FeatureServer
Nik220
FeatureServer
Сообщение Nik220 » 09 дек 2016, 11:58
Жители форума!
Есть такая штука http://featureserver.org/. Я поставил её на отдельный сервер. Есть другой отдельный сервер - PostgreSQL + PostGIS. С помощью osm2pgsql импортировал карту Москвы.osm.pbf. В featureserver.cfg (https://github.com/iocast/featureserver ... server.cfg) прописал параметры fs_postgis, где layer = planet_osm_point. Запустил featureserver_http_server.py.
The following layers are available:
* fs_flickr, http://192.168.0.82:8080/fs_flickr
* fs_twitter, http://192.168.0.82:8080/fs_twitter
* fs_spatiallite, http://192.168.0.82:8080/fs_spatiallite
* fs_postgis, http://192.168.0.82:8080/fs_postgis
* fs_geoalchemy, http://192.168.0.82:8080/fs_geoalchemy
Перешел на http://192.168.0.82:8080/fs_postgis
38.4078238189,54.8280979842None None None None None None None None None None None None None None None None None None None 0.0 None None None None None (4275539.39,7328574.66) None None None None 37.519272144,55.5915034889None None None None None None None None None None None None None None None None None None None 0.0 None None None None None (4176626.27,7477521.65) None None None None 37.5180823254,55.6013502951None None None None None None None None None None None None None None None None None None None 0.0 None None None None None (4176493.82,7479461.66) None None None None 37.5179645562,55.6011852046None None None None None None None None
и т.д. Вместо карты он выводит в строку содержимое таблицы.
Вопрос: как отобразить карту? (как тут - http://featureserver.org/demo.html)
Сижу вторую неделю. Помогите, пожалуйста.
Настройки такие:
[fs_postgis]
type=PostGIS
title=Point from OpenStreetMap
abstract=Point-of-Interests (POIs) from OpenStreetMap. (Hstore example)
dsn=host='соответственно парметры'
layer=planet_osm_point
fid=osm_id
geometry=way
version=hstore(tags)->'version'
fe_attributes=true
srid=900913
srid_out=4326
order=z_order
hstore=true
hstore_attr=tags
ele=hstore(tags)->'ele'
attribute_cols=name, way::Point as "geometry_type", hstore(tags)->'operator' as "operator", hstore(tags)->'highway' as "highway", hstore(tags)->'amenity' as "amenity", hstore(tags)->'historic' as "historic", hstore(tags)->'natural' as "natural", hstore(tags)->'url' as "url", hstore(tags)->'contact:website' as "contact_website", hstore(tags)->'website' as "website", hstore(tags)->'wikipedia' as "wikipedia", hstore(tags)->'wikipedia:en' as "wikipedia_en", hstore(tags)->'wikipedia:de' as "wikipedia_de", hstore(tags)->'addr:street' as "street", hstore(tags)->'addr:housenumber' as "housenumber", hstore(tags)->'addr:postcode' as "postcode", hstore(tags)->'addr:city' as "city", hstore(tags)->'phone' as "phone", hstore(tags)->'tourism' as "tourism", hstore(tags)->'shop' as "shop", hstore(tags)->'opening_hours' as "opening_hours", hstore(tags)->'bicycle_parking' as "bicycle_parking", hstore(tags)->'railway' as "railway", hstore(tags)->'aeroway' as "aeroway", hstore(tags)->'leisure' as "leisure", hstore(tags)->'species' as "species", hstore(tags)->'surface' as "surface"
additional_cols=round(ST_Area2d(ST_Transform(way, 21781))) as sqm
#<minx> <miny> <maxx> <maxy>
bbox=5.95459 45.75986 10.52490 47.83528
# Possible values: Point, LineString, Polygon
geometry_type=Point
Re: FeatureServer
Сообщение Максим Дубинин » 09 дек 2016, 12:04
FeatureServer умер
Nik220
Re: FeatureServer
Сообщение Nik220 » 09 дек 2016, 12:12
Максим Дубинин писал(а):FeatureServer умер
В каком смысле?
Andrey Zhukov
Ваше звание: старик-гисовик
Re: FeatureServer
Сообщение Andrey Zhukov » 09 дек 2016, 12:22
4 комита с 2012 года не смущают? :)
Nik220
Re: FeatureServer
Сообщение Nik220 » 09 дек 2016, 12:28
Andrey Zhukov писал(а):4 комита с 2012 года не смущают? :)
Смущали. Но сайт рабочий и сервер на нем прорисовывает карту => значит версия c GitHub'а должна работать.
