copy infomation in Mapinfo !
MapInfo, MapBasic
hoangdiep
Сообщение hoangdiep » 17 май 2012, 08:18
I want information of the class and copy this data pasted into other data layers, is there a way to do it? you please help me!
Re: copy infomation in Mapinfo !
Сообщение Игорь Белов » 17 май 2012, 10:35
Fisrt method:
1. Make layer A editable.
2. Select objects from layer B.
3. Copy and paste.
Second method:
1. Select objects from layer B.
2. [Table] → [Append Rows to Table...] and choose tables Selection as source and A as target.
hoangdiep
Сообщение hoangdiep » 18 май 2012, 11:54
thank you!
but me want to copy the property not is the map!
Сообщение Игорь Белов » 18 май 2012, 13:45
What do you mean by "property"? Object style such as colour or attribute data from table?
hoangdiep
Сообщение hoangdiep » 21 май 2012, 08:02
Yes ! I want it !
Сообщение Игорь Белов » 21 май 2012, 09:09
Suppose we wish to convey object styles. I would prefer MapCAD. If your MapInfo version is 9.5, you have to install MapCAD from installation CD. If newer, then MapCAD is already at hand. In both cases you must activate it by tool manager:
[Tools] → [Tool Manager…]
New toolbars appear: MapCAD and Objects. Find Copy Style and Paste Style buttons.
  • Select model object
  • Press Copy Style
  • Make wanted layer editable
  • Select target object(s)
  • Press Paste Style
MapCAD comes with comprehensive help.
hoangdiep
Сообщение hoangdiep » 21 май 2012, 10:35
Thank you !
But I want copy attribute data from table !
Сообщение Игорь Белов » 21 май 2012, 11:31
SQL Queries 1
In fisrt sample we shall add new field.
I have a map layer ‘Country’ with the attribute table of the sort
ID Code
 1    2
 2    3
 3    1
 4    1
 5    2
 6    2
and I have a table ‘Classes’ of all code meanings:
No Descriptio
 1 Water
 2 Forest
 3 Field
Let's apply SQL query:
[Query] → [SQL Select…]
(see picture below for details) and obtain ‘Country2’ table:
ID Code Descriptio
 1    2 Forest
 2    3 Field
 3    1 Water
 4    1 Water
 5    2 Forest
 6    2 Forest
Let's save ‘Country2’:
[File] → [Save Copy As…]
Сообщение Игорь Белов » 21 май 2012, 12:04
SQL Queries 2
In second sample we shall fill existing field.
I have a map layer ‘Country’ with the attribute table of the sort:
ID Code Feature
 1    2 NULL
 2    3 NULL
 3    1 NULL
 4    1 NULL
 5    2 NULL
 6    2 NULL
No Descriptio
 1 Water
 2 Forest
 3 Field
(see picture below for details) and obtain ‘Query1’ table:
ID Code Feature Descriptio
 1    2 NULL    Forest
 2    3 NULL    Field
 3    1 NULL    Water
 4    1 NULL    Water
 5    2 NULL    Forest
 6    2 NULL    Forest
Now modify ‘Query1’ table filling ‘Feature’ column with ‘Descriptio’ values:
[Table] → [Update Column…]
(see second picture below for details).
 1    2 Forest  Forest
 2    3 Field   Field
 3    1 Water   Water
 4    1 Water   Water
 5    2 Forest  Forest
 6    2 Forest  Forest
Eventually save ‘Country’:
[File] → [Save Table…]
Вернуться в «MapInfo»
