mapserver, openlayers , pulkovo 42
soilmsu
Сообщение soilmsu » 15 сен 2011, 11:59
Здравствуйте.
Никак не выводится wms в openlayers.
http://localhost/cgi-bin/mapserv.exe?ma ... s&mode=map - так она нормально отображается.
Так же все ок отображается, если добавляю WMS слой в QGIS.
map file:
MAP
 NAME "wms_pgr"
 IMAGETYPE	PNG
 STATUS	ON
 EXTENT		-4346700.50 5266065.51 3673131.75 9687927.99
 SIZE		800 600
 SHAPEPATH	"C:\ms4w\apps\pgr\data"
 IMAGECOLOR	249 245 186
 WEB
 TEMPLATE "C:\ms4w\apps\pgr\template.html"
 IMAGEPATH "C:\ms4w\apps\pgr\data\tmp"
 IMAGEURL "C:\ms4w\tmp"
	METADATA
	wms_title "pgr"
	wms_abstract "this is WMS of pgr"
	wms_onlineresource "http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/pgr/pgr.map&"
	wms_srs  "EPSG:4326"
	wms_getfeatureinfo "http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/pgr/pgr.map&"
	wms_featureformat "text/plain"
	wms_enable_request "*"
	END
 END
	PROJECTION
   "proj=latlong"
   "ellps=WGS84"
   "datum=WGS84"
	END
LAYER
  NAME poias
  DATA pochv_rayony_Russia_region
  STATUS ON
  TYPE POLYGON
  TEMPLATE "dummy"
		CLASS
		NAME "poias"
		STYLE
		COLOR 232 232 232
		OUTLINECOLOR 32 32 32
		END
		END
		METADATA
		wms_title         "poias"
		wms_abstract      "poisa"
		wms_srs           "EPSG:4326"
		wms_include_items "all"
		END
	PROJECTION
   "proj=latlong"
   "ellps=WGS84"
   "datum=WGS84"
   END
 END
END
шаблон:
<html>
<head>
  <title>OpenLayers PGR</title>
    <script
    src="C:/ms4w/apps/openlayers-2.10/lib/OpenLayers.js"></script>
    </head>
    <body>
      <div style="width:100%; height:100%" id="map"></div>
      <script type="text/javascript">
	  	var lat = 36;
        var lon = 32;
        var zoom = 2;
var map = new OpenLayers.Map('map');
projection: new OpenLayers.Projection("EPSG:900913");
displayProjection: new OpenLayers.Projection("EPSG:4326");
maxExtent: new OpenLayers.Bounds(-4346700.50,5266065.51,3673131.75,9687927.99);
           var mappath="C:/ms4w/apps/pgr/pgr.map";
           var mapurl="http://localhost/cgi-bin/mapserv.exe";
           var layer = new OpenLayers.Layer.WMS("WMS",
            mapurl,    {map: mappath, layers: 'poias', format: 'png'},{'reproject': true});
           map.addLayer(layer);
map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
        map.addControl( new OpenLayers.Control.LayerSwitcher() );
      </script>
</body>
</html>
Косяк как я понимаю в проекции.. Пробовал менять все и так и сяк, не работает, шерстил форумы, прочитал побольше про проекции. Как я понимаю, надо определить проекцию карты в ogrinfo (хотя и без этого все выводилось) для начала, а потом прописать ее в mapfile:
C:\ms4w\Apache\cgi-bin>ogrinfo.exe -al -so 1.shp
INFO: Open of `1.shp'
      using driver `ESRI Shapefile' successful.
Layer name: 1
Geometry: Polygon
Feature Count: 1378
Extent: (-4346700.498942, 5266065.506618) - (3673131.754524, 9687927.994227)
Layer SRS WKT:
PROJCS["_MI_0",
    GEOGCS[,
        DATUM["Pulkovo_1942",
            SPHEROID["Krassovsky_1940_1948",6378245,298.300000000038]],
        PRIMEM["Greenwich",0],
        UNIT["Degree",0.017453292519943295]],
    PROJECTION["Equidistant_Conic"],
    PARAMETER["standard_parallel_1",51.3041667],
    PARAMETER["standard_parallel_2",66.4366667],
    PARAMETER["latitude_of_center",0],
    PARAMETER["longitude_of_center",100],
    PARAMETER["false_easting",0],
    PARAMETER["false_northing",0],
    UNIT["Meter",1]]
Осознал свой косяк в mapfile и шаблоне.. пробовал вставлять туда разные "окна" Пулково 42, ничего не отображается или ругается на неверный SRS.
Никак не пойму как определить зону для Pulkovo_1942? Где это прописано в ogrinfo? (что бы потом вписать эту проекцию в map file)
Изображение - что показывает openlayers (template.html)
Изображение - что показывается в qgis и через http://localhost/cgi-bin/mapserv.exe?ma ... s&mode=map
Заранее огромное спасибо за помощь.
The author accepts no liability for any harm, injury, disease, insanity, death, life, trauma or shotgun wounds caused, directly or indirectly, by this reply to any person.
