АркГИС 10.2 не хочет кэшировать фрейм с вырезкой
Добавлено: 25 фев 2016, 12:29
АркГИС 10.2 не хочет кэшировать фрейм, вырезанный по форме контура объекта, пишет ошибку :
00026: Data frames with a clip shape are not supportedArcGIS 10.2
Locate topic
Your data frame has clipping enabled, which is not supported for map services.
Solution
Remove (turn off) the Clip to shape option from your map's data frame properties.
Learn more about clipping the data frame
More information
Most maps contain a rectangular map extent in which geographic information and features are displayed as map layers. In some maps, you can specify a clipping shape that is used as a template within which map graphics are displayed—for example, a state's boundary might be used to clip a map. However, map clipping is not supported for map services because clipping may significantly slow down map drawing performance.
Задаю рамки фрейма полигоном из файловой базы геоданных.
Locate topic
Solution
More information
