ENVI stereo
AndreyL
ENVI stereo
Сообщение AndreyL »
Вопрос такой - можно ли в ЭНВИ посмотреть стереопару? Типа "красный-синий", как в ЭРДАС-е. У меня почему-то справка по ЭНВИ не работает (тоже, кстати, не понятно)
Ваше звание: хрюкало
Re: ENVI stereo
Сообщение nadiopt »
а небсоь недоустановили справку
вот вам извлечение:
Building Epipolar Images
The DEM Extraction Module provides a stand-alone tool that enables you to build epipolar images from a stereo pair. The Build Epipolar Images menu item is accessed by selecting Topographic → DEM Extraction → Build Epipolar Images from the ENVI main menu bar. Use this menu option to create epipolar image pairs that can be used for DEM extraction or viewed with ENVI's Epipolar 3D Cursor Tool (see Epipolar 3D Cursor Tool for details).
From the ENVI main menu bar, select Topographic → DEM Extraction → Build Epipolar Images. The Select Left Stereo Pair Image dialog opens. See Step 1: Selecting the Stereo Image Pair for instructions on opening the left and right image stereo pair.
When you click OK in the Select Right Stereo Pair Image dialog, the Select Input Tie Points File dialog opens.
Navigate to the directory and filename where the tie point information is stored. (See Selecting Stereo Tie Points for information about selecting tie points and saving them to a file.) Click Open. The Build Epipolar Images Parameters dialog opens.
The Build Epipolar Images Parameters dialog allows you to select an Epipolar Reduction Factor and whether to save the output images to a file or to memory. See Step 6: Generating Epipolar Images for details of the parameters.
To view the epipolar results, select Topographic → DEM Extraction → Epipolar 3D Cursor from the ENVI main menu bar, or use the RGB setting in the Available Bands List and select the Left Epipolar Image for the red band, and the Right Epipolar Image for both the green and the blue bands. Load the RGB image to a display group.
Use anaglyph glasses to view the 3D image.
AndreyL
Re: ENVI stereo
Сообщение AndreyL »
Ага, спасибо! Т.е. это в ДЕМ-экстракторе было.
А как это "недоустановили справку"? При установке галочка на хелпе стояла, сама программа "envihelp.exe" имеется, только она через пару секунд после запуска сама закрывается ни слова не говоря.
Re: ENVI stereo
Сообщение nadiopt »
хм вот уж не знаю:(
у меня энви 4.7 все работает
AndreyL
Re: ENVI stereo
Сообщение AndreyL »
у меня 4.6 на х64
AndreyL
Re: ENVI stereo
Сообщение AndreyL »
Я только не понял, откуда он берет высоту? Когда смотрю с в режиме Epipolar 3D Cursor этот самый курсор меняет расстояние между красным и синим в зависимости от высоты. И не всегда правильно.
Re: ENVI stereo
Сообщение Boris »
AndreyL писал(а):у меня 4.6 на х64
не работает в ней хелп - пытается запустить локальный сервер и к нему обращаться. на этом и умирает. я для того беру хелп от 4,5
Вернуться в «Обработка ДДЗ»
