from arcpy.sa import *
class Toolbox(object):
def __init__(self):
"""Define the toolbox (the name of the toolbox is the name of the
.pyt file)."""
self.label = "Toolbox"
self.alias = ""
# List of tool classes associated with this toolbox
self.tools = [Tool]
class Tool(object):
def __init__(self):
"""Define the tool (tool name is the name of the class)."""
self.label = "Tool"
self.description = ""
self.canRunInBackground = False
def getParameterInfo(self):
param0 = arcpy.Parameter(
displayName = "Input value",
name = "in_value",
datatype = "GPFeatureLayer",
parameterType = "Required",
direction = "input")
"""Define parameter definitions"""
params = [param0]
return params
def isLicensed(self):
"""Set whether tool is licensed to execute."""
return True
def updateParameters(self, parameters):
"""Modify the values and properties of parameters before internal
validation is performed. This method is called whenever a parameter
has been changed."""
return
def updateMessages(self, parameters):
"""Modify the messages created by internal validation for each tool
parameter. This method is called after internal validation."""
return
def execute(self, parameters, messages):
"""The source code of the tool."""
return
Хотя если тип поставить String все работает. Помогите пожалуйста.Traceback (most recent call last): File "<string>", line 28, in getParameterInfo File "c:\program files\arcgis\desktop10.1\arcpy\arcpy\arcobjects\mixins.py", line 286, in __init__ setattr(self, attrib, attribvalue) File "c:\program files\arcgis\desktop10.1\arcpy\arcpy\arcobjects\_base.py", line 87, in _set return setattr(self._arc_object, attr_name, cval(val))ValueError: ParameterObject: Invalid input value for DataType property
