Понимаю, что трудно профессионалу объяснять начинающему прописные истины. Поэтому задаю последний, наверное, вопрос: в файле map. записано- OziExplorer Map Data File Version 2.2
N-36-012-C-c
1 ,Map Code,
Pulkovo 1942 (1),WGS 84, 0.0000, 0.0000,WGS 84
Reserved 1
Reserved 2
Magnetic Variation,,,E
Map Projection,Transverse Mercator,PolyCal,No,AutoCalOnly,No,BSBUseWPX,Yes
Point01,xy, 297, 128, in, deg, , ,N, , ,E, grid, , 6656971.70089, 6183667.88318, N
Point02,xy, 3648, 5, in, deg, , ,N, , ,E, grid, , 6664818.32148, 6183958.15462, N
Point03,xy, 3798, 3966, in, deg, , ,N, , ,E, grid, , 6665169.62574, 6174683.50872, N
Point04,xy, 439, 4091, in, deg, , ,N, , ,E, grid, , 6657306.26648, 6174392.90644, N
Projection Setup,0,33,1,6500000,0,,,
Map Feature = MF ; Map Comment = MC These follow if they exist
Track File = TF These follow if they exist
Moving Map Parameters = MM? These follow if they exist
MM0,Yes
MMPNUM,4
MMPXY,1,297,128
MMPXY,2,3648,5
MMPXY,3,3798,3966
MMPXY,4,439,4091
MMPLL,1,35.5,55.75
MMPLL,2,35.625,55.75
MMPLL,3,35.625,55.6666666667
MMPLL,4,35.5,55.6666666667
MM1B,2.341216
MOP,Map Open Position,0,0
IWH,Map Image Width/Height,4096,4096
Какая проекция ПКК сервера росреестра подойдет для этого случая? Всем спасибо!
