PyGMTSAR is Next Generation Interferometric Synthetic Aperture Radar (InSAR) Software for Everyone
MBG
Сообщение MBG » 12 фев 2023, 16:48
Do you need to produce satellite interferometry results for your work or study? Or should you find the way to process terabytes of radar data on your common laptop? Maybe you aren’t confident about the installation and usage of the required software. Fortunately, there is the next generation of satellite interferometry products available for you. Beginners can build the results easily and advanced users might work on huge datasets. Open Source software PyGMTSAR is available on GitHub for developers and on DockerHub for advanced users and on Google Colab for everyone. This is the cloud-ready product, and it works the same as do you run it locally on your old laptop as on powerful cloud servers. PyGMTSAR provides an interactive processing environment with annotations and quality plots and progress indicators for the complete processing pipeline. There is no software installation hassle or complex steps to produce the results, but just live annotated examples in your web browser are available with a single click. When it already works, you are free to change the source datasets and processing parameters and see all the results for your own tasks. Software invented to make our work more productive and it should not distract us from our work and PyGMTSAR follows the way.
Read more on Medium...
Константин Силкин
Re: PyGMTSAR is Next Generation Interferometric Synthetic Aperture Radar (InSAR) Software for Everyone
Сообщение Константин Силкин » 12 фев 2023, 16:59
Вам необходимо получить результаты спутниковой интерферометрии для работы или учебы? Или вам нужно найти способ обрабатывать терабайты радарных данных на обычном ноутбуке? Возможно, вы не уверены в установке и использовании необходимого программного обеспечения. К счастью, для вас доступно следующее поколение продуктов спутниковой интерферометрии. Новички могут легко получить результаты, а опытные пользователи могут работать с огромными наборами данных. Программное обеспечение с открытым исходным кодом PyGMTSAR доступно на GitHub для разработчиков, на DockerHub для опытных пользователей и на Google Colab для всех. Это готовый для облачных решений продукт, и он работает так же, как если бы вы запускали его локально на своем старом ноутбуке или на мощных облачных серверах. PyGMTSAR предоставляет интерактивную среду обработки с аннотациями, графиками качества и индикаторами выполнения для всего конвейера обработки. Не возникнет проблем с установкой программного обеспечения или сложных шагов для получения результатов. Однако просто живые аннотированные примеры в вашем веб-браузере доступны одним щелчком мыши. Когда ПО начало работать, вы можете свободно изменять исходные наборы данных и параметры обработки и видеть все результаты для своих собственных задач. Программное обеспечение создано для того, чтобы сделать нашу работу более продуктивной, и оно не должно отвлекать нас от работы, и PyGMTSAR идет по этому пути.
Прочитать больше на Mediun
Вернуться в «Обработка ДДЗ»
Сейчас этот форум просматривают: Bing [Bot] и 21 гость
