Здравствуйте
Была на днях рассылка с предупреждением.
Вроде и перевел но особо ничего не понял:
О чем они?
Hello Earth Engine User,
We are writing to remind you about key updates for Earth Engine's noncommercial offerings starting September 16, 2024. These updates are time-sensitive and may require you to change how you access Earth Engine.
Please note that Earth Engine will continue to remain free for noncommercial use.
We have provided additional details below to guide you through these changes.
What you need to know
As part of this important update, all Earth Engine usage must be linked to Cloud projects:
Since 2022, we've encouraged the use of Cloud projects, which enable you to leverage other Google Cloud tools to maximize your impact. Earth Engine users with a Cloud project are able to run custom machine learning models with Vertex AI and export large datasets to BigQuery, enabling solutions for complex use cases such as palm oil cultivation prediction and flood mapping. Cloud projects also enable a number of administrative capabilities, such as automated workflows and managed access and resources, allowing users to enable these solutions more efficiently and securely.
As part of this effort, please note the following changes to Earth Engine:
Starting September 16, 2024, we will begin limiting quotas* for accounts without Cloud projects, and most new Earth Engine features will only be available to users of Cloud projects.
Starting November 13, 2024, all Earth Engine access will require a Cloud project.
What you need to do
To ensure all Earth Engine users have a consistent experience and access to the growing set of Cloud features, follow the guidelines below:
Transition to Cloud projects: If you're not already using Cloud projects to access Earth Engine, you’ll need to follow the steps in the configuration guide by November 13, 2024 to ensure uninterrupted access to Earth Engine. We recommend starting as early as possible since you may need additional permissions from your organization’s Cloud administrator.
If you wish to retain your individual access (without a Cloud project) beyond November 13, 2024, please review your eligibility and apply for an extension.
We’re here to help
We understand these changes may require some adjustments, but please know that we are here to support you. If you have any questions or require further assistance, please contact Earth Engine Registration Support.
Thanks for choosing Earth Engine.
- The Earth Engine Team
*You'll still be able to make requests, but having fewer concurrent online/high-volume requests and concurrent batch tasks will limit your throughput. Learn more in our quota documentation.
Рассылка GEE
artterrm
- Эдуард Казаков
Re: Рассылка GEE
Здравствуйте, теперь нужно создавать проекты Google Cloud и привязывать работу в GEE к ним
artterrm
Re: Рассылка GEE
Здравствуйте.
Спасибо
Бесплатно?
Спасибо
Бесплатно?
