Имеем шейп-файл с множеством разбросанных по карте замкнутых мелких полигонов.
Задача - получить одну точку в центре каждого полигона.
Как можно это реализовать наименьшими трудозатратами?
Вручную стал набивать ... понял что не выход.
Может кто сталкивался с подобными задачами?
Версия ArcView 3.х
Точка в центре полигона
greengo
ggis
Re: Точка в центре полигона
' Name: PolyCentroidToPoint
' Title: Polygon Centroid to Point Theme
' Topics: polygon, shapefile, centroid, point
' Author: Tara Montgomery 12/20/99
' Description: Make a point theme from the centroid of a polygon
' Called by:
' Runs:
' Self:
' Returns: Nothing
theProject = av.GetProject
theDocs = theProject.GetDocs
'Let the user select the view and polygon theme
theViewList = List.Make
for each theDoc in theDocs
if (theDoc.GetClass.GetClassName = "view") then
theViewList.Add(theDoc)
end
end
theView = msgbox.Choice (theViewList,"Select the view containing the polygon theme you wish to convert","Select a View")
if (theView.GetName = "") then
Exit
end
theProjection = theView.GetProjection
if (theProjection <> "") then
msgbox.info ("It was determined that the view is projected." + NL + NL +
"Please un-project the view then re-run the conversion.","ERROR - VIEW IS PROJECTED")
Exit
end
theThemeList = theView.GetThemes
thePolyThemeList = List.Make
for each theThm in theThemeList
if (theThm.GetSrcName.GetSubName = "polygon") then
thePolyThemeList.Add(theThm)
end
end
theTheme = msgbox.Choice (theThemeList,"Select the polygon theme you wish to convert",theView.GetName + ": Select a Theme")
if (theTheme.GetName = "") then
Exit
end
theTList = List.Make
for each theView in theViewList
theTs = theView.GetThemes
for each theT in theTs
if (theT.GetSrcName.AsString = theTheme.GetSrcName.AsString) then
theTList.Add(theT)
end
end
end
if (theTList.Count > 1) then
msgbox.WARNING ("The same theme exists in other views in this project." + NL + NL + "Please create a unique shapefile from the theme before running this utility.","WARNING - DUPLICATE THEME EXISTS IN PROJECT")
Exit
end
theFullThemeName = theTheme.GetFTab.GetName
thePeriod = theFullThemeName.Indexof(".")
theThemeName = theFullThemeName.Left(thePeriod)
'Add the polygon centroid to the theme's table
theFTab = theTheme.GetFTab
theFTab.SetEditable(True)
if (theFTab.IsEditable) then
X = Field.Make ("X",#FIELD_DECIMAL,18,5)
Y = Field.Make ("Y",#FIELD_DECIMAL,18,5)
theFTab.AddFields({X,Y})
theFTab.Calculate("[Shape].ReturnCenter.GetX",X)
theFTab.Calculate("[Shape].ReturnCenter.GetY",Y)
end
theFTab.SetEditable(False)
'Create a point event theme and add it to the view
theEventTheme = XYName.Make(theFTab,X,Y)
theEventTheme = Theme.Make(theEventTheme)
theEventTheme.SetName(theThemeName + "_pt")
theView.AddTheme(theEventTheme)
theEventTheme.SetVisible(True)
msgbox.info ("A new point theme ( " + theEventTheme.GetName + " ) has been added to the " + theView.GetName + " view.","NEW POINT THEME ADDED TO VIEW")
' Called by:
' Runs:
' Self:
' Returns: Nothing
end
end
Exit
end
Exit
end
end
end
Exit
end
theTList.Add(theT)
end
end
end
Exit
end
end
greengo
Огромное спасибо
roof2005
Кто-нибудь может помочь, как воспользоваться этим кодом?
Простая вставка его в окно питона не работает ØD
Надо что-то где-то заменить?
roof2005
Решил проблему следующим образом:
1) Feature to point
2) Add XY to point
1) Feature to point
2) Add XY to point
dime1
Точка в центре полигона называется центроид, спокойно автоматически выставляется в атрибутивной таблице через Calculate Geometry.
