Geoserver + Geowebcash
Кроме QGIS
mgramin
Сообщение mgramin »
Придеплоил war-файлы Geoserver'а и Geowebcash'а к Tomcat - все впорядке.
Теперь если первым запускается Geoserver, то не работет Geowebcash:
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: Servlet.init() for servlet geowebcache threw exception
	org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
	org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100)
	org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:929)
	org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:405)
	org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:279)
	org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:515)
	org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:302)
	java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
	java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
	java.lang.Thread.run(Thread.java:662)
root cause
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcRestDispatcher' defined in ServletContext resource [/WEB-INF/geowebcache-rest-context.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geowebcache.rest.RESTDispatcher]: Constructor threw exception; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcDiskQuotaRestDispatcher' defined in ServletContext resource [/WEB-INF/geowebcache-diskquota-context.xml]: Cannot resolve reference to bean 'gwdDiskQuotaResourcetFinder' while setting bean property 'routes' with key [TypedStringValue: value [/diskquota/{layer}.{extension}"], target type [null]]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwdDiskQuotaResourcetFinder' defined in ServletContext resource [/WEB-INF/geowebcache-diskquota-context.xml]: Cannot resolve reference to bean 'DiskQuotaMonitor' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'DiskQuotaMonitor' defined in ServletContext resource [/WEB-INF/geowebcache-diskquota-context.xml]: Cannot resolve reference to bean 'DiskQuotaStore' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'DiskQuotaStore' defined in ServletContext resource [/WEB-INF/geowebcache-diskquota-context.xml]: Invocation of init method failed; nested exception is com.sleepycat.je.EnvironmentLockedException: (JE 4.1.7) /home/maksim/Programms/apache-tomcat-7.0.20/temp/geowebcache/diskquota_page_store The environment cannot be locked for single writer access. ENV_LOCKED: The je.lck file could not be locked. Environment is invalid and must be closed.
	org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:883)
	org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:839)
	org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
	org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
	java.security.AccessController.doPrivileged(Native Method)
	org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
	org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
	org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
	org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
	org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
	org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
	org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
	org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
	org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
	org.springframework.web.servlet.FrameworkServlet.createWebApplicationContext(FrameworkServlet.java:402)
	org.springframework.web.servlet.FrameworkServlet.initWebApplicationContext(FrameworkServlet.java:316)
	org.springframework.web.servlet.FrameworkServlet.initServletBean(FrameworkServlet.java:282)
	org.springframework.web.servlet.HttpServletBean.init(HttpServletBean.java:126)
	javax.servlet.GenericServlet.init(GenericServlet.java:160)
root cause
	org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:115)
	org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:61)
	org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:877)
Если наоборот, то:
2011-09-01 21:26:38,846 INFO [jdbc.JDBCMBWrapper] - MetaStore database is version 120
2011-09-01 21:26:38,865 INFO [config.XMLConfiguration] - Failed to find geowebcache.xml. This is not a problem unless you are trying to use a custom XML configuration file.
2011-09-01 21:26:39,506 INFO [layer.TileLayerDispatcher] - Adding layers from GeoServer Catalog Configuration
2011-09-01 21:26:39,506 INFO [layer.TileLayerDispatcher] - Adding: tiger-ny
2011-09-01 21:26:39,506 INFO [layer.TileLayerDispatcher] - Adding: tiger:poly_landmarks
2011-09-01 21:26:39,507 INFO [layer.TileLayerDispatcher] - Adding: nurc:Arc_Sample
2011-09-01 21:26:39,507 INFO [layer.TileLayerDispatcher] - Adding: spearfish
2011-09-01 21:26:39,507 INFO [layer.TileLayerDispatcher] - Adding: tiger:giant_polygon
2011-09-01 21:26:39,507 INFO [layer.TileLayerDispatcher] - Adding: sf:roads
