OpenLayers WMSGetFeatureInfo пример
Pavel
Re: OpenLayers WMSGetFeatureInfo пример
Сообщение Pavel » 29 сен 2011, 13:35
Хорошо. Вот:
Спойлер
<html>
    <head>
<link rel="stylesheet" type="text/css" href="http://localhost:8080/geoserver/openlayers/theme/default/style.css"/>
    <script
    src="http://192.168.1.3:8080/geoserver/openlayers/lib/OpenLayers.js" type="text/javascript"></script>
              <script defer="defer" type="text/javascript">
    var info;
function load() {
       var bounds = new OpenLayers.Bounds(...);
       var options = {
                        controls:[],
                        maxExtent: bounds,
                        maxResolution: 147.527050781249955,
                        projection: "EPSG:32638",
                        units: 'm'
            var map = new OpenLayers.Map('map', options);
            var wms = new OpenLayers.Layer.WMS( "test",
                "http://192.168.1.3:8080/geoserver/nurc/wms",
    {layers: 'nurc:poligon_test',
    STYLES: 'PH-test',format: 'image/gif'
            map.addLayer(wms);
            map.zoomToMaxExtent();
    // build up all controls
                    map.addControl(new OpenLayers.Control.PanZoomBar({
                        position: new OpenLayers.Pixel(2, 15)
                    map.addControl(new OpenLayers.Control.Navigation());
                    map.addControl(new OpenLayers.Control.Scale($('scale')));
                    //map.addControl(new OpenLayers.Control.MousePosition({element: $('location')}));
                    map.zoomToExtent(bounds);
      wms_info = new OpenLayers.Control.WMSGetFeatureInfo({
          title: 'wmsinfo',
          layers: [wms],
          url: 'http://192.168.1.3:8080/geoserver/nurc/wms',
          infoFormat: 'application/vnd.ogc.gml',
          queryVisible: true
       wms_info.events.register('getfeatureinfo', this, showInfo);
       map.addControl(wms_info);
       wms_info.activate();
    function showInfo(e) {
       var reg = /^reg\./;
    var text = '';
       for(i in e.features) {
          if (i != 0) text += '<br>';
          if (reg.test(e.features[i].fid)) {
             if (e.features.length != 1)
                text += '<b>Цвет:</b><br>';
             text += e.features[i].attributes.A+ ' "'
    var popup = new OpenLayers.Popup.FramedCloud("popup",
                   map.getLonLatFromPixel(e.xy),
                   new OpenLayers.Size(640,480),
                   text,
                   null,
                   true
       map.addPopup(popup);
</script>
 </head>
 <body onload="load()">
 <div style="width: 640px; height: 480px; border: 2px solid black;" id="map"></div>
<div>test</div>
</body>
</html>
Сообщение Denis Rykov » 29 сен 2011, 13:44
Прям так и написано?
Pavel
Сообщение Pavel » 29 сен 2011, 13:52
Нет. Там нормальные координаты. Карта отображается правильно. Трудности возникают только при попытке сделать что-нибудь отличное от приблизить/отдалить/переместить.
Сообщение Denis Rykov » 30 сен 2011, 06:47
Похоже на проблему отображения попапа в случае пустого ответа. Попробуйте перед var popup = new OpenLayers.Popup.FramedCloud написать следующую строку, должно помочь:
(text === '') ? text = '&nbsp' : text = text;
Pavel
Сообщение Pavel » 30 сен 2011, 07:35
Спасибо! Помогло!:)
Ну и на закуску.:)
При щелчке на объект показывает пустое всплывающее окошко.
В ошибках:
Ошибка: элемент не найден
Источник: http://127.0.0.1/exapmle3.html
Строка: 1
Смотреть опять в сторону html?
Сообщение Denis Rykov » 30 сен 2011, 08:34
От сервера ответ приходит? Вот попытался воспроизвести ваш проект, только с другим WMS.
Pavel
Сообщение Pavel » 30 сен 2011, 09:02
Ответы приходят, окошки выскакивают. Но в них пусто.
(см.вложение)
Я начинаю подозревать, что проблемы в самом слое. С атрибутикой.
Сейчас посмотрел исходный код (и ваш и мой) и возникли два вопроса. Если ошибаюсь, то поправьте меня:
1.
text += e.features[i].attributes.address+ ' "'
Я так понимаю здесь address - это колонка в таблице атрибутов?
2.
var reg = /^car/;
Что за значение такое /^car/?
Сообщение Denis Rykov » 30 сен 2011, 09:24
1. Да
2. А это я у вас взял (по сути можно без этого, но я подумал, что вы специально такое условие накрутили) - это регулярка, только у вас var reg = /^reg\./, а у меня var reg = /^car/. В условии if (reg.test(e.features.fid)) матчатся только те фичи, fid которых соответствует регулярке, то есть в моём случае -начинающиеся с "car". Я в консоль вывожу объект ответа, так что можете изучить - что приходит у меня и посмотреть, что приходит у вас. С фаербагом дружите?
Pavel
Сообщение Pavel » 30 сен 2011, 09:30
_DR_ писал(а): С фаербагом дружите?
Да.
А по поводу регулярных условий... Стянул с примера.:) Вот и пытаюсь понять, как все это делло работает.
Сообщение Denis Rykov » 30 сен 2011, 09:43
Тогда сделайте по-простому. Перепишите функцию showInfo, чтобы выглядела так:
       e.text,
       null,
       true
И в контроле WMSGetFeatureInfo уберите строку infoFormat: 'application/vnd.ogc.gml'. Результат.
Pavel
Сообщение Pavel » 30 сен 2011, 12:24
Как все забавно получается...
Стал проверять - openlayers.org упал...
Надеюсь, не я его сломал... :oops:
Чуть по позже попробую и отпишусь
Pavel
Сообщение Pavel » 03 окт 2011, 08:37
Итак... После тщательного разбора, нашел, что у меня не работает скрипт proxy.cgi. Толи поддержка не включена, толи еще что-то. Это будем копать...
При щелчке на объекте во всплывающем окне пишется
Access forbidden!
You don't have permission to access the requested object. It is either read-protected or not readable by the server.
If you think this is a server error, please contact the webmaster.
Что очень странно, так как все разрешения стоят правильно.
Исходя из этого вопрос: можно ли использовать popup без объявления прокси? Этот скрипт обязателен для всех запросов GetFeatureInfo? Или можно обойтись без него?
Сообщение Denis Rykov » 03 окт 2011, 09:42
Да, для запроса данных по AJAX - прокси обязателен.
Mavka
Сообщение Mavka » 03 окт 2011, 15:52
Cross-domain security - viewtopic.php?f=41&t=6353
P.S. Проверьте путь к python
Pavel
Сообщение Pavel » 05 окт 2011, 07:33
Получилось наконец-то запустить все это дело! Правда, как всегда с костылями...
Пришлось отказаться от апача (так и не смог настроить в нем cgi и привязать к питону, что странно) и поставить nginx. Несколько "легких" движений и все заработало.
_DR_ и Mavka , большое спасибо за помощь и разъяснения!
