Помогите разобраться с модулем NextGIS Web Qgis
u3max
Re: Помогите разобраться с модулем NextGIS Web Qgis
Сообщение u3max »
Denis Rykov писал(а):
PYTHONPATH='' env/bin/nextgisweb --config config.ini initialize_db
в первую очередь хотел бы сказать Вам спасибо за ценные советы!!..но чего-то они перестали помогать...
root@nextgis:~/ngw# PYTHONPATH='' env/bin/nextgisweb --config config.ini initialize_db
root@nextgis:~/ngw# /root/ngw/env/bin/pserve development.ini
  File "/root/ngw/env/bin/pserve", line 11, in <module>
    sys.exit(main())
  File "/root/ngw/env/local/lib/python2.7/site-packages/pyramid/scripts/pserve.py", line 60, in main
    return command.run()
  File "/root/ngw/env/local/lib/python2.7/site-packages/pyramid/scripts/pserve.py", line 371, in run
    global_conf=vars)
  File "/root/ngw/env/local/lib/python2.7/site-packages/pyramid/scripts/pserve.py", line 406, in loadapp
    return loadapp(app_spec, name=name, relative_to=relative_to, **kw)
  File "/root/ngw/env/local/lib/python2.7/site-packages/paste/deploy/loadwsgi.py", line 247, in loadapp
    return loadobj(APP, uri, name=name, **kw)
  File "/root/ngw/env/local/lib/python2.7/site-packages/paste/deploy/loadwsgi.py", line 272, in loadobj
    return context.create()
  File "/root/ngw/env/local/lib/python2.7/site-packages/paste/deploy/loadwsgi.py", line 710, in create
    return self.object_type.invoke(self)
  File "/root/ngw/env/local/lib/python2.7/site-packages/paste/deploy/loadwsgi.py", line 146, in invoke
    return fix_call(context.object, context.global_conf, **context.local_conf)
  File "/root/ngw/env/local/lib/python2.7/site-packages/paste/deploy/util.py", line 55, in fix_call
    val = callable(*args, **kw)
  File "/root/ngw/nextgisweb/nextgisweb/__init__.py", line 65, in main
    env = Env(cfg)
  File "/root/ngw/nextgisweb/nextgisweb/env.py", line 21, in __init__
    components_ignore=components_ign)
  File "/root/ngw/nextgisweb/nextgisweb/component.py", line 99, in load_all
    __import__(pkginfo.comp_mod(comp))
  File "/root/ngw/nextgisweb/nextgisweb/wmsclient/__init__.py", line 3, in <module>
    from .model import Base, Connection, Layer, WMS_VERSIONS
  File "/root/ngw/nextgisweb/nextgisweb/wmsclient/model.py", line 14, in <module>
    from owslib.map.common import WMSCapabilitiesReader
ImportError: No module named map.common
Ваше звание: Author
Сообщение Denis Rykov »
Ну всё же понятно, вы переопределили PYTHONPATH, поэтому и OWSLib у вас ищется не в нужном месте, уверен, что вот так запустится без ошибок:
PYTHONPATH='' env/bin/pserve development.ini
u3max
Сообщение u3max »
Denis Rykov писал(а):Ну всё же понятно, вы переопределили PYTHONPATH, поэтому и OWSLib у вас ищется не в нужном месте, уверен, что вот так запустится без ошибок:
Точно! Большое спасибо, запустился!
Ваше звание: Author
А чего вы радуетесь, QGIS то всё равно не заработает :) Какие ошибки возникают в процессе установки nextgisweb_qgis, PyQt не находится?
u3max
Сообщение u3max »
Может мы что-то не так сделали, но, вроде, у нас работает. Перенеслись стили и подписи, пока qgis не поставили, не переносились, копировался только шейп без раскраски. Но мы уже радуемся. Рано, да? :)
nextgisweb_qgis установился без ошибок. pyqt тоже нашёлся. Это магия, спасибо!!! :)
Ваше звание: Author
Ну тогда поздравляю, квест пройден.
Сообщение Максим Дубинин »
u3max писал(а):Это магия
это не магия, а поддержка адекватная
u3max
Сообщение u3max »
При добавлении на десктопе в Qgis ресурса не отображает карту и питон десктопа выдаёт ошибку:
2017-02-13T12:57:18	1	Traceback (most recent call last):
			  File "c:/NEXTGI~1/apps/qgis/./python/plugins\nextgis_connect\tree_panel.py", line 467, in __export_to_qgis
			    add_resource_as_geojson(ngw_resource)
			  File "c:/NEXTGI~1/apps/qgis/./python/plugins\nextgis_connect\ngw_api\qgis\resource_to_map.py", line 34, in add_resource_as_geojson
			    raise NGWError('Layer %s can\'t be added to the map!' % resource.common.display_name)
			  File "c:/NEXTGI~1/apps/qgis/./python/plugins\nextgis_connect\ngw_api\core\ngw_error.py", line 25, in __init__
			    self.message = unicode(message, 'utf-8')
			TypeError: decoding Unicode is not supported
Ваше звание: Author
Всё в кучу не сваливайте. Один вопрос - одна тема.
Вернуться в «NextGIS»
