Проблема со сборкой QGIS (компиляция)
dmitriy_gislab
Сообщение dmitriy_gislab » 14 июн 2018, 11:48
Делал по этому руководству:
https://oslandia.com/en/2017/12/20/qgis ... n-windows/
Ошибка возникает на последнем шаге
package-nightly.cmd 2.99.0 1 qgis-dev x86_64
Процесс компиляции:
C:\cygwin\home\Влад\QGIS\ms-windows\osgeo4w>package-nightly.cmd 2.99.0 1 qgis-dev x86_64
BEGIN: 14.06.2018 11:38:49,13
CMAKE: 14.06.2018 11:38:49,20
-- Selecting Windows SDK version  to target Windows 10.0.17134.
-- The C compiler identification is MSVC 19.0.24215.1
-- The CXX compiler identification is MSVC 19.0.24215.1
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/bin/x86_amd64/cl.exe
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/bin/x86_amd64/cl.exe -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/bin/x86_amd64/cl.exe
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/bin/x86_amd64/cl.exe -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- QGIS version: 3.1.0 Master (30100)
-- Found GRASS 7: C:/OSGEO4~1/apps/grass/grass-7.4.0 (7.4.0, off_t size = 8)
-- Found Proj: C:/OSGeo4W64/lib/proj_i.lib
-- Found GEOS: C:/OSGeo4W64/lib/geos_c.lib (3.6.1)
-- Found GDAL: C:/OSGeo4W64/lib/gdal_i.lib (2.2.4)
-- Found Expat: C:/OSGeo4W64/lib/expat.lib
-- Found Spatialindex: C:/OSGeo4W64/lib/spatialindex-64.lib
-- Found Qwt: C:/OSGeo4W64/apps/Qt5/lib/qwt.lib (6.1.3)
-- Found libzip: C:/OSGeo4W64/lib/zip.lib
-- Found Sqlite3: C:/OSGeo4W64/lib/sqlite3_i.lib
-- Found PostgreSQL: C:/OSGeo4W64/lib/libpq.lib
-- Found SpatiaLite: C:/OSGeo4W64/lib/spatialite_i.lib
-- Qt WebKit support enabled
-- Found Qt version: 5.9.2
-- Found QScintilla2: C:/OSGeo4W64/apps/Qt5/lib/qscintilla2.lib (2.10.1)
-- Found QtKeychain: C:/OSGeo4W64/apps/Qt5/lib/qt5keychain.lib
-- Found QCA: C:\OSGEO4~1\apps\Qt5\lib\qca-qt5.lib (2.1.0)
-- Pedantic compiler settings enabled
-- Debug output enabled
-- Found Python executable: C:/OSGeo4W64/bin/python3.exe
-- Found Python version: 3.6.0
-- Found Python library: C:/OSGeo4W64/apps/Python36/libs/python36.lib
-- Found Python site-packages: C:/OSGEO4~1/apps/Python36/Lib/site-packages
-- Found PyQt5 version: 5.9
-- Found SIP version: 4.19.3
-- Found QScintilla2 PyQt module: 2.10.1
-- txt2tags not found - disabled
CMake Error at src/providers/oracle/ocispatial/cmake/FindOCI.cmake:39 (MESSAGE):
  Could not find OCI
Call Stack (most recent call first):
  src/providers/oracle/ocispatial/CMakeLists.txt:5 (FIND_PACKAGE)
-- Configuring incomplete, errors occurred!
See also "C:/cygwin/home/Влад/QGIS/ms-windows/osgeo4w/build-qgis-dev-x86_64/CMakeFiles/CMakeOutput.log".
See also "C:/cygwin/home/Влад/QGIS/ms-windows/osgeo4w/build-qgis-dev-x86_64/CMakeFiles/CMakeError.log".
cmake failed
BUILD ERROR 1: 14.06.2018 11:39:14,43
rhot
Статьи: 1
Ваше звание: доктор
Re: Проблема со сборкой QGIS (компиляция)
Сообщение rhot » 14 июн 2018, 12:33
Oracle development headers and libraries установите сначала.
dmitriy_gislab
Сообщение dmitriy_gislab » 14 июн 2018, 13:56
Откуда взять этот пакет?
Статьи: 1
Сообщение trir » 14 июн 2018, 14:05
dmitriy_gislab
Сообщение dmitriy_gislab » 14 июн 2018, 14:12
Кому интересно, то нехватало пакета OCI
поставил его через osgeo4w. Вопрос решен!
dmitriy_gislab
Сообщение dmitriy_gislab » 14 июн 2018, 15:38
После компиляции и запуска exe возникает ошибка
Could not load qgis_app.dll
Сейчас этот форум просматривают: freeExec и 2 гостя
