Re: Собственная Wikimapia
Добавлено: 08 янв 2014, 09:29
Э.. есть ssh-доступ, значит можно, для разнообразия, запустить uname -a
Геоинформационные системы (ГИС) и Дистанционное зондирование Земли
https://gis-lab.info/forum/
XXXX@web1137 ~/XXXX.ru/mapserver]$ make
if test ! -s build/Makefile; then mkdir -p build ; cd build ; cmake .. -DCMAKE_C_FLAGS="--coverage" -DCMAKE_CXX_FLAGS="--coverage" -DCMAKE_SHARED_LINKER_FLAGS="-lgcov" -DWITH_GD=1 -DWITH_CLIENT_WMS=1 -DWITH_CLIENT_WFS=1 -DWITH_KML=1 -DWITH_SOS=1 -DWITH_PHP=1 -DWITH_PYTHON=1 -DWITH_JAVA=1 -DWITH_THREAD_SAFETY=1 -DWITH_FRIBIDI=0 -DWITH_FCGI=0 -DWITH_EXEMPI=1 -DCMAKE_BUILD_TYPE=Release -DWITH_RSVG=1 -DWITH_CURL=1; fi
-- Could NOT find PROJ (missing: PROJ_LIBRARY PROJ_INCLUDE_DIR)
CMake Error at CMakeLists.txt:49 (message):
PROJ library/component/dependency could not be found.
HINTS:
- disable PROJ support by adding -DWITH_PROJ=0
- add the PROJ install directory to the CMAKE_PREFIX_PATH variable (-DCMAKE_PREFIX_PATH="/path/to/PROJ-install-dir;/path/to/other/dirs"
Call Stack (most recent call first):
CMakeLists.txt:304 (report_optional_not_found)
CMake Error at CMakeLists.txt:60 (message):
WMS support requires PROJ support, however PROJ support has been disabled.
HINTS:
- re-run with -DWITH_PROJ=1 (or without -DWITH_PROJ=0)
- disable WMS support by adding -DWITH_WMS=0
CMakeLists.txt:316 (report_dependency_error)
-- checking for module 'cairo'
-- package 'cairo' not found
-- Could NOT find CAIRO (missing: CAIRO_LIBRARY CAIRO_INCLUDE_DIR)
CAIRO library/component/dependency could not be found.
HINTS:
- disable CAIRO support by adding -DWITH_CAIRO=0
- add the CAIRO install directory to the CMAKE_PREFIX_PATH variable (-DCMAKE_PREFIX_PATH="/path/to/CAIRO-install-dir;/path/to/other/dirs"
CMakeLists.txt:381 (report_optional_not_found)
-- Could NOT find GEOS (missing: GEOS_LIBRARY GEOS_INCLUDE_DIR)
GEOS library/component/dependency could not be found.
HINTS:
- disable GEOS support by adding -DWITH_GEOS=0
- add the GEOS install directory to the CMAKE_PREFIX_PATH variable (-DCMAKE_PREFIX_PATH="/path/to/GEOS-install-dir;/path/to/other/dirs"
CMakeLists.txt:493 (report_optional_not_found)
-- Could NOT find GDAL (missing: GDAL_LIBRARY GDAL_INCLUDE_DIR)
GDAL library/component/dependency could not be found.
HINTS:
- disable GDAL support by adding -DWITH_GDAL=0
- add the GDAL install directory to the CMAKE_PREFIX_PATH variable (-DCMAKE_PREFIX_PATH="/path/to/GDAL-install-dir;/path/to/other/dirs"
CMakeLists.txt:523 (report_optional_not_found)
-- Could NOT find RSVG (missing: RSVG_LIBRARY RSVG_INCLUDE_DIR)
-- Could NOT find GOBJECT (missing: GOBJECT_INCLUDE_DIR)
RSVG library/component/dependency could not be found.
HINTS:
- disable RSVG support by adding -DWITH_RSVG=0
- add the RSVG install directory to the CMAKE_PREFIX_PATH variable (-DCMAKE_PREFIX_PATH="/path/to/RSVG-install-dir;/path/to/other/dirs"
CMakeLists.txt:553 (report_optional_not_found)
CMake Error at CMakeLists.txt:567 (message):
GDAL library could not be found and is needed for OGR support.
HINTS:
- disable OGR support by adding -DWITH_OGR=0
- add the GDAL install directory to the CMAKE_PREFIX_PATH variable (-DCMAKE_PREFIX_PATH="/path/to/-install-dir;/path/to/other/dirs"
CLIENT_WMS support requires GDAL support, however GDAL support has been
disabled.
HINTS:
- re-run with -DWITH_GDAL=1 (or without -DWITH_GDAL=0)
- disable CLIENT_WMS support by adding -DWITH_CLIENT_WMS=0
CMakeLists.txt:606 (report_dependency_error)
CLIENT_WMS support requires PROJ support, however PROJ support has been
disabled.
HINTS:
CMakeLists.txt:609 (report_dependency_error)
CLIENT_WFS support requires OGR support, however OGR support has been
disabled.
HINTS:
- re-run with -DWITH_OGR=1 (or without -DWITH_OGR=0)
- disable CLIENT_WFS support by adding -DWITH_CLIENT_WFS=0
CMakeLists.txt:619 (report_dependency_error)
CLIENT_WFS support requires PROJ support, however PROJ support has been
disabled.
HINTS:
CMakeLists.txt:622 (report_dependency_error)
WFS support requires OGR support, however OGR support has been disabled.
HINTS:
- disable WFS support by adding -DWITH_WFS=0
CMakeLists.txt:633 (report_dependency_error)
WFS support requires PROJ support, however PROJ support has been disabled.
HINTS:
CMakeLists.txt:636 (report_dependency_error)
WCS support requires GDAL support, however GDAL support has been disabled.
HINTS:
- disable WCS support by adding -DWITH_WCS=0
CMakeLists.txt:646 (report_dependency_error)
WCS support requires PROJ support, however PROJ support has been disabled.
HINTS:
CMakeLists.txt:649 (report_dependency_error)
SOS support requires PROJ support, however PROJ support has been disabled.
HINTS:
- disable SOS support by adding -DWITH_SOS=0
CMakeLists.txt:683 (report_dependency_error)
-- Could NOT find LIBEXEMPI (missing: LIBEXEMPI_LIBRARY LIBEXEMPI_INCLUDE_DIR)
EXEMPI library/component/dependency could not be found.
HINTS:
- disable EXEMPI support by adding -DWITH_EXEMPI=0
- add the EXEMPI install directory to the CMAKE_PREFIX_PATH variable (-DCMAKE_PREFIX_PATH="/path/to/EXEMPI-install-dir;/path/to/other/dirs"
CMakeLists.txt:750 (report_optional_not_found)
CMake Error at /.ro/usr/local/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:97 (MESSAGE):
Could NOT find SWIG (missing: SWIG_EXECUTABLE SWIG_DIR)
/.ro/usr/local/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:288 (_FPHSA_FAILURE_MESSAGE)
/.ro/usr/local/share/cmake/Modules/FindSWIG.cmake:67 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
mapscript/python/CMakeLists.txt:1 (FIND_PACKAGE)
-- Configuring incomplete, errors occurred!
*** Error code 1
