradiometer
LandProcessedPct= 99.44
LOCALGRANULEID=MOD07_L2.A2013036.0535.005.2013079062357.hdf
LOCALINPUTGRANULEID=MOD021KM.A2013036.0535.005.2013079061917.hdf, MOD03.A2013036.0535.005.2013079061913.hdf, MOD35_L2.A2013036.0535.005.2013079062316.hdf, gdas1.PGrbF00.130205.06z, MODIS_REGCOEF_col5.2.terra, MODIS_senzen.bin, terra_bias.dat.v2, terra_det.dat.v2, destripe_config_terra.dat.v1
LOCALVERSIONID=005
LONGNAME=MODIS/Terra Temperature and Water Vapor Profiles 5-Min L2 Swath 5km
LowConfidentClearPct= 82.69
MaxSolarZenithAngle= 77.57
MinSolarZenithAngle= 51.42
NightProcessedPct= 0.00
NonCloudObstructionFoundPct= 7.04
NORTHBOUNDINGCOORDINATE=56.7109484692178
ORBITNUMBER=69869
PARAMETERNAME=Water_Vapor_Infrared
PGEVERSION=5.3.0
PROCESSINGENVIRONMENT=IRIX64 modular 6.5 10070055 IP27
PRODUCTIONDATETIME=2013-03-20T06:23:57.000Z
PRODUCTIONHISTORY=PGE03:5.3.0
PROFILES_ALGORITHM_VERSION_NUMBER=1
QAPERCENTMISSINGDATA=84
RANGEBEGINNINGDATE=2013-02-05
RANGEBEGINNINGTIME=05:35:00.022739
RANGEENDINGDATE=2013-02-05
RANGEENDINGTIME=05:39:59.882404
REPROCESSINGACTUAL=processed once
REPROCESSINGPLANNED=further update is anticipated
SCIENCEQUALITYFLAG=Not Investigated
SCIENCEQUALITYFLAGEXPLANATION=See http://modis-atmos.gsfc.nasa.gov/validation.html for more details on MODIS Atmosphere data quality.
ShadowFoundPct= 0.00
SHORTNAME=MOD07_L2
Snow_IceSurfaceProcessedPct= 8.56
SOUTHBOUNDINGCOORDINATE=35.1006174004249
STABILITY_INDICES_ALGORITHM_VERSION_NUMBER=1
SuccessfulRetrievalPct= 15.61
SunglintProcessedPct= 0.00
ThinCirrusIR_FoundPct= 5.80
ThinCirrusSolarFoundPct= 15.77
title=MODIS Level 2 Atmospheric Profiles
TOTAL_OZONE_ALGORITHM_VERSION_NUMBER=1
VERSIONID=5
WaterProcessedPct= 0.07
WESTBOUNDINGCOORDINATE=65.5624376429678
Subdatasets:
SUBDATASET_1_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Scan_Start_Time
SUBDATASET_1_DESC=[406x270] Scan_Start_Time mod07 (64-bit floating-point)
SUBDATASET_2_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Solar_Zenith
SUBDATASET_2_DESC=[406x270] Solar_Zenith mod07 (16-bit integer)
SUBDATASET_3_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Solar_Azimuth
SUBDATASET_3_DESC=[406x270] Solar_Azimuth mod07 (16-bit integer)
SUBDATASET_4_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Sensor_Zenith
SUBDATASET_4_DESC=[406x270] Sensor_Zenith mod07 (16-bit integer)
SUBDATASET_5_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Sensor_Azimuth
SUBDATASET_5_DESC=[406x270] Sensor_Azimuth mod07 (16-bit integer)
SUBDATASET_6_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Brightness_Temperature
SUBDATASET_6_DESC=[12x406x270] Brightness_Temperature mod07 (16-bit integer)
SUBDATASET_7_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Cloud_Mask
SUBDATASET_7_DESC=[406x270] Cloud_Mask mod07 (8-bit integer)
SUBDATASET_8_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Surface_Temperature
SUBDATASET_8_DESC=[406x270] Surface_Temperature mod07 (16-bit integer)
SUBDATASET_9_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Surface_Pressure
SUBDATASET_9_DESC=[406x270] Surface_Pressure mod07 (16-bit integer)
SUBDATASET_10_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Surface_Elevation
SUBDATASET_10_DESC=[406x270] Surface_Elevation mod07 (16-bit integer)
SUBDATASET_11_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Processing_Flag
SUBDATASET_11_DESC=[406x270] Processing_Flag mod07 (8-bit integer)
SUBDATASET_12_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Tropopause_Height
SUBDATASET_12_DESC=[406x270] Tropopause_Height mod07 (16-bit integer)
SUBDATASET_13_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Guess_Temperature_Profile
SUBDATASET_13_DESC=[20x406x270] Guess_Temperature_Profile mod07 (16-bit integer)
SUBDATASET_14_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Guess_Moisture_Profile
SUBDATASET_14_DESC=[20x406x270] Guess_Moisture_Profile mod07 (16-bit integer)
SUBDATASET_15_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Retrieved_Temperature_Profile
SUBDATASET_15_DESC=[20x406x270] Retrieved_Temperature_Profile mod07 (16-bit integer)
SUBDATASET_16_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Retrieved_Moisture_Profile
SUBDATASET_16_DESC=[20x406x270] Retrieved_Moisture_Profile mod07 (16-bit integer)
SUBDATASET_17_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Retrieved_Height_Profile
SUBDATASET_17_DESC=[20x406x270] Retrieved_Height_Profile mod07 (16-bit integer)
SUBDATASET_18_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Total_Ozone
SUBDATASET_18_DESC=[406x270] Total_Ozone mod07 (16-bit integer)
SUBDATASET_19_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Total_Totals
SUBDATASET_19_DESC=[406x270] Total_Totals mod07 (16-bit integer)
SUBDATASET_20_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Lifted_Index
SUBDATASET_20_DESC=[406x270] Lifted_Index mod07 (16-bit integer)
SUBDATASET_21_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:K_Index
SUBDATASET_21_DESC=[406x270] K_Index mod07 (16-bit integer)
SUBDATASET_22_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Water_Vapor
SUBDATASET_22_DESC=[406x270] Water_Vapor mod07 (16-bit integer)
SUBDATASET_23_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Water_Vapor_Direct
