Как запустить GeoServer
Добавлено: 15 апр 2014, 21:00
uDezimiro
Не могу запустить ГеоСервер
Cкачиваю виндоус дистрибутив стабильной версии 2.5 тут
http://sourceforge.net/projects/geoserv ... mirror=kaz
Все переменные среды он прописывает сам.
Запускаю через sturtup.bat - в консоли куча ошибок
C:\Program Files (x86)\GeoServer 2.5\bin>call "C:\Program Files\Java\jdk1.6.0_45
\\bin\java.exe" -DGEOSERVER_DATA_DIR="C:\Program Files (x86)\GeoServer 2.5\data_
dir" -Xmx512m -XX:MaxPermSize=128m -DSTOP.PORT=8079 -DSTOP.KEY=geoserver -Djetty
.port=8080 -Djetty.logs="C:\Program Files (x86)\GeoServer 2.5\logs" -jar "C:\Pro
gram Files (x86)\GeoServer 2.5\start.jar"
1 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger@18b753f8
via org.mortbay.log.Slf4jLog
236 [main] WARN org.mortbay.log - Deprecated configuration used for C:\Program F
iles (x86)\GeoServer 2.5/webapps
289 [main] INFO org.mortbay.log - jetty-6.1.8
0 [main] WARN org.geoserver.logging - log4jConfigFile 'DEFAULT_LOGGING.prop
erties' couldn't be found in the data dir, so GeoServer will install the various
logging config file into the data dir, and then try to find it again.
8 [main] ERROR org.geoserver.logging - Could not configure log4j overrides
java.io.IOException: Can't write to file C:\Program Files (x86)\GeoServer 2.5\da
ta_dir\logs\DEFAULT_LOGGING.properties. Check write permissions on target folder
for user Admin
at org.geoserver.platform.GeoServerResourceLoader.copyFromClassPath(GeoS
erverResourceLoader.java:608)
erverResourceLoader.java:574)
at org.geoserver.logging.LoggingUtils.initLogging(LoggingUtils.java:152)
at org.geoserver.logging.LoggingStartupContextListener.contextInitialize
d(LoggingStartupContextListener.java:74)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.
java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.jav
a:1220)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:
510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:
39)
at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection
.java:152)
at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHan
dlerCollection.java:156)
39)
.java:152)
39)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:
130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
39)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
3766 [main] INFO /geoserver - Initializing Spring root WebApplicationContext
15.04.2014 20:58:20 org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup occured, but ApplicationContext is unset.
4447 [main] WARN org.geoserver - No default workspace was found.
4465 [main] WARN org.geoserver - Failed to persist default workspace 'cite'
java.io.FileNotFoundException: C:\Program Files (x86)\GeoServer 2.5\data_dir\wor
kspaces\default.xml (╬Єърчрэю т фюёЄєях)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(FileOutputStream.java:194)
at java.io.FileOutputStream.<init>(FileOutputStream.java:145)
at org.geoserver.config.GeoServerLoader.persist(GeoServerLoader.java:733
На веб интерфейсе:
HTTP ERROR: 404
NOT_FOUND
Re: Как запустить GeoServer
Добавлено: 15 апр 2014, 21:48
uDezimiro
победил тем, что поставил на диск д в корень.
Добавлено: 19 апр 2014, 12:10
Nariman писал(а):Тоже сталкивался с такой проблемой.
Выяснилось, что data_dir geoservera в виндовс обязательно должен находиться на диске D.
Наверное, имеется в виду не конкретно диск D, а то, что имя каталога не должно содержать "некошерных" символов типа кириллицы, пробелов и т.п.?
