The DigitalGlobe 8-Band Research Challenge
- syroezhka
Re: The DigitalGlobe 8-Band Research Challenge
И на тот, который заявку 8bandchallenge@....., и на тот, который указан в "Terms and conditions" 8-Band_Challenge@....
тоже написал на оба еще раз
неужели сложно нормальную систему приема заявок сделать...
Анна
Отпостила им на linkedin'е этот вопрос - про получение заявок.
См. скриншоты.
Надеюсь ответ будет)
См. скриншоты.
- screen2.jpg (107.07 КБ) 11901 просмотр
- nadiopt
- Ваше звание: хрюкало
мне пришло подтверждение еще 30 августа
Greetings
This email is to confirm that we have received your application for the 8-Band Challenge ahead of the 31 August, 2010 deadline. We are in the process of reviewing all the proposals we have received. The response to this challenge has been overwhelming, and as a result the competition is quite strong. On 15 September, 2010, we will be notifying all individuals whose proposals have been accepted for the 8-Band Challenge. Prior to this date, you may be contacted, regarding clarifications to your proposal.
If you receive another email alerting you to the 31 August, 2010 deadline, please ignore it. You do not need to re-submit your proposal.
Thank you for your interest in DigitalGlobe and our 8-band Imagery.
Sincerely,
Greetings
Sincerely,
Анна
Вот так вот ответили на вопрос:
* Group: 8-Band Discussion Forum
* Discussion: Welcome to the 8-band discussion forum. I look forward to your questions of feedback on our 8-Band imagery and the 8-Band Challenge.
We have seen a very positive response to the 8-Band Challenge, with a very large number of proposals received at the deadline. We are still going through the list of proposals and responding to the applicants. An automated response was not feasible because we received numerous questions, along with proposal submissions. I expect that we have received your application, but will confirm it next week.
Posted by Ian Gilbert
Анна, спасибо что потрудилась спросить их в linkedin'е, будем ждать.
Анна
да ну - за что спасибо-то?:) не за что
- syroezhka
Сегодня, наконец-то, пришло подтверждение от DG. Не в такой развернутой форме, как nadiopt. Просто одно предложение, мол получили.
аналогично
- nadiopt
может, это из-за того, что у меня заглючил Интернет, и я послала им свою заявку 2 раза случайно?
- nadiopt
ну и как дела обстоят? мне написали что-то в ключе "ах, мы зашились, заявок слишком много"
Мне написали что мол, молодец, принимаем твою писанину, продлили срок сдачи окончательных отчетов и напомнили про лицензию. Вот подробности:
DigitalGlobe is pleased to announce that we have accepted your proposal for the 8-Band Challenge. We have your area of interest covered in our archive, so we will be providing you with imagery within the next week or two.
The response to our inaugural challenge was tremendous, with over 500 highly qualified proposals. As a result we are extending the challenge into the second quarter of 2011 by adding a second judging event. We hope that you will take the opportunity to submit your research paper by December 1st in order to be considered for the awards presentation at Geospatial World Forum in January. However, if you are unable to submit your research in December, there will be a second deadline in early 2011. Only one paper may be submitted as part of the 8-Band Challenge. The final details for this second event will be announced in the near future.
When you receive your imagery, you will be bound by the terms and conditions of the End User License Agreement (EULA) which restricts you to using this imagery for research purposes only. Please make sure that you read and understand the EULA when you receive your imagery.
- nadiopt
что-то я туплю
"мы продлеваем конкурс до второго квартала 2011 г. путем добавления второго судилища"
(пардон за мой английский, я смысл передаю:))
"надеемся, что вы напишете отчет к 1-ому декабря" а если не получится - "второй дедлайн в начале 2011"
то есть если мы не сдаем отчет до декабря, на форум в январе не едем, и тогда нужно сдать его в январе 2011? а когда же новый форум? и почему первый дедлайн за месяц до форума, а второй зачем-то в январе, хотя типа второе судилище - аж во втором квартале (то есть не раньше апреля)?
как я понял, будет второе сборище некое.
http://dgl.us.neolane.net/res/dgl/surve ... 0719921&id
Прислали данные (ссылку на ФТП).
Данные - GeoTIFF нарезанные зачем-то на 9 частей, 8 канальные в UTM8. Дата паршивая, облака
Обрезано с точностью до первых метров 10 на 10 км.
gdalinfo -noct -norat -nomd 10JUL16080520-M3DS_R0_01_P001.TIF
Driver: GTiff/GeoTIFF
Files: 10JUL16080520-M3DS_R1C1-052408868010_01_P001.TIF
Size is 2048, 2048
Coordinate System is:
PROJCS["WGS 84 / UTM zone 38N",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",45],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","32638"]]
Origin = (611588.000000000000000,5099468.000000000000000)
Pixel Size = (2.000000000000000,-2.000000000000000)
Corner Coordinates:
Upper Left ( 611588.000, 5099468.000) ( 46d26'31.71"E, 46d 2'22
Lower Left ( 611588.000, 5095372.000) ( 46d26'28.26"E, 46d 0'10
Upper Right ( 615684.000, 5099468.000) ( 46d29'42.21"E, 46d 2'20
Lower Right ( 615684.000, 5095372.000) ( 46d29'38.63"E, 46d 0'7.
Center ( 613636.000, 5097420.000) ( 46d28'5.20"E, 46d 1'15.
Band 1 Block=2048x256 Type=UInt16, ColorInterp=Red
Min=338.000 Max=1408.000
Minimum=338.000, Maximum=1408.000, Mean=450.549, StdDev=135.927
Band 2 Block=2048x256 Type=UInt16, ColorInterp=Green
Min=182.000 Max=1060.000
Minimum=182.000, Maximum=1060.000, Mean=287.874, StdDev=110.887
Band 3 Block=2048x256 Type=UInt16, ColorInterp=Blue
Min=184.000 Max=1506.000
Minimum=184.000, Maximum=1506.000, Mean=386.031, StdDev=162.190
Band 4 Block=2048x256 Type=UInt16, ColorInterp=Undefined
Min=164.000 Max=1670.000
Minimum=164.000, Maximum=1670.000, Mean=431.343, StdDev=183.781
Band 5 Block=2048x256 Type=UInt16, ColorInterp=Undefined
Min=123.000 Max=1501.000
Minimum=123.000, Maximum=1501.000, Mean=387.044, StdDev=168.071
Band 6 Block=2048x256 Type=UInt16, ColorInterp=Undefined
Min=138.000 Max=1615.000
Minimum=138.000, Maximum=1615.000, Mean=480.717, StdDev=178.127
Band 7 Block=2048x256 Type=UInt16, ColorInterp=Undefined
Min=149.000 Max=1718.000
Minimum=149.000, Maximum=1718.000, Mean=608.301, StdDev=195.732
Band 8 Block=2048x256 Type=UInt16, ColorInterp=Undefined
Min=128.000 Max=1589.000
Minimum=128.000, Maximum=1589.000, Mean=555.592, StdDev=185.428пристегивайтесь, турбулентность прямо по курсу