Mavka
Re: mapserver, openlayers , pulkovo 42
Сообщение Mavka » 15 сен 2011, 12:04
Полистайте логи Apache, там увидите расхождения qgis и OL.
reproject в свойствах слоя не нужен.
soilmsu
Сообщение soilmsu » 15 сен 2011, 12:24
Спасибо за быстрый ответ!
Мапсервер:
/cgi-bin/mapserv.exe?MAP=C%3A%2Fms4w%2Fapps%2Fpgr%2Fpgr.map&
LAYERS=poias&
FORMAT=png&S
ERVICE=WMS&
VERSION=1.1.1&
REQUEST=GetMap&
STYLES=&
EXCEPTIONS=application%2Fvnd.ogc.se_inimage&
SRS=EPSG%3A4326&
BBOX=135,-90,180,-45&
WIDTH=256&HEIGHT=256%20
HTTP/1.1%22%20200%20761
QGIS:
SERVICE=WMS&
VERSION=1.3.0&
REQUEST=GetMap&
BBOX=1668100.000000,-4346700.000000,9687930.000000,3673130.000000&
CRS=EPSG:4326&
WIDTH=32&
HEIGHT=32&
LAYERS=wms_pgr&
STYLES=&
FORMAT=image/png&TRANSPARENT=TRUE HTTP/1.1" 200 649
/cgi-bin/mapserv.exe?map=/ms4w/apps/pgr/pgr.map&SERVICE=WMS&
VERSION=1.3.0&
REQUEST=GetMap&
BBOX=5261937.420561,-4346700.000000,9687930.000000,3673130.000000&
CRS=EPSG:4326&
WIDTH=1109&
HEIGHT=612&
LAYERS=wms_pgr&
STYLES=&
FORMAT=image/png&
DPI=96&
TRANSPARENT=TRUE HTTP/1.1" 200 643994
что-то не пойму в чем дело-то... попробовал в openlayers сделать не LAYERS=poias&, а LAYERS=wms_pgr& - не помогает.
может проблема в BBOX.. сделал
new OpenLayers.Bounds(1668100.000000,-4346700.000000,9687930.000000,3673130.000000);
или с 5261937.420561,-4346700.000000,9687930.000000,3673130.000000, тоже самое, желтый экран (reproject убрал)
Mavka
Сообщение Mavka » 15 сен 2011, 13:01
В запросах не совместимые параметры:
CRS=EPSG:4326&
В map-файле аналогично:
PROJECTION
"proj=latlong"
"ellps=WGS84"
"datum=WGS84"
END
В wms_srs добавьте 900913
pochv_rayony_Russia_region в какой СК?
soilmsu
Сообщение soilmsu » 15 сен 2011, 14:12
Спасибо за помощь отчаявшемуся человеку! :)
Добавил в wms_srs 900913, перестал отображаться даже фон - invalid srs given: srs must be valid for all requested layers.
Иходя из ogrinfo, pochv_rayony_Russia_region:
Layer name: 1
Geometry: Polygon
Feature Count: 1378
Layer SRS WKT:
PROJCS["_MI_0",
GEOGCS[,
UNIT["Meter",1]]
Видимо в мапфайле надо изменить СК все, т.к. там указан WSG.. Странно только, что QGIS все нормально отображает.
То есть мы имеет Pulkovo 42, эллипсоид Красовского. Единицы измерения - метры.. То есть это не WGS 1984, а Pulkovo 1942, так? Я никак не могу понять какая это зона Pulkovo 1942, что бы выбрать номер EPSG (http://gis-lab.info/qa/proj-sk-faq.html#1 - тут картинка с разграфовкой зон, я не очень понял как ей пользоваться.. карта попадает с 19 по 27 интервалы, какое выбрать?
Mavka
Сообщение Mavka » 15 сен 2011, 15:56
Equidistant_Conic с зонами вряд ли связан...
Конвертните ее в обычный epsg:4326 и не гадайте.
soilmsu
Сообщение soilmsu » 15 сен 2011, 19:47
Спасибо! )) Перевел через универсальный транслятор и заработало!
Теперь уже который час борюсь с проблемой выравнивания карты (см вложенный файл) - она смещена вправо вверх
Пробовал менять EXTENT, не помогло.
