вышел Opticks 4.7.0
Добавлено: 22 июн 2011, 19:45
Opticks 4.7.0 (Free and Open Source Remote Sensing software) Released
http://opticks.org/confluence/display/o ... To+Opticks
Opticks is an expandable remote sensing and imagery analysis software platform that is free and open source. http://opticks.org/confluence/display/o ... To+Opticks
• Sample data http://opticks.org/confluence/display/o ... ample+Data (imagery, vector data and vidoe are included.
• Available extensions (free) http://opticks.org/confluence/display/o ... Extensions
1. SAR processing tools plug-in>> SAR processing tools that can perform speckle removal, edge detection and segmentation
2. Spectral Processing>> Perform hyper and multi-spectral analysis using this collection of spectral processing algorithms.
3. IDL Scripting>> The IDL extension provides the ability to combine the power of Opticks and the IDL language . This extension provides the IDL scripting window which allows you use Opticks to load and visualize your imagery and then directly interface that imagery with IDL from within Opticks to manipulate and perform algorithms using the full power of the IDL language.
4. Raster Math>> Raster Math allows you write mathematical expressions involving the bands of multiple images to generate results, for example a Normalized Difference Vegetation Index (NDVI).
5. Python Scripting>> The Python scripting extension provides the ability to combine the power of Opticks and the Python language. This extension provides the Python scripting window which allows you use Opticks to load and visualize your imagery and then directly interface that imagery with Python and any other Python libraries from within Opticks to manipulate and perform algorithms using the full power of the Python language.
6. COAN General Image Processing >> Miscellaneous image processing utilities including color space translations, scaling and band replacement.
7. COAN Video Extensions >> Enhanced time-line widget for working with video data.
8. GSoC Project Extension >> This extension is a project of Google Summer of Code 2010 for Opticks. The extension contains target detection, anomaly detection and data merge tools.
9. OpenCV bindings for Python and Opticks.