SUBDATASET_23_DESC=[406x270] Water_Vapor_Direct mod07 (16-bit integer)
SUBDATASET_24_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Water_Vapor_Low
SUBDATASET_24_DESC=[406x270] Water_Vapor_Low mod07 (16-bit integer)
SUBDATASET_25_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Water_Vapor_High
SUBDATASET_25_DESC=[406x270] Water_Vapor_High mod07 (16-bit integer)
SUBDATASET_26_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Quality_Assurance
SUBDATASET_26_DESC=[406x270x10] Quality_Assurance mod07 (8-bit integer)
SUBDATASET_27_NAME=HDF4_EOS:EOS_SWATH:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":mod07:Quality_Assurance_Infrared
SUBDATASET_27_DESC=[406x270x5] Quality_Assurance_Infrared mod07 (8-bit integer)
SUBDATASET_28_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":0
SUBDATASET_28_DESC=[406x270] Scan_Start_Time (64-bit floating-point)
SUBDATASET_29_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":1
SUBDATASET_29_DESC=[406x270] Latitude (32-bit floating-point)
SUBDATASET_30_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":2
SUBDATASET_30_DESC=[406x270] Longitude (32-bit floating-point)
SUBDATASET_31_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":3
SUBDATASET_31_DESC=[406x270] Solar_Zenith (16-bit integer)
SUBDATASET_32_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":4
SUBDATASET_32_DESC=[406x270] Solar_Azimuth (16-bit integer)
SUBDATASET_33_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":5
SUBDATASET_33_DESC=[406x270] Sensor_Zenith (16-bit integer)
SUBDATASET_34_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":6
SUBDATASET_34_DESC=[406x270] Sensor_Azimuth (16-bit integer)
SUBDATASET_35_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":7
SUBDATASET_35_DESC=[12x406x270] Brightness_Temperature (16-bit integer)
SUBDATASET_36_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":8
SUBDATASET_36_DESC=[406x270] Cloud_Mask (8-bit integer)
SUBDATASET_37_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":9
SUBDATASET_37_DESC=[406x270] Surface_Temperature (16-bit integer)
SUBDATASET_38_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":10
SUBDATASET_38_DESC=[406x270] Surface_Pressure (16-bit integer)
SUBDATASET_39_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":11
SUBDATASET_39_DESC=[406x270] Surface_Elevation (16-bit integer)
SUBDATASET_40_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":12
SUBDATASET_40_DESC=[406x270] Processing_Flag (8-bit integer)
SUBDATASET_41_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":13
SUBDATASET_41_DESC=[406x270] Tropopause_Height (16-bit integer)
SUBDATASET_42_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":14
SUBDATASET_42_DESC=[20x406x270] Guess_Temperature_Profile (16-bit integer)
SUBDATASET_43_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":15
SUBDATASET_43_DESC=[20x406x270] Guess_Moisture_Profile (16-bit integer)
SUBDATASET_44_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":16
SUBDATASET_44_DESC=[20x406x270] Retrieved_Temperature_Profile (16-bit integer)
SUBDATASET_45_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":17
SUBDATASET_45_DESC=[20x406x270] Retrieved_Moisture_Profile (16-bit integer)
SUBDATASET_46_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":18
SUBDATASET_46_DESC=[20x406x270] Retrieved_Height_Profile (16-bit integer)
SUBDATASET_47_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":19
SUBDATASET_47_DESC=[406x270] Total_Ozone (16-bit integer)
SUBDATASET_48_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":20
SUBDATASET_48_DESC=[406x270] Total_Totals (16-bit integer)
SUBDATASET_49_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":21
SUBDATASET_49_DESC=[406x270] Lifted_Index (16-bit integer)
SUBDATASET_50_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":22
SUBDATASET_50_DESC=[406x270] K_Index (16-bit integer)
SUBDATASET_51_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":23
SUBDATASET_51_DESC=[406x270] Water_Vapor (16-bit integer)
SUBDATASET_52_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":24
SUBDATASET_52_DESC=[406x270] Water_Vapor_Direct (16-bit integer)
SUBDATASET_53_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":25
SUBDATASET_53_DESC=[406x270] Water_Vapor_Low (16-bit integer)
SUBDATASET_54_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":26
SUBDATASET_54_DESC=[406x270] Water_Vapor_High (16-bit integer)
SUBDATASET_55_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":27
SUBDATASET_55_DESC=[406x270x10] Quality_Assurance (8-bit integer)
SUBDATASET_56_NAME=HDF4_SDS:UNKNOWN:"MOD07_L2.A2013036.0535.005.2013079062316.hdf":28
SUBDATASET_56_DESC=[406x270x5] Quality_Assurance_Infrared (8-bit integer)
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 512.0)
Upper Right ( 512.0, 0.0)
Lower Right ( 512.0, 512.0)
Center ( 256.0, 256.0)
Сообщение
Александр Мурый » 09 ноя 2013, 10:17
Какая версия HEG? Желательно поставить самую свежую, т.к. в старых, как я понял по поиску в сети, были проблемы с MOD07_L2.
В HEG в граф. интерфейсе выставляются точно те же параметры для преобразования в геотифф? Ну и желательно посмотреть на сам файл.
