Привязка Ozi
AnnaBaticka
Привязка Ozi
Сообщение AnnaBaticka » 29 дек 2019, 22:36
Подскажите, пожалуйста, где можно найти полную информацию по структуре документа .map? Не могу привязать растр.
OziExplorer Map Data File Version 2.2
1 ,Map Code,
Pulkovo 1942 (2),WGS 84, 0.0000, 0.0000,WGS 84
Reserved 1
Reserved 2
Magnetic Variation,,,E
Map Projection,Transverse Mercator,PolyCal,No,AutoCalOnly,No,BSBUseWPX,No
Point01,xy, 48, 43,in, deg, 60, 20.0000,N, 30, 0.0000,E, grid, , , ,N
Point02,xy, 2201, 52,in, deg, 60, 20.0000,N, 30, 30.0000,E, grid, , , ,N
Point03,xy, 4354, 49,in, deg, 60, 20.0000,N, 31, 0.0000,E, grid, , , ,N
Point04,xy, 37, 1494,in, deg, 60, 10.0000,N, 30, 0.0000,E, grid, , , ,N
Point05,xy, 2200, 1503,in, deg, 60, 10.0000,N, 30, 30.0000,E, grid, , , ,N
Point06,xy, 4362, 1495,in, deg, 60, 10.0000,N, 31, 0.0000,E, grid, , , ,N
Point07,xy, 26, 2940,in, deg, 60, 0.0000,N, 30, 0.0000,E, grid, , , ,N
Point08,xy, 2202, 2952,in, deg, 60, 0.0000,N, 30, 30.0000,E, grid, , , ,N
Point09,xy, 4377, 2946,in, deg, 60, 0.0000,N, 31, 0.0000,E, grid, , , ,N
Point10,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point11,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point12,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point13,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point14,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point15,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point16,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point17,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point18,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point19,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point20,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point21,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point22,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point23,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point24,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point25,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point26,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point27,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point28,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point29,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Point30,xy, , ,in, deg, , ,N, , ,W, grid, , , ,N
Projection Setup, 0.000000000, 33.000000000, 1.000000000, 500000.00, 0.00,,,,,
Map Feature = MF ; Map Comment = MC These follow if they exist
Track File = TF These follow if they exist
Moving Map Parameters = MM? These follow if they exist
MM0,Yes
MMPNUM,4
MMPXY,1,48,43
MMPXY,2,4354,49
MMPXY,3,4377,2946
MMPXY,4,26,2940
MMPLL,1, 30.000000, 60.333333
MMPLL,2, 31.000000, 60.333333
MMPLL,3, 31.000000, 60.000000
MMPLL,4, 30.000000, 60.000000
MM1B,12.411942
MOP,Map Open Position,0,0
IWH,Map Image Width/Height,4406,2981
Re: Привязка Ozi
Сообщение tikhpetr » 09 янв 2020, 10:26
Файл привязки у Вас правильный в чем затык?
