WMSGetFeatureInfo и GeoExt.Popup
yarovka
Сообщение yarovka » 15 фев 2012, 18:52
Доброго дня суток!
никак не могу заставить появиться popup на моей карте:
<script type="text/javascript">
Ext.onReady(function() {
var map = new OpenLayers.Map();
var googlemapsatellite = new OpenLayers.Layer.Google("Google Satellite", {type: G_SATELLITE_MAP});
googlemapsatellite.setIsBaseLayer(true);
map.addLayer(googlemapsatellite);
var layers = [
new OpenLayers.Layer.WMS("слой 1", "мой_слой",
layers: "мой_слой",
transparent: true
{reproject: true},
isBaseLayer: false,
buffer: 0
new OpenLayers.Layer.WMS("Слой 2", "мой_второй_слой",
transparent: "TRUE",
layers: "мой_второй_слой",
{reproject: true},
isBaseLayer: false,
buffer: 0
var mappanel = new GeoExt.MapPanel({
renderTo: 'gxmap',
height: 600,
width: 750,
map: map,
title: 'Basic Map',
center: [-7.92114,42.90816],
zoom: 8,
layers: layers
var tree = new Ext.tree.TreePanel({
renderTo: 'layers',
border: true,
region: "west",
title: "Layers",
height: 600,
width: 250,
root: {},
rootVisible: false,
enableDD: true
tree.render(document.body);
var node = new GeoExt.tree.BaseLayerContainer({text: "Base Layers"});
tree.root.appendChild(node);
var node = new GeoExt.tree.OverlayLayerContainer({
text: "Overlay Layers",
expanded: true
node.eachChild(function(child) {
child.ui.toggleCheck(false);
var legendPanel = new GeoExt.LegendPanel({
title: "Legend",
renderTo: "legend",
defaults: {
style: 'padding:5px'
width: 250,
height: 600,
border: true,
bodyStyle: 'padding:5px'
legendPanel.render(document.body);
controls.push(new OpenLayers.Control.WMSGetFeatureInfo({
autoActivate: true,
infoFormat: "text/plain",
maxFeatures: 3,
eventListeners: {
"getfeatureinfo": function(e) {
var items = [];
Ext.each(e.features, function(feature) {
items.push({
xtype: "propertygrid",
title: feature.fid,
source: feature.attributes
new GeoExt.Popup({
title: "Feature Info",
width: 200,
height: 200,
layout: "accordion",
map: mappanel.map,
items: items
}).show();
</script>
По задумке GetFeatureInfo должен выводить данные из слоя shape. Пробовала работать со слоями в QuantumGIS, все получается - данные читаются.
А на веб-карте popup просто не появляется и все, сколько ни кликай!
Если кто-нибудь знаком с GeoExt и сталкивался с подобной проблемой, или кто может предложить другой вариант решения аналогичной задачи, помогите, пожалуйста!
Ваше звание: Author
Re: WMSGetFeatureInfo и GeoExt.Popup
Сообщение Denis Rykov » 15 фев 2012, 20:03
Работающий пример:
//Контрол WMSGetFeatureInfo
map.addControl(
autoActivate: true,
infoFormat: 'application/vnd.ogc.gml',
maxFeatures: 1000,
layers: [lay_herbary],
queryVisible: true,
eventListeners: {
'getfeatureinfo': function(e) {
new GeoExt.Popup({
title: "Информация об объектах",
width: 600,
height: 320,
map: map,
html: "<div>Popup content</div>"
}).show();
Не увидел в вашем фрагменте кода описания того, что такое controls.
yarovka
Сообщение yarovka » 15 фев 2012, 21:18
Добавила ваш кусок в мой код. И страница не грузится. FireBug не указывает на ошибки.
yarovka
Сообщение yarovka » 15 фев 2012, 21:30
Аааа, заработала! :) Как всегда, потеряла скобку :) Огромнейшее преогромнейшее спасибо! Теперь как-то надо связать этот popup с данными моих слоев... Чтобы он выдавал атрибуты из .dbf
Вернуться в «Веб-картография»
Сейчас этот форум просматривают: Ahrefs [Bot] и 2 гостя
