copy infomation in Mapinfo !
- hoangdiep
I want information of the class and copy this data pasted into other data layers, is there a way to do it? you please help me!
- Игорь Белов
Re: copy infomation in Mapinfo !
Fisrt method:
1. Make layer A editable.
2. Select objects from layer B.
3. Copy and paste.
Second method:
1. Select objects from layer B.
2. [Table] → [Append Rows to Table...] and choose tables Selection as source and A as target.
3. Copy and paste.
Second method:
- hoangdiep
thank you!
but me want to copy the property not is the map!
- Игорь Белов
What do you mean by "property"? Object style such as colour or attribute data from table?
- hoangdiep
Yes ! I want it !
- Игорь Белов
Suppose we wish to convey object styles. I would prefer MapCAD. If your MapInfo version is 9.5, you have to install MapCAD from installation CD. If newer, then MapCAD is already at hand. In both cases you must activate it by tool manager:
[Tools] → [Tool Manager…]
New toolbars appear: MapCAD and Objects. Find Copy Style and Paste Style buttons.
- Select model object
- Press Copy Style
- Make wanted layer editable
- Select target object(s)
- Press Paste Style
- MapCAD.png (22.67 КБ) 8095 просмотров
- hoangdiep
Thank you !
But I want copy attribute data from table !
- Игорь Белов
SQL Queries 1
In fisrt sample we shall add new field.
I have a map layer ‘Country’ with the attribute table of the sort
and I have a table ‘Classes’ of all code meanings:
Let's apply SQL query:
[Query] → [SQL Select…]
(see picture below for details) and obtain ‘Country2’ table:
Let's save ‘Country2’:
[File] → [Save Copy As…]
ID Code
1 2
2 3
3 1
4 1
5 2
6 2
No Descriptio
1 Water
2 Forest
3 Field
ID Code Descriptio
1 2 Forest
2 3 Field
3 1 Water
4 1 Water
5 2 Forest
6 2 Forest
- Country2.png (5.6 КБ) 8073 просмотра
- Игорь Белов
SQL Queries 2
In second sample we shall fill existing field.
I have a map layer ‘Country’ with the attribute table of the sort:
(see picture below for details) and obtain ‘Query1’ table:
Now modify ‘Query1’ table filling ‘Feature’ column with ‘Descriptio’ values:
[Table] → [Update Column…]
(see second picture below for details).
Eventually save ‘Country’:
[File] → [Save Table…]
ID Code Feature
1 2 NULL
2 3 NULL
3 1 NULL
4 1 NULL
5 2 NULL
6 2 NULL
No Descriptio
1 Water
2 Forest
3 Field
ID Code Feature Descriptio
1 2 NULL Forest
2 3 NULL Field
3 1 NULL Water
4 1 NULL Water
5 2 NULL Forest
6 2 NULL Forest
1 2 Forest Forest
2 3 Field Field
3 1 Water Water
4 1 Water Water
5 2 Forest Forest
6 2 Forest Forest
- Query1.png (5.67 КБ) 8072 просмотра
- UpdateColumn.png (3.57 КБ) 8072 просмотра