2011-09-01 21:26:39,507 INFO [layer.TileLayerDispatcher] - Adding: tiger:tiger_roads
2011-09-01 21:26:39,507 INFO [layer.TileLayerDispatcher] - Adding: nurc:Img_Sample
2011-09-01 21:26:39,507 INFO [layer.TileLayerDispatcher] - Adding: sf:archsites
2011-09-01 21:26:39,507 INFO [layer.TileLayerDispatcher] - Adding: sf:restricted
2011-09-01 21:26:39,507 INFO [layer.TileLayerDispatcher] - Adding: sf:sfdem
2011-09-01 21:26:39,507 INFO [layer.TileLayerDispatcher] - Adding: tasmania
2011-09-01 21:26:39,507 INFO [layer.TileLayerDispatcher] - Adding: topp:tasmania_roads
2011-09-01 21:26:39,507 INFO [layer.TileLayerDispatcher] - Adding: topp:tasmania_cities
2011-09-01 21:26:39,508 INFO [layer.TileLayerDispatcher] - Adding: topp:tasmania_water_bodies
2011-09-01 21:26:39,508 INFO [layer.TileLayerDispatcher] - Adding: topp:tasmania_state_boundaries
2011-09-01 21:26:39,508 INFO [layer.TileLayerDispatcher] - Adding: sf:streams
2011-09-01 21:26:39,508 INFO [layer.TileLayerDispatcher] - Adding: nurc:mosaic
2011-09-01 21:26:39,508 INFO [layer.TileLayerDispatcher] - Adding: nurc:Pk50095
2011-09-01 21:26:39,508 INFO [layer.TileLayerDispatcher] - Adding: topp:states
2011-09-01 21:26:39,508 INFO [layer.TileLayerDispatcher] - Adding: sf:bugsites
2011-09-01 21:26:39,508 INFO [layer.TileLayerDispatcher] - Adding: tiger:poi
2011-09-01 21:26:39,508 ERROR [config.XMLConfiguration] - Configuration file cannot be read or does not exist!
2011-09-01 21:26:39,509 INFO [config.XMLConfiguration] - Found configuration file in /home/maksim/Programms/apache-tomcat-7.0.20/webapps/geoserver/../resources
2011-09-01 21:26:39,509 INFO [layer.TileLayerDispatcher] - Adding layers from /home/maksim/Programms/apache-tomcat-7.0.20/webapps/geoserver/../resources
2011-09-01 21:26:39,509 ERROR [layer.TileLayerDispatcher] - Configuration /home/maksim/Programms/apache-tomcat-7.0.20/webapps/geoserver/../resources contained no layers.
2011-09-01 21:26:39,510 ERROR [layer.TileLayerDispatcher] - Error reading service information from /home/maksim/Programms/apache-tomcat-7.0.20/webapps/geoserver/../resources: Error parsing file /home/maksim/Programms/apache-tomcat-7.0.20/webapps/geoserver/../resources/geowebcache.xml
2011-09-01 21:26:39,510 INFO [layer.TileLayerDispatcher] - ConfigurationLoader completed
2011-09-01 21:26:39,588 WARN [storage.EntityStoreBuilder] - Neither disk quota page store' cache memory percent nor cache size was provided. Defaulting to 25% Heap Size
2011-09-01 21:26:39,677 INFO [seed.SeederThreadPoolExecutor] - Initiating shut down for running and pending seed tasks...
2011-09-01 21:26:39,677 INFO [seed.SeederThreadPoolExecutor] - Seeder thread pool executor shut down complete.
2011-09-01 21:26:39,677 INFO [storage.StorageBroker] - Destroying StorageBroker
2011-09-01 21:26:42,986 WARN [jdbc.JDBCMBWrapper] - SHUTDOWN call to JDBC resulted in: Connection is broken [90067-119]
2011-09-01 21:26:44,325 INFO [geoserver.catalog] - Disposing datastore 'DataStoreInfoImpl--570ae188:124761b8d78:-7fdb'
2011-09-01 21:26:44,326 INFO [geoserver.catalog] - Disposing datastore 'DataStoreInfoImpl--570ae188:124761b8d78:-7fda'
2011-09-01 21:26:44,326 INFO [geoserver.catalog] - Disposing datastore 'DataStoreInfoImpl--570ae188:124761b8d78:-7fdc'
2011-09-01 21:26:44,326 INFO [geoserver.catalog] - Disposing datastore 'DataStoreInfoImpl--570ae188:124761b8d78:-7fd9'
2011-09-01 21:26:44,326 INFO [geoserver.catalog] - Disposing grid coverage reader 'sfdem'
2011-09-01 21:26:44,326 INFO [geoserver.catalog] - Disposing grid coverage reader 'arcGridSample'
2011-09-01 21:26:44,326 INFO [geoserver.catalog] - Disposing grid coverage reader 'worldImageSample'
2011-09-01 21:26:44,326 INFO [geoserver.catalog] - Disposing grid coverage reader 'img_sample2'
2011-09-01 21:26:44,326 WARN [geoserver.catalog] - Error occured disposing coverage reader 'img_sample2'
2011-09-01 21:26:44,326 INFO [geoserver.catalog] - Disposing grid coverage reader 'mosaic'
2011-09-01 21:26:44,327 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcFacade' defined in URL [jar:file:/home/maksim/Programms/apache-tomcat-7.0.20/webapps/geoserver/WEB-INF/lib/gwc-2.1.1.jar!/geowebcache-geoserver-context.xml]: Cannot resolve reference to bean 'DiskQuotaStore' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'DiskQuotaStore' defined in URL [jar:file:/home/maksim/Programms/apache-tomcat-7.0.20/webapps/geoserver/WEB-INF/lib/gwc-2.1.1.jar!/geowebcache-diskquota-context.xml]: Invocation of init method failed; nested exception is com.sleepycat.je.EnvironmentLockedException: (JE 4.1.7) /home/maksim/Programms/apache-tomcat-7.0.20/temp/geowebcache/diskquota_page_store The environment cannot be locked for single writer access. ENV_LOCKED: The je.lck file could not be locked. Environment is invalid and must be closed.