Andrey Zhukov
Re: FeatureServer
Сообщение Andrey Zhukov » 09 дек 2016, 12:45
Вполне вероятно, проблемы с совместимостью со свежей версией PostGIS.
Nik220
Re: FeatureServer
Сообщение Nik220 » 09 дек 2016, 13:14
Andrey Zhukov писал(а):Вполне вероятно, проблемы с совместимостью со свежей версией PostGIS.
Возможно, но мне кажется он бы тогда вообще ничего не отображал. Но я обязательно посмотрю, все равно идей больше нет.
У кого-нибудь ещё какие-нибудь мысли есть?
Re: FeatureServer
Сообщение freeExec » 09 дек 2016, 15:01
Отображает тайлы с сервера OSM.ORG вам это ни на что не намекает?
Nik220
Re: FeatureServer
Сообщение Nik220 » 09 дек 2016, 15:09
freeExec писал(а):Отображает тайлы с сервера OSM.ORG вам это ни на что не намекает?
Что Вы имеете в виду?
Ваше звание: Author
Re: FeatureServer
Сообщение Denis Rykov » 09 дек 2016, 17:03
Если речь идёт о растровых тайлов, то вы выбрали не тот инструмент. По ссылке, которую вы привели, я вижу подложку OSM и пару полигонов, так вот подложка никакого отношения к FeatureServer-у не имеет.
Nik220
Re: FeatureServer
Сообщение Nik220 » 09 дек 2016, 17:44
Denis Rykov писал(а):Если речь идёт о растровых тайлов, то вы выбрали не тот инструмент. По ссылке, которую вы привели, я вижу подложку OSM и пару полигонов, так вот подложка никакого отношения к FeatureServer-у не имеет.
Я не совсем вас понимаю. Т.е. он не может отобразить оффлайн-карту из PostGIS, например как QGIS?
Если взглянуть на http://featureserver.org/ раздел Servises. Там написано следующее:
OGR The OGR datasource allows you to take any OGR datasource -- such as a shapefile, PostGIS database, GML file, or other formats supported by OGR -- and use it as a backend for a FeatureServer layer.
(OGR позволяет принимать любой источник данных - такие как шейп-файлы, базы данных PostGIS, файлы GML, или другие форматы, которые поддерживает OGR - использовать их в качестве основы для слоя FeatureServer.)
OSM Load streets from OpenStreetMap by area, id, or key/value pair.
(Загрузка OSM из OpenStreetMap по району, ID, или пары ключ/значение.)
PostGIS The PostGIS datasource implements a direct connection to PostGIS, allowing for full featured editing/updating.
(Реализует прямое подключение к PostGIS , что позволяет полноценно редактировать/обновлять.)
Т.е. как я понимаю:
- загружаем в БД слои, например osm.
- настраиваем соединение с БД.
- он должен отобразить оффлайн-карту в браузере, как QGIS.
Я остановился на моменте отображения. К сожалению, я плохо понимаю это должны быть тайлы или стиль. Как в демо (http://featureserver.org/demo.html), только карта Москвы и только Point (пока я настроился на них, пусть хотя бы что-то отобразит).
Последний раз редактировалось Nik220 12 дек 2016, 09:58, всего редактировалось 1 раз.
Ваше звание: Author
Re: FeatureServer
Сообщение Denis Rykov » 09 дек 2016, 18:55
Какая задача перед вами стоит? Вы хотите отображать именно вектор?
Nik220
Re: FeatureServer
Сообщение Nik220 » 10 дек 2016, 19:57
Denis Rykov писал(а):Какая задача перед вами стоит? Вы хотите отображать именно вектор?
Настроить FeatureServer.
Nik220
Re: FeatureServer
Сообщение Nik220 » 12 дек 2016, 12:00
Товарищи, хотя бы объясните, чем он карты отрисовывает и почему стиль как OSM!? :cry:
Andrey Zhukov
Re: FeatureServer
Сообщение Andrey Zhukov » 12 дек 2016, 12:25
Demo отрисовывает тайлы OSM с помощью OpenLayers2.
Что делает FeatureServer? Пытается сохранить нарисованные объекты через WFS, но у него получается через раз.
Основной вопрос к автору: зачем пользоваться мертвым софтом? В чем задача? Если побаловаться - поражаюсь вашему упорству. Если задача от начальства - сочувствую, рекомендую узнать задачу целиком и решить ее с помощью рабочего софта.
Вернуться в «Веб-картография»
