30+ years of LAI and FAPAR data for Your research use
Ваше звание: хрюкало
Сообщение nadiopt » 15 янв 2013, 08:49
выдается бесплатно, то есть даром. Если надо, переведу, но попозже, сейчас работой обложили
Dear Colleague,
We are providing you free access to a 30+ year long global data sets of vegetation leaf area index (LAI3g) and fraction vegetation absorbed photosynthetically active radiation (FPAR3g). These data sets were derived from the third generation GIMMS NDVI3g data set (hence the suffix "3g"). The data sets are at 1/12 degree resolution, 15-day composites (2 per month) and span the period July 1981 to December 2011. A set of neural networks were first trained on best-quality and significantly post-processed MODIS LAI and FPAR products and AVHRR GIMMS NDVI3g data for the overlapping period (2000 to 2009). The trained neural networks were then used to produce the LAI3g and FPAR3g data sets.
You can download the LAI3g and FPAR3g data sets together with documentation and a research article (plus supporting material accompanying the article) from the links to our dropbox location below my signature. Please note the following:
(1) If you wish to submit an article to the special dedicated to NDVI3g/LAI3g/FPAR3g of the open source journal "Remote Sensing" you are welcome. The link is:
http://www.mdpi.com/journal/remotesensi ... ing_global
(2) These data sets, plus the NDVI3g data set when approved for release by Dr. Tucker, the special issue articles, codes and other documents will be posted at NASA Earth Exchange (https://c3.nasa.gov/nex/)
(3) For all information, please email rmy...@bu.edu
Sincerely,
Ranga B. Myneni
1) LAI3g
https://dl.dropbox.com/u/51768478/%28di ... v01.tar.gz
2) FPAR3g
3) LAI3g-FPAR3g documentation
https://dl.dropbox.com/u/51768478/%28di ... ts-v01.pdf
4) Paper describing the production and evaluation of the data sets
https://dl.dropbox.com/u/51768478/%28di ... 2_2012.pdf
5) Supporting material accompanying the paper
Natalia Novoselova
Ваше звание: Лиса
Re: 30+ years of LAI and FAPAR data for Your research use
Сообщение Natalia Novoselova » 15 дек 2016, 19:33
Данные в первом сообщении ссылки устарели. Связалась с авторами (Ranga B. Myneni) и мне дали новую ссылку на скачивание базы:
http://sites.bu.edu/cliveg/datacodes/
Data and Codes
30+ Year LAI and FPAR Data Sets: We are providing free access to a 30+ year long global data sets of vegetation index (NDVI3g), leaf area index (LAI3g) and fraction vegetation absorbed photosynthetically active radiation (FPAR3g). The data sets are at 1/12 degree resolution, 15-day composites (2 per month) and span the period July 1981 to December 2011.The links to these data sets are in this file.
10+ Years of MODIS LAI and FPAR Data Sets:Dowload From the EDC DAAC
И еще описание этой базы:
http://cliveg.bu.edu/modismisr/lai3g-fpar3g.html
30+ Years of LAI3g and FPAR3g Data Sets
(2) The article describing the LAI3g/FPAR3g by Zhu et al. can downloaded from the Special Issue
Cтатья, описывающая создание и точность этой базы (найти среди статей по сслыке). Open access.
(3) To obtain the data sets, please contact Ranga B. Myneni
Еще описание: http://nasanex.s3.amazonaws.com/AVHRR/G ... ME_V01.pdf
P.S. Статья о которой говорят во 2 ссылке похоже вот эта.
Global Data Sets of Vegetation Leaf Area Index (LAI)3g and Fraction of Photosynthetically Active Radiation (FPAR)3g Derived from Global Inventory Modeling and Mapping Studies (GIMMS) Normalized Difference Vegetation Index (NDVI3g) for the Period 1981 to 2011.
Т.к. она Open access но приложу ее к посту.
Zhu et al_2013.pdf
(1.44 МБ) 390 скачиваний
gimms_list.txt
(164.94 КБ) 658 скачиваний
Последний раз редактировалось Natalia Novoselova 16 дек 2016, 00:15, всего редактировалось 8 раз.
Natalia Novoselova
Ваше звание: Лиса
Сообщение Natalia Novoselova » 15 дек 2016, 19:39
Уф. нервы шалят. Разобралась ))
Вопрос аннулирую. Пусть просто тогда в качестве обновления инфы будет.
Вернуться в «Данные»
