Странная ощибка GetFeatureInfo
Protectr
Сообщение Protectr »
Доброго времени суток!
Обращаюсь к вам за советом , а проблема вот в чем:
Пытаюсь отобразить атрибуты Shape слоя в Popup
Использую Openlayers+Mapserver
Popup отображаеться по клику , но вместо атрибутов в нем вот это :
#!/usr/bin/env python """This is a blind proxy that we use to get around browser restrictions that prevent the Javascript from loading pages not on the same server as the Javascript. This has several problems: it's less efficient, it might break some sites, and it's a security risk because people can use this proxy to browse the web and possibly do bad stuff with it. It only loads pages via http and https, but it can load any content type. It supports GET and POST requests.""" import urllib2 import cgi import sys, os # Designed to prevent Open Proxy type stuff. allowedHosts = ['www.openlayers.org', 'openlayers.org', 'labs.metacarta.com', 'world.freemap.in', 'prototype.openmnnd.org', 'geo.openplans.org', 'sigma.openplans.org', 'demo.opengeo.org', 'www.openstreetmap.org', 'sample.azavea.com', 'v-swe.uni-muenster.de:8080', 'vmap0.tiles.osgeo.org'] method = os.environ["REQUEST_METHOD"] if method == "POST": qs = os.environ["QUERY_STRING"] d = cgi.parse_qs(qs) if d.has_key("url"): url = d["url"][0] else: url = "http://www.openlayers.org" else: fs = cgi.FieldStorage() url = fs.getvalue('url', "http://www.openlayers.org") try: host = url.split("/")[2] if allowedHosts and not host in allowedHosts: print "Status: 502 Bad Gateway" print "Content-Type: text/plain" print print "This proxy does not allow you to access that location (%s)." % (host,) print print os.environ elif url.startswith("http://") or url.startswith("https://"): if method == "POST": length = int(os.environ["CONTENT_LENGTH"]) headers = {"Content-Type": os.environ["CONTENT_TYPE"]} body = sys.stdin.read(length) r = urllib2.Request(url, body, headers) y = urllib2.urlopen(r) else: y = urllib2.urlopen(url) # print content type header i = y.info() if i.has_key("Content-Type"): print "Content-Type: %s" % (i["Content-Type"]) else: print "Content-Type: text/plain" print print y.read() y.close() else: print "Content-Type: text/plain" print print "Illegal request." except Exception, E: print "Status: 500 Unexpected Error" print "Content-Type: text/plain" print print "Some unexpected error occurred. Error text was:", E
Кто раньше стыкался? помогите !
вот как я это делаю
info = new OpenLayers.Control.WMSGetFeatureInfo({
            url: 'http://localhost:8080/WMSTileCache-V0.2/WMS/water',
            title: '',
            queryVisible: true,
            eventListeners: {
                getfeatureinfo: function(event) {
                    map.addPopup(new OpenLayers.Popup.FramedCloud(
                        "chicken",
                        map.getLonLatFromPixel(event.xy),
                        null,
                        event.text,
                        null,
                        true
        map.addControl(info);
        info.activate();
Последний раз редактировалось Protectr 29 апр 2011, 22:36, всего редактировалось 2 раза.
Protectr
Re: Странная ощибка GetFeatureInfo
Если у кого-нибудь есть рабочий пример вывода атрибутов в попап - скидывайте , на примерах легче учиться.
Сообщение Voltron »
Нагуглилось. Официальный пример
P.S. Пожалуйста, пользуйте тегами
 и [quote] для кода и больших объемов текста, а то читать жутко неудобно.
Protectr
Я использую Тilecache , может это в нем причина?
Оффициальный пример с сайта работает отлично , но его исходник у меня на машине выдает ту же ошибку
(текст ошибки в попапе)
Protectr
Прошу написать простой рабочий пример кода !!!
Mavka
Сообщение Mavka »
Protectr
Кэш хранит только тайлы. Что бы ответить на GetFeatureInfo, ему нужно обратиться на сервер WMS. GeoJazzy не умеет пробрасывать такие запросы. (В GWC такая возможность есть.)
На уровне OpenLayers можно подменять url.
Protectr
Спасибо , почитал !
Но какой будет url_straight в моем случае?
Будет чтото вроде:
http://localhost/cgi-bin/mapserv.exe?ma ... t&mode=map ????
тогда в массив layerUrls вписываем URL кешированной картики?
правильно понимаю ???
Protectr
Делаю так , все равно в попапе вылазит та же билеберда что я описывал ....
            url: 'http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/example/polt.map&layer=veget&mode=map',    #STRAIGHT URL
			layerUrls:['http://localhost:8080/WMSTileCache-V0.2/WMS/water'],   #URL КЕШИРОВАННОГО ИЗОБРАЖЕНИЯ
            title: '123',
            queryVisible: true,
            eventListeners: {
                        "chicken",
                        null,
                        event.text,
                        null,
                        true
        info.activate();
странно что если поменять
event.text
на
event.ху
то в попапе спокойно отображаються координаты щелчка!!! :evil:
Protectr
Неужели никто не поможет ????
Protectr
Я так понял нужно изменить файл PROXY.CGI
Я это сделал добавил в AllowedHosts все что нужно:
                'vmap0.tiles.osgeo.org','/cgi-bin/proxy.cgi?url=',"localhost:8080"]
и прописал в основном НTML OpenLayers.ProxyHost = "/cgi-bin/proxy.cgi?url=";
но результат тот же , что еще не так?
Mavka
Re: Странная ошибка GetFeatureInfo
Сообщение Mavka »
У вас по ходу прокси-скрипт не срабатывает и отдается чистым текстом.
Гляньте здесь раздел Cross-domain security.
Последний раз редактировалось Mavka 03 май 2011, 13:50, всего редактировалось 1 раз.
Mavka
Сообщение Mavka »
Так как у вас и сайт и mapserver работают на одном и том же веб-сервере (apache), то использовать прокси по идее не нужно. Уберите OpenLayers.ProxyHost.
Последний раз редактировалось Mavka 03 май 2011, 13:53, всего редактировалось 2 раза.
Mavka
Сообщение Mavka »
Кусок кода из моего рабочего проекта:
click_ctrl = new OpenLayers.Control.WMSGetFeatureInfo({
    url: url_server_2,
    layerUrls: [url_server_1],
    layers: [lay_points],
    queryVisible: true
click_ctrl.events.register('getfeatureinfo', this, point_click);
map.addControl(click_ctrl);
click_ctrl.activate();
Функция point_click описана отдельно.
Protectr
А что у вас значат строки
url: url_server_2,
ато я не совсем понял?
Mavka
Сообщение Mavka »
layers - вероятно, можно убрать совсем.
layerUrls - тоже что и у вас, переменная содержащая строку-адрес сервера
Вернуться в «Веб-картография»