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:275)
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
	at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
	at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
	at java.security.AccessController.doPrivileged(Native Method)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
	at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
	at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
	at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
	at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
	at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
	at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
	at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
	at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
	at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
	at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
	at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
	at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:18)
	at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4723)
	at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5226)
	at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5221)
	at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
	at java.util.concurrent.FutureTask.run(FutureTask.java:138)
	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
	at java.lang.Thread.run(Thread.java:662)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'DiskQuotaStore' defined in URL [jar:file:/home/maksim/Programms/apache-tomcat-7.0.20/webapps/geoserver/WEB-INF/lib/gwc-2.1.1.jar!/geowebcache-diskquota-context.xml]: Invocation of init method failed; nested exception is com.sleepycat.je.EnvironmentLockedException: (JE 4.1.7) /home/maksim/Programms/apache-tomcat-7.0.20/temp/geowebcache/diskquota_page_store The environment cannot be locked for single writer access. ENV_LOCKED: The je.lck file could not be locked. Environment is invalid and must be closed.
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1337)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
	... 29 more
Caused by: com.sleepycat.je.EnvironmentLockedException: (JE 4.1.7) /home/maksim/Programms/apache-tomcat-7.0.20/temp/geowebcache/diskquota_page_store The environment cannot be locked for single writer access. ENV_LOCKED: The je.lck file could not be locked. Environment is invalid and must be closed.
	at com.sleepycat.je.log.FileManager.<init>(FileManager.java:350)
	at com.sleepycat.je.dbi.EnvironmentImpl.<init>(EnvironmentImpl.java:439)
	at com.sleepycat.je.dbi.EnvironmentImpl.<init>(EnvironmentImpl.java:340)
	at com.sleepycat.je.dbi.DbEnvPool.getEnvironment(DbEnvPool.java:195)
	at com.sleepycat.je.Environment.makeEnvironmentImpl(Environment.java:229)
	at com.sleepycat.je.Environment.<init>(Environment.java:211)
	at com.sleepycat.je.Environment.<init>(Environment.java:165)
	at org.geowebcache.diskquota.storage.EntityStoreBuilder.buildEntityStore(EntityStoreBuilder.java:61)
	at org.geowebcache.diskquota.storage.BDBQuotaStore.configure(BDBQuotaStore.java:158)
	at org.geowebcache.diskquota.storage.BDBQuotaStore.startUp(BDBQuotaStore.java:117)
	at org.geowebcache.diskquota.storage.BDBQuotaStore.afterPropertiesSet(BDBQuotaStore.java:102)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1368)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1334)
	... 39 more
Насколько я понимаю, происходит конфликт двух кешировщиков - встроенного gwc и Geowebcash.
Как объяснить Geoserver'у, что не нужно загружать gwc?
mgramin
Re: Geoserver + Geowebcash
Сообщение mgramin »
Неужели никто не ставил Geoserver + Geowebcash?! Поделитесь пожалуйста опытом.
Mavka
Сообщение Mavka »
Попробуйте откатиться на Tomcat 6
В рассылке по старым версиям: Geoserver doesn't start after installing GeoWebCache
mgramin
Сообщение mgramin »
Спасибо уважаемый Mavka, будут пробовать. Если кому интересно потом отпишусь.
