3DPolyline
Uchenik
3DPolyline
Здравствуйте! А есть ли инструмент, с помощью которого можно перевести 3DPolyline и LWPolyline в простую Polyline?
Re: 3DPolyline
причём тут ArcGIS?
- novia
Re: 3DPolyline
посмотрите такой рецепт https://support.esri.com/en/technical-article/000010389
Procedure
1. Browse to ArcToolbox > Conversion Tools > To Geodatabase.
2. Open the Feature Class to Geodatabase (multiple) tool.
3. Add all the feature classes into the Input Feature Class parameter.
4. Select an Output Geodatabase.
5. Click the Environments button at the bottom of the tool dialog box.
6. Expand the General Settings.
7. For the parameter, Output has Z Values, change the value to Disabled.
8. For the parameter, Output has M Values, change the value to Disabled.
9. Click OK in the Environments dialog box.
10. Click OK to execute the geoprocessing tool.
Uchenik
Re: 3DPolyline
Спасибо!
