Уважаемые Гуру!
Если не сложно, где можно посмотреть - как определить какому полигону принадлежит точка с координатами x,y?
(arcgis engine 2010, c#+ vs 2010)
Как определить полигон, которому принадлежит точка x,y
Tereha
- Дмитрий Барышников
Tereha
Re: Как определить полигон, которому принадлежит точка x,y
Спасибо, огромное!
///<summary>Finds all the features in a GeoFeature layer by supplying a point. The point could come from a mouse click on the map.</summary>
///<param name="searchTolerance">A System.Double that is the number of map units to search. Example: 25</param>
///<param name="point">An IPoint interface in map units where the user clicked on the map</param>
///<param name="geoFeatureLayer">An ILayer interface to search upon</param>
///<param name="activeView">An IActiveView interface</param>
///<returns>An IFeatureCursor interface is returned containing all the selected features found in the GeoFeatureLayer.</returns>
///<remarks></remarks>
public ESRI.ArcGIS.Geodatabase.IFeatureCursor GetAllFeaturesFromPointSearchInGeoFeatureLayer(System.Double searchTolerance, ESRI.ArcGIS.Geometry.IPoint point, ESRI.ArcGIS.Carto.IGeoFeatureLayer geoFeatureLayer, ESRI.ArcGIS.Carto.IActiveView activeView)
if (searchTolerance < 0 || point == null || geoFeatureLayer == null || activeView == null)
return null;
ESRI.ArcGIS.Carto.IMap map = activeView.FocusMap;
// Expand the points envelope to give better search results
ESRI.ArcGIS.Geometry.IEnvelope envelope = point.Envelope;
envelope.Expand(searchTolerance, searchTolerance, false);
ESRI.ArcGIS.Geodatabase.IFeatureClass featureClass = geoFeatureLayer.FeatureClass;
System.String shapeFieldName = featureClass.ShapeFieldName;
// Create a new spatial filter and use the new envelope as the geometry
ESRI.ArcGIS.Geodatabase.ISpatialFilter spatialFilter = new ESRI.ArcGIS.Geodatabase.SpatialFilterClass();
spatialFilter.Geometry = envelope;
spatialFilter.SpatialRel = ESRI.ArcGIS.Geodatabase.esriSpatialRelEnum.esriSpatialRelEnvelopeIntersects;
spatialFilter.set_OutputSpatialReference(shapeFieldName, map.SpatialReference);
spatialFilter.GeometryField = shapeFieldName;
// Do the search
ESRI.ArcGIS.Geodatabase.IFeatureCursor featureCursor = featureClass.Search(spatialFilter, false);
return featureCursor;
}Кто сейчас на конференции
