QGIS и слой PostGIS с полем geography
rhot
Ваше звание: доктор
Сообщение rhot » 22 май 2012, 15:36
Подключил слой PostGIS (полигональный) в QGIS, при выборе инструмента "Определить объекты" выдаёт следующую ошибку:
Потеряно 1 состояний курсора.
SQL: declare qgisf0 binary cursor for select "gid",asbinary(force_2d("geog"::geometry),'NDR'),"fid_vid_al"::text,"id_asu"::text,"id"::text,"Код"::text,"id_1"::text,"ln"::text,"uch_ln"::text,"kv"::text,"vyd"::text,"podvyd"::text,"kl_vozr"::text,"sostav"::text,"gr_vozr"::text,"s"::text,"poroda"::text,"bon"::text,"object_id"::text,"nkv"::text,"label"::text,"pod_vyd"::text,"id_asu_1"::text,"area"::text,"x"::text,"y"::text,"fid_dog_di"::text,"ln_1"::text,"uch_ln_1"::text,"n_dog"::text,"data"::text,"s_1"::text,"v"::text,"v_hv"::text,"v_vyb_hv"::text,"v_vyb"::text,"id_uch"::text,"rent"::text,"formula_so"::text,"m1"::text,"m2"::text,"sr_vozrast"::text,"prispev"::text,"spel"::text,"fsc"::text,"s_12"::text,"tl"::text,"tlu_1"::text,"m_zapas"::text,"id_12"::text from "public"."v_tax" where "geog" && setsrid('BOX3D(45.9614121374536353 64.0735875701547144, 45.9618862614637465 64.0740616941648256)'::box3d,4326) and intersects("geog",setsrid('BOX3D(45.9614121374536353 64.0735875701547144, 45.9618862614637465 64.0740616941648256)'::box3d,4326))
Результат: 7 (ERROR:  function intersects(geography, geometry) does not exist
LINE 1: ...2614637465 64.0740616941648256)'::box3d,4326) and intersects...
HINT:  No function matches the given name and argument types. You might need to add explicit type casts.
Это что значит, QGIS не поддерживает пока полностью тип данных geography?
Ubuntu 11.10
Quantum GIS - 1.7.4-Wroclaw 'Wroclaw' (exported)
PostgreSQL 9.0.5 on i686-pc-linux-gnu, compiled by GCC gcc-4.5.real (Ubuntu/Linaro 4.5.2-8ubuntu4) 4.5.2, 32-bit
POSTGIS="1.5.3" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.7.1, 23 September 2009" LIBXML="2.7.8" USE_STATS
Вернуться в «Ошибки QGIS»