Проверил логи апача:
OL:
/cgi-bin/mapserv.exe?MAP=C%3A%2Fms4w%2Fapps%2Fpgr%2Fpgr.map&LAYERS=wms_pgr&FORMAT=png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-90,-90,0,0&WIDTH=256&HEIGHT=256 HTTP/1.1" 200 761
/cgi-bin/mapserv.exe?MAP=C%3A%2Fms4w%2Fapps%2Fpgr%2Fpgr.map&LAYERS=wms_pgr&FORMAT=png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-180,-90,-90,0&WIDTH=256&HEIGHT=256 HTTP/1.1" 200 761
/cgi-bin/mapserv.exe?MAP=C%3A%2Fms4w%2Fapps%2Fpgr%2Fpgr.map&LAYERS=wms_pgr&FORMAT=png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=90,-90,180,0&WIDTH=256&HEIGHT=256 HTTP/1.1" 200 761
/cgi-bin/mapserv.exe?MAP=C%3A%2Fms4w%2Fapps%2Fpgr%2Fpgr.map&LAYERS=wms_pgr&FORMAT=png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=0,-90,90,0&WIDTH=256&HEIGHT=256 HTTP/1.1" 200 761
/cgi-bin/mapserv.exe?MAP=C%3A%2Fms4w%2Fapps%2Fpgr%2Fpgr.map&LAYERS=wms_pgr&FORMAT=png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-180,0,-90,90&WIDTH=256&HEIGHT=256 HTTP/1.1" 200 761
/cgi-bin/mapserv.exe?MAP=C%3A%2Fms4w%2Fapps%2Fpgr%2Fpgr.map&LAYERS=wms_pgr&FORMAT=png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=-90,0,0,90&WIDTH=256&HEIGHT=256 HTTP/1.1" 200 761
/cgi-bin/mapserv.exe?MAP=C%3A%2Fms4w%2Fapps%2Fpgr%2Fpgr.map&LAYERS=wms_pgr&FORMAT=png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=90,0,180,90&WIDTH=256&HEIGHT=256 HTTP/1.1" 200 36976
/cgi-bin/mapserv.exe?MAP=C%3A%2Fms4w%2Fapps%2Fpgr%2Fpgr.map&LAYERS=wms_pgr&FORMAT=png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&BBOX=0,0,90,90&WIDTH=256&HEIGHT=256 HTTP/1.1" 200 28872
qgis:
VERSION=1.3.0&REQUEST=GetMap&
BBOX=41.136957,19.640700,81.890700,190.297000&
CRS=epsg:4326&WIDTH=1341&HEIGHT=320&
LAYERS=wms_pgr&STYLES=&FORMAT=image/png&DPI=96&
TRANSPARENT=TRUE HTTP/1.1" 200 396896
VERSION=1.3.0&REQUEST=GetMap&BBOX=-88.765600,19.640700,81.890700,190.297000&
CRS=epsg:4326&WIDTH=120&HEIGHT=120&
DPI=96&TRANSPARENT=TRUE HTTP/1.1" 200 4123
добавлял HEIGHT побольше в шаблон - не помогло..
шаблон:
	var lat = 0;
        var lon = 0;
        var zoom = 2;
maxExtent: new OpenLayers.Bounds(41.009601,19.640700,81.890700,190.297000);
            mapurl,    {map: mappath, layers: 'wms_pgr', format: 'png'},{'reproject': true});
мапфайл:
MAP
 NAME "wms_pgr"
 IMAGETYPE	PNG
 STATUS	ON
 EXTENT		19.6407 41.1742 190.297 81.8907
 SIZE		1280 1024
 WEB
	METADATA
	wms_title "pgr"
	wms_srs  "epsg:4326"
	END
 END
	PROJECTION
   "proj=latlong"
   "ellps=WGS84"
   "datum=WGS84"
	END
LAYER
  NAME poias
  STATUS ON
  TYPE POLYGON
  TEMPLATE "dummy"
		CLASS
		NAME "poias"
		STYLE
		COLOR 232 232 232
		END
		END
		METADATA
		wms_title         "poias"
		wms_srs           "epsg:4326"
		END
	PROJECTION
   "proj=latlong"
   "ellps=WGS84"
   "datum=WGS84"
   END
 END
END
p.s.
{'reproject': true} убирал, не помогло )
old_Bibigon
Сообщение old_Bibigon » 16 сен 2011, 07:24
soilmsu писал(а):Пробовал менять EXTENT, не помогло.
шаблон:
	var lat = 0;
        var lon = 0;
        var zoom = 2;
У Вас перепутаны координаты в Bounds, смотрите тут и вместо zoom=2 с таким лучше использовать map.zoomToMaxExtent()
soilmsu
Сообщение soilmsu » 16 сен 2011, 15:04
Спасибо за подсказку, разобрался немного с Bounds :D
Как я понял, т.к. у меня EPSG:4326, макс. охват всего глобуса (-180,-90,180,90). Я измерил в qgis охват карты и сделал:
maxExtent: new OpenLayers.Bounds(15,12,195,111);
не помогает :(
У меня почему-то выводится все время охват всего глобуса. когда я меняю любые значения в new OpenLayers.Bounds - ничего не происходит.
Выкладываю еще 1 скриншот, внизу справа мини-карта ля навигации, на ней это особенно хорошо видно.
когда я руками правлю запрос (взял его через ПКМ по изображению карты в браузере) и прописываю там нужный BBOX (http://localhost/cgi-bin/mapserv.exe?MA ... HEIGHT=256) - все ок становится....
Почему у меня не изменяется BBOX, хотя я задаю его в OpenLayers.Bounds?
АПДЕЙТ:
проблему решила эта строка:
var map = new OpenLayers.Map('map', {'projection': new OpenLayers.Projection("EPSG:4326"), 'maxExtent': new OpenLayers.Bounds(15,12,195,111), 'maxResolution': 'auto'})
оказывается, параметры были верные... неверным был КОД )) javascript синтаксис )) как говорится, так программы не пишутся ))
всем спасибо за помощь! доволен аки слон, теперь буду привязывать другие слои )
Вернуться в «Веб-картография»
